Sun Apr 30, 2023 12:25 am
VLAN design will depend on what you want to do with VLAN's, besides this wifiwave2.
3 separate SSID (2.4GHz, 5GHz and 5 GHz-guest) , on 3 separate LAN subnets as you describe, in one device, if that is all, do not need the use of VLAN.
