Bikeprincess
hAP ax2 wifi not detected
Sun Apr 30, 2023 1:10 am
I have problem with my hAP ax2. On last connection I found, that the router don't have wifi interface. In log is show only in log:
"DefConf gen: Unable to find wireless interface(s)"
and I can't find any way to fix it. I try to reset to factory firmware, reset config, but the problem is still here. Any help, or it's better to return resseler?
dcavni
Re: hAP ax2 wifi not detected
Sun May 07, 2023 1:47 pm
Try to update RouterOS and then Firmware. If this won't help send it back and get anoter one.
mkx
Re: hAP ax2 wifi not detected  [SOLVED]
Sun May 07, 2023 1:53 pm
Make sure that ax2 has package wifiwave2 installed (look under /system/packages) ... it's available in "Extra Packages" archive on download.mikrotik.com, just make sure it's exactly the same version as routeros package.
After you install the package, perform reset to factory config to get default wireless config in place.
Bikeprincess
Mon May 08, 2023 12:04 am
Ok, thanks for reply. That's help :)
Users browsing this forum: No registered users and 23 guests
