Techsystem
Endpoint-Independent NAT when applying Hairpin NAT
Sun Apr 30, 2023 12:26 pm
Hello my friends..!
so i am trying to solve a problem related to Hairpin NAT in my RB951ui, so i stop against this Endpoint-Independent NAT thing that i didn't find in my router
so anyone know any thing about it..?
also if anyone have any suggestion about what i am facing here is my problem:
i have a mikrotik router, and i apply this hairpin rule to open my duhua NVR using the public ip address on my app
first here is my dst nat rule chain=srcnat action=masquerade to-addresses=192.168.2.2 protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.122 dst-port=38888 log=no .
and here is my hairpin NAT rule
the second rule : 2 chain=dstnat action=dst-nat to-addresses=192.168.1.122 to-ports=38888 protocol=tcp dst-address=192.168.2.2 dst-port=38888 log=no .
i placed the hairpin nat before all rule.
the connection is working only for 2 second then the traffic stop and disconnect..
so what may case this to happen..?
is there is anything that i have to apply with this rule to make the connection persist..?
what case this connection to drop on the first place..?
loloski
Re: Endpoint-Independent NAT when applying Hairpin NAT
Sun Apr 30, 2023 12:54 pm
I suggest use zerotier and network routing this will help you a lot, no more hairpit nat issue, just my 0.2$
baragoon
Sun Apr 30, 2023 1:22 pm
zerotier on RB951ui? it will not work without unicorns
wiseroute
Sun Apr 30, 2023 5:21 pm
hello @ Techsystem
i think your nat rules are ok, except maybe you forgot about the in-interface for the dstnat rule, prerouting.
and out-interface for your srcnat rule.
good luck 👍🏻
Guscht
Sun Apr 30, 2023 6:01 pm
You wrote a lot but missed imporatant information!
Simple solution, put the device (your HUNAHUNA-stuff) in another VLAN - problem solved, because cleint und server are in different VLANs.
More Complex solution:
You DNAT 192.168.2.2:38888 (this should be your public IP!) to 192.168.1.122:38888
Second rule (here we have to change the source-IP from the inital-device to the IP of the router):
Is 192.168.2.2 the IP of your router in this network?
After both NAT-rules, the HUNAHUNA-device sees a packet:
Destination-IP: 192.168.1.122:38888
Source-IP: ????????????:38888
PROBLEM: In the Masquerade-Action you cant specify a "to-address". Masquarde is a dynmic-action which uses the IP of the router in that network.
Techsystem
Mon May 01, 2023 9:26 am
Hello Mr.Guscht ..!
yes you can pretend the 192.168.2.2 as the public IP..
for the second complex solution that's didn't work on my scenario, yet i am curious to know how can i put my NVR inside different VLAN
so in my network i have a bridge interface that contain all interface except the ether-1
this NVR is connected to poe switch and the switch connected to the router through one of router interface -(i think ether3)- so how can i apply VLAN for this specific IP address..?
you mean to create Enter-Vlan routing..?
Ca6ko
Long time Member
Long time Member
Mon May 01, 2023 5:02 pm
Why do you create several threads with the same problem.viewtopic.php?t=195707
Your task is to make it as clear as possible to other users to ask a question and then get help.
To do this, it is best to draw a network diagram.
There is no need to use 192.168.0.0/16 for public addresses in the examples, so as not to mislead others. There is a pool of special addresses for that, 192.0.2.0/24, 198.51.100.0/24, and 203.0.113.0/24
Endpoint-Independent NAT does not work at all for you because it does not work with the TCP protocol
I have had several devices working steadily for years. You only need to replace the public address with your own.
add action=dst-nat chain=dstnat comment="Videoreg NVR" dst-port=38888 in-interface=ether1 protocol=tcp to-addresses=192.168.1.122
add action=dst-nat chain=dstnat dst-address=198.51.100.28 dst-port=38888 in-interface=Bridge protocol=tcp src-address=192.168.1.0/24 to-addresses=192.168.1.122
add action=masquerade chain=srcnat dst-port=38888 protocol=tcp src-address=192.168.1.0/24
If you had asked the questions correctly, you would have got the solution long time ago.
Feature of Dahua registrars, you can not reassign ports. That is, the device port 38888 and the router must also be the port 38888 if you make a port change will not always work.
In the dst-nat rule, if the input and output ports are the same, there is no need to specify the output port.
Techsystem
Mon May 01, 2023 7:41 pm
No..!
not that way..!
first this didn't work on my situation viewtopic.php?t=195707
i make it like crystal, i have a DMZ inside my asus router and i don't want to make this situation very complicated, so for that i have dst-nat like 192.168.2.2 so this represent my router out interface ip address, and sure i know that already its work. as i said that i can see my device as normal from outside.
i run a sniffer inside my LAN and what i notice that this hairpin NAT rule that i created work for one time, then disappear form the trace, so is this normal..?
also i mentioned previously that the rule is working however there is a huge delay in traffic -(if i open my app inside my local network with 1 public ip assigned to this app it work for 4 second as a real time live stream then stopped then after 20 second run again ...etc)- . so i asked a solution to this specific case.
Amm0
Mon May 01, 2023 7:59 pm
@techsystem, are you sure the "streaming" isn't using TCP?
Techsystem
Tue May 02, 2023 5:26 am
how cam i know..? you mean from Tracefile..?
Ca6ko
Long time Member
Long time Member
Wed May 03, 2023 3:22 pm
You don't have a public address on the mikrotik so it has nothing to do with it. You have an Asus for Hairpin NAT.
You don't understand the situation correctly and are therefore looking for the wrong solutions.
Mikrotik's Hairpin NAT settings will allow you to access its external address 192.168.2.2 from the network 192.168.1.0/24 !!!
You are making a few Dahua related mistakes when setting up Mikrotik.
Enable port forwarding 38888 on the Asus to the internal 192.168.2.2 address and disable the DMZ. Warning In the screenshot port forwarding is disabled
On the Mikrotik make these settings, put these rules above your own and remove unnecessary rules. viewtopic.php?t=195707#p998939
add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=38888 protocol=tcp to-addresses=192.168.1.122
add action=src-nat chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
After that, everything will work correctly.
Techsystem
Wed May 03, 2023 8:04 pm
i agree, maybe really i don't understand my situation, but
what make me do that is that i have a DMZ in my asus and alot of port forwarding rule in mikrotik not asus and it work well..!!
i will apply your solution and give you the output, hope that all this work.
Techsystem
Thu May 04, 2023 9:25 am
Hello Mr.Ca6ko..!
so i am in my lab right now and i just apply your rules.
First: so ok i disable the DMZ in asus and apply your rule and it work fine for the out internet connection as its before so no thing change -(as i said i can open my NVR using public ip from outside)- so its another way to apply port forwarding without DMZ..OK
second: for my main problem that doesn't change any thing ..!
still the same problem, so still i can't open my NVR using my public IP inside my LAN.
i apply this rule that you mentioned to add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=38888 protocol=tcp to-addresses=192.168.1.122
for this rule add action=src-nat chain=srcnat comment="defconf: masquerade" out-interface-list=WAN i put the to address as 192.168.2.2
also i try to put the src-add as 192.168.1.0/24 and the dst-add as 192.168.1.122 and the action as Masqurade but also that's didn't work..!
Ca6ko
Long time Member
Long time Member
Thu May 04, 2023 10:04 am
Show the mikrotik configuration after applying my recommendations
viewtopic.php?p=999909#p999769
Techsystem
Thu May 04, 2023 11:02 am
so here is my config after your recommendations
Ca6ko
Long time Member
Long time Member
Thu May 04, 2023 10:52 pm
Techsystem wrote Wed Apr 26, 2023 7:35 pm
give an advise or explaination about how can i config this ...
add action=src-nat chain=srcnat comment="defconf: masquerade" out-interface-list=WAN to-addresses=192.168.2.2
Ca6ko wrote Fri Apr 28, 2023 10:40 am
For mikrotik you have to turn on the standard NAT and disable unnecessary rules.
Techsystem wrote Sun Apr 30, 2023 12:26 pm
Ca6ko wrote Wed May 03, 2023 3:22 pm
Techsystem wrote Thu May 04, 2023 11:02 am
I give up :shock:
Techsystem
Fri May 05, 2023 6:42 am
I give up :shock:
sorry but really i didn't understand what you meant..!
it seems that i have a logistic problem with your explanation..! do you have a problem with my NAT rule..? here is it as its in the router, just rewrit it in this thread and to agree on some colour
any unnecessary rule write it in Red and any additional rule write it in Green, if the rule didn't need change keep it as black.
my NAT rules:
add action=masquerade chain=srcnat dst-address=192.168.1.122 dst-port=38888 \
out-interface=Bridge protocol=tcp src-address=192.168.1.0/24 \
add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=38888 \
protocol=tcp to-addresses=192.168.1.122 to-ports=38888
add action=src-nat chain=srcnat comment="defconf: masquerade" \
add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=34567 \
protocol=tcp to-addresses=192.168.1.10 to-ports=34567
add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=554 \
protocol=tcp to-addresses=192.168.1.244 to-ports=554
as i say i apply your rule from asus side.
well i also will be crateful if you explain this line from this post viewtopic.php?p=1000101#p999769
so you mean this is not achievable..? or my understanding of the Hairpin NAT is wrong..?
to update my situation its still not work...
Users browsing this forum: jaclaz, JazzMaster, trmns and 64 guests
