Dear concern,
I hope you will be fine.
I need the Mikrotik script for 4-WAN (is the same cost 50Mbps for each WAN) Load Balance from the same ISP.
Thanks.
What is the difference between pfsense load-balance algorithm and Mikrotik PCC Load Balance algorithm?
or try online script genaratorDear concern,
Thanks.
