jspool
v7 BGP Full Tables Core Usage
Sun Apr 30, 2023 11:43 pm
For those running BGP with full tables on v7 is it normal for one core to be 90-100% almost all the time when BGP is running. tool profile shows it as "routing". This happens regardless of no traffic or high traffic.
DarkNate
Re: v7 BGP Full Tables Core Usage
Mon May 01, 2023 12:38 am
If you didn't properly configure BGP input/output CPU affinity on all BGP peers to match the CPU model of your router, then you will face CPU issues.
https://help.mikrotik.com/docs/display/ ... sion%20are
Configure input multi-core processing. Read more in Routing Protocol Multi-core Support article.
alone - input and output of each session are processed in its own process, most likely the best option when there are a lot of cores and a lot of peers
afi, instance, vrf, remote-as - try to run input/output of new session in process with similar parameters
main - run input/output in the main process (could potentially increase performance on single-core even possibly on multi-core devices with a small amount of cores)
input - run output in the same process as input (can be set only for output affinity)
jspool
Mon May 01, 2023 12:44 am
This behavior occurs on baremetal x86 with 22 cores and CCR2116 with 16 cores. I have them set to "alone" BGP stability is good and throughput is good. Just always have a single core 90-100%. Curious what others have observed.
DarkNate
Wed May 03, 2023 11:33 pm
You need to set “alone” for all peers and both input/output on each peer. If you only do it for some peers and not all peers, you may see issues.
psilva
Fri May 05, 2023 7:30 am
I'm having the same problem even though all peers are configured affinity input/output alone. It keeps alternating 100% processing between CPU cores.
lekr74
Sat May 06, 2023 9:02 am
I saw that I have this issue once I open ip/route or ipv6/route windows on winbox.
If I reboot the router and don't open those windows, I don't have any core at ~100% for routing
jspool
Sun May 07, 2023 8:03 am
You are correct. After a reboot it no longer taps out one core. Mikrotik needs to figure out how to optimize Winbox so something as simple as ip/route or ipv6/route does not cause such behavior even after the ip/route box is closed or the Winbox session has been closed.
chechito
Sun May 07, 2023 8:29 am
sometimes when you open winbox and a window with many elements that consume alot of resources
is a matter of clossing that windows and then exit winbox
reopen winbox and wait (without opening a window with many elements) some minutes and that 100% core will be gone
windows with many elements:
simple queues when you have a lot of them
ip firewall when you hav a lot of rules
ip firewall connections when you use conn tracking
ip routes when you have a lot of routes
i think they have optimizes this, in some age problem was worst, i hope this improve, several full tables will be a increasingly frequent situation on CCR2216/2116
jspool
Sun May 07, 2023 10:08 pm
In my case I closed all windows and waited an hour as well as exited the Winbox session and opened a new one with only the system resources cpu box open and it was still tapping out a core. This was replicated on 4 x86 7.8 routers as well as a 7.8 CCR2116
DarkNate
Sun May 07, 2023 10:20 pm
Does this happen if you print the table in the terminal directly outside Winbox as well?
chubbs596
Wed May 31, 2023 12:56 pm
Im also seeing similar issues, Im currently testing on V7.10rc1
lanrat
Thu Jan 04, 2024 1:34 am
I'm also observing this exact same behavior on RouterOS 7.13.
Opening the route list in winbox, even if filtering, maxes one core to 100%. Closing the window or winbox does not fix the issue. Restarting the entire routes does seem to fix it, which is not an option for a production machine.
interco
Thu Jan 25, 2024 8:44 am
Same problem here, also SNMP stops working because of the high cpu usage.
Users browsing this forum: mrtrca, mrz and 10 guests
