robvangils
Reaching 2 VLAN's on a single port for a client device
Mon May 01, 2023 10:59 am
Hi all,
equiptment used:
CRS328-4C-20S-4S+RM (Main Switch)
CRS-106-1C-2S (Field Switch)
mAP Lite (WiFi Client)
What i am trying to do:
On the Main Switch:
Combo 1 trunk port carrying VLAN 10 and 20
Combo 2 Acces/Client port carrying VLAN 10 and 20 (Computer needs to acces both VLAN's)
Combo 4 Acces/Client port carrying VLAN 10
On the Field Switch:
SFP1 trunk port carrying VLAN 10 and 20
SFP 2 Acces/Client port carrying VLAN 10
SFP 3 Acces/Client port carrying VLAN 10
Combo 1 Acces/Client port carrying VLAN 20
VLAN 10 will be used to send data to control a lighting instalation
VLAN 20 will be used to connect a 4G modem at the Field Switch and have that accessible at the Main Switch
The mAP Lite is now connected to the combo1 port on the Field Switch, he is set up as a wifi client to simulate the 4G Modem
I already managed to create the trunk between the 2 switches. the single VLAN access ports also work fine, now i need to get the access port with both vlans working
Main Switch config:
# may/01/2023 09:55:12 by RouterOS 6.48.6
# software id = HKMI-SCQX
# model = CRS328-4C-20S-4S+
# serial number = HE508HDYECJ
add name=BR-VLAN10
add name=BR-VLAN20
/interface vlan
add interface=combo1 name=vlan10 vlan-id=10
add interface=combo1 name=vlan20 vlan-id=20
/ip hotspot profile
add bridge=BR-VLAN10 interface=vlan10
add bridge=BR-VLAN10 interface=combo4
add bridge=BR-VLAN20 interface=vlan20
add bridge=BR-VLAN20 interface=combo2
/interface bridge vlan
add vlan-ids=10,20
add address=10.0.10.1/8 interface=vlan10 network=10.0.0.0
add address=10.0.20.1/8 interface=vlan20 network=10.0.0.0
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name="Main Switch 1"
/system routerboard settings
set boot-os=router-os
Field Switch Config:
# may/01/2023 09:55:53 by RouterOS 6.48.6
# software id = 4S29-DICX
# model = CRS106-1C-5S
# serial number = HE908YESN9B
add name=BR-VLAN10
add name=BR-VLAN20
/interface vlan
add interface=sfp1 name=vlan10 vlan-id=10
add interface=sfp1 name=vlan20 vlan-id=20
add bridge=BR-VLAN10 interface=sfp2
add bridge=BR-VLAN20 interface=combo1
add address=10.0.10.2/8 interface=vlan10 network=10.0.0.0
add address=10.0.20.2/8 interface=vlan20 network=10.0.0.0
/system clock
/system identity
set name="Field Switch 2"
tdw
Re: Reaching 2 VLAN's on a single port for a client device
Mon May 01, 2023 1:36 pm
Stop using multiple bridges. Since the introduction of VLAN-aware bridges you should use a single bridge to avoid many pitfalls https://help.mikrotik.com/docs/display/ ... figuration.
There is an excellent guide viewtopic.php?t=143620, the basic information on them is in the help pages https://help.mikrotik.com/docs/display/ ... NFiltering or https://help.mikrotik.com/docs/pages/vi ... mples-VLAN for CRS1xx/2xx.
Users browsing this forum: Bing [Bot], Innoce and 49 guests
