Techsystem
Problem with generated Certificate in CAPsMAN configuration
Wed May 03, 2023 11:12 am
Hello for all Mikrotik people there..!
so i have two RB951ui and i am trying to setup a CAPsMAN scenario between both routers, and it work well, but when i came to enable the Certificate it didn't work
you can see the picture below.
my config is so simple you can check it in the attached file below, yet no certificate generated.
as you see no value in Generated Certificate field. -(i press apply and wait for a while but no thing happen)-
Users browsing this forum: GoogleOther [Bot] and 16 guests
