conecting
Unifi controller on Mikrotik RB5009 7.9
Wed May 03, 2023 5:07 pm
Hi !
I have issue with installing container to rb5009 with 7.9
Unifi controller on mikrotik were working perfectly before using this script :
/system/device-mode/update container=yes
/interface/veth/add name=veth1-unifi address=192.168.88.10/24 gateway=192.168.88.1
/interface/bridge/port add bridge=bridge interface=veth1-unifi
/container config set registry-url=https://registry-1.docker.io tmpdir=disk1
/container/config/set ram-high=600M
/container/mounts add dst=/config name=unifi-controller_config src=/disk1/containers/unifi-controller/config
/container add remote-image=jacobalberty/unifi:latest hostname=unifi interface=veth1-unifi logging=yes mounts=unifi-controller_config root-dir=disk1/containers/unifi-controller workdir=disk1/containers/unifi
After extracting procedure
It writes stoped
Even after I try to run it with:
/container start 0
it won't start
Does anybody have any idea how to fix it ?
soonwai
Re: Unifi controller on Mikrotik RB5009 7.9
Wed May 03, 2023 9:16 pm
Any errors in the log? I had a container which refused to start due to uid & guid permission problem.
masseselsev
Wed Jul 12, 2023 6:57 pm
Same behaviour on Chateau 18 (7.10.2), tried 5 different unifi container versions (the one from the OP, the one from linuxserver, and some of their older versions) with no luck.
Every time it just halts everything on ..getting layer.. without any further logs.
And it also stops all the containers running.
And no that's not because I already have 5 containers up and running. Same with clean install...
RAM level during the process remains 280+
LikeMyFloydPink
Sat Jul 15, 2023 9:40 am
Disregard.
Users browsing this forum: No registered users and 0 guests
