cyb3erg
Routing devices/sources through wireguard vpn V7.8
Thu May 04, 2023 12:22 am
Hello, maybe there is someone who can help.. :)
In the past I have used a L2TP client to establish a vpn connection to the L2TP server and routed all traffic through that vpn. Now I want to use wireguard and route specific devices/sources through the vpn. Since (I think) RouterOS v7.x there are routing tables so my old setup does not work anymore and I can't figure it out with routing tables.
Setup:
- I have the default clean mikrotik setup with DHCP on 192.168.88.10-192.168.88.254 etc..
- I have successfully setup the wireguard peer to connect to the wireguard server.. it's called "vpn-wg" in the interfaces
Goal:
- route all wireless devices through the "vpn-wg" (called "wifi1" and "wifi2" in interfaces)
- route "ether2" through the "vpn-wg"
- the devices should also use DNS through the vpn-wg.. it should "completely" look like that the devices are at the location of the wireguard server
- when the "vpn-wg" is not available/connected.. the devices shall not have internet through ether1/wan at client-side
- using as less config as possible =)
Thanks in advance.
Users browsing this forum: Bing [Bot], carcuevas, deadmaus911, neskiask and 110 guests
