jhony
hEX-S HELP: pppoe (using SFP) seems connected but no internet access  [SOLVED]
Thu May 04, 2023 1:54 pm
Hi All!
Need your help with first connection to hEX-S
I just got my new hEX-S. I kept the default configurations, and only changed the WAN to use SFP1 port (instead of Ether1), changed the default DCHP, and configured the pppoe user/pass connection from my ISP.
In WinBox I see that the pppoe is connected, but there is no internet access on Ether2 port.
What did I miss doing???
Here are the exported configuration:
# jan/02/1970 02:25:47 by RouterOS 6.48.6
# software id = ZBI2-PFFY
# model = RB760iGS
# serial number = HE808NV4JJN
add admin-mac=48:A9:8A:87:72:D3 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=sfp1 name=pppoe-out1 \
use-peer-dns=yes user=b1000@201947343
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.101.3-192.168.101.199
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf disabled=yes interface=sfp1
add bridge=bridge interface=ether1
add interface=sfp1 list=WAN
add address=192.168.101.1/24 comment=defconf interface=bridge network=\
192.168.101.0
/ip dhcp-client
add interface=sfp1
add address=192.168.101.0/24 comment=defconf gateway=192.168.101.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.101.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
jhony
Re: hEX-S HELP: pppoe (using SFP) seems connected but no internet access
Thu May 04, 2023 10:13 pm
Update -
I removed the sfp1 interface from wan list.
But still not working.
Please need your help
anav
Fri May 05, 2023 12:24 am
Remove this, your IP DHCP client is already done via pppoe.........
/ip dhcp-client
add interface=sfp1
jhony
Fri May 05, 2023 9:26 am
Tried to remove it, but now I see that the pppoe cannot connect.
The PPPoE status is disconnected or stuck on connecting....
Maybe I do need the dhcp client?
Any other suggestions please
Thanks again!
jhony
Fri May 05, 2023 9:27 am
The SFP led on the hex is off...
jhony
Fri May 05, 2023 11:22 am
Should I revert it?
anav
Fri May 05, 2023 2:58 pm
From what you have posted it should work. The ppoe is your client.
Perhaps you have the wrong pppoe username and password etc or it needs a vlan as well.........?????
jhony
Fri May 05, 2023 7:57 pm
Yes! That was it!
The username I received from the ISP was wrong!
Thank you very much!!
Users browsing this forum: 4l4R1, raiser and 19 guests
