Hi. I have an AC3 v7.9 (192.168.1.2) with a cable modem/router (192.168.1.1) connected to ether1 interface and cellular on LTE1 interface.
It's strange but pinging from bridge interface, or no interface specified, works but pinging from ether1 does not work. Ether1 is connected to a cable modem router that has its DHCP turned off (I'm not network smart enough to configure it in bridge mode) but ether1 interface is successfully passing traffic thru to WAN b/c the speed test is showing gig speed which LTE is much slower.
I've disabled the firewall rules, restarted and still no luck.
Bridge:
ping 8.8.8.8 interface=bridge count=3
SEQ HOST SIZE TTL TIME STATUS
0 8.8.8.8 56 57 15ms229us
1 8.8.8.8 56 57 15ms771us
2 8.8.8.8 56 57 19ms600us
sent=3 received=3 packet-loss=0% min-rtt=15ms229us avg-rtt=16ms866us max-rtt=19ms600us
No interface:
ping 8.8.8.8 count=3
0 8.8.8.8 56 57 14ms921us
1 8.8.8.8 56 57 18ms659us
2 8.8.8.8 56 57 17ms418us
sent=3 received=3 packet-loss=0% min-rtt=14ms921us avg-rtt=16ms999us max-rtt=18ms659us
LTE:
ping 8.8.8.8 interface=lte1 count=3
0 8.8.8.8 56 112 206ms971us
1 8.8.8.8 56 112 26ms609us
2 8.8.8.8 56 112 27ms872us
sent=3 received=3 packet-loss=0% min-rtt=26ms609us avg-rtt=87ms150us max-rtt=206ms971us
PROBLEM...Ether1:
ping 8.8.8.8 interface=ether1 count=3
0 8.8.8.8 timeout
1 192.168.1.2 84 64 341ms707us host unreachable
CONFIGURATION:
# may/04/2023 09:22:55 by RouterOS 7.9
# software id = KQH9-SBIK
# model = RBD53GR-5HacD2HnD
# serial number = DC900D2432BE
add admin-mac=xx:xx:xx...:xx auto-mac=no comment=defconf name=bridge
add name=bridge2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country="united states" distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=MikroTik-6E8028 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country="united states" distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTik-6E8029 \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] use-peer-dns=no
add apn=broadband default-route-distance=10 use-network-apn=yes use-peer-dns=\
no
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=broadband band=\
/ip hotspot profile
add name=dhcp ranges=192.168.1.1-192.168.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=WAN
add bridge=bridge interface=LAN
add comment=defconf interface=lte1 list=WAN
add interface=ether1 list=WAN
add address=192.168.1.1 client-id=1:xxxxxxx comment="NETGEAR CAX80" \
mac-address=xxxxxx server=defconf
add address=192.0.0.0/8 comment=defconf dns-server=192.168.1.2 gateway=\
192.168.1.2 netmask=8
set allow-remote-requests=yes servers=9.9.9.9,1.1.1.1
/ip dns static
add address=192.168.1.2 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
invalid in-interface-list=WAN
add action=accept chain=input dst-address=!192.168.1.1
add check-gateway=ping comment=NETGEAR_XFINITY disabled=no distance=1 \
dst-address=0.0.0.0/0 gateway=192.168.1.1 pref-src="" routing-table=main \
scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=MIKROTIK_NETGEAR disabled=no distance=1 \
dst-address=128.0.0.1/32 gateway=ether1 pref-src="" routing-table=main \
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
connection-state=invalid
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Chicago
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool e-mail
set address=smtp.gmail.com from=pipnee@gmail.com port=587 user=pipnee
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add comment=CheckCon disabled=yes down-script="\r\
\n:log info \"Netwatch Initial Test: Xfinity Down\"\r\
\n:if ([/ping 8.8.8.8 interface=ether1 count=10] =0) do={\r\
\n:log info \"XFINITY Netwatch down\"\r\
\n/ip route set [find comment=\"MIKROTIK_NETGEAR\"] distance=111\r\
\n/ip route set [find comment=\"NETGEAR_XFINITY\"] distance=111\r\
\n/tool e-mail send to=\"8324449009@txt.att.net\" subject=\"XFINITY Down\"\
\_body=\"DOWN\" tls=starttls\r\
\n} else={\r\
\n:log info \"Tested: XFINITY Down.\"\r\
\n}\r\
\n" host=8.8.8.8 http-codes="" interval=5s test-script="" timeout=2s \
type=simple up-script="\r\
\n:local i\r\
\n:log info \"Netwatch Initial Test: Xfinity Up\"\r\
\n:do {\r\
\n:set \$i [/ping 8.8.8.8 interface=ether1 count=50]\r\
\n:log info \"Test: XFINITY Ping\"\r\
\n} while=(\$i != 50);\r\
\n:if (\$i = 50) do={\r\
\n:log info \"XFINITY Netwatch up.\"\r\
\n/ip route set [find comment=\"MIKROTIK_NETGEAR\"] distance=1\r\
\n/ip route set [find comment=\"NETGEAR_XFINITY\"] distance=1\r\
\n/tool e-mail send to=\"8324449009@txt.att.net\" subject=\"XFINITY UP\" b\
ody=\"UP\" tls=starttls\r\
\n} else={\r\
\n:log info \"Tested: XFINITY Up\"\r\
\n}"
/tool sniffer
set filter-interface=ether1
