antelma
eoip l2 cpu utilization
Thu May 04, 2023 6:02 pm
Hello, I have a problem with a layer 2 connection between two offices, I'm simulating everything in the laboratory using two 1Gb uplinks, I have set up an eoip tunnel between the two routers and created a bridge with the eoip and the interface inside ethernet connected to the switch, everything works but doing a data transfer I arrive at about 870Mb/s, I see that the problem is the cpu which reaches 100%. I first tried with two RB4011s and also with two CCR2004s. I see that only one is used, the others all remain around 0% usage. Do you have any idea how to optimize the connection? I tried both with ROS 6.xx and 7.xx versions without significant differences.
Thank You
Lino
Users browsing this forum: Bing [Bot], jh1, nagylzs, pe1chl, regisc, stef70, tim427 and 140 guests
