timo182
Set port mapping(-p) for new container
Thu May 04, 2023 7:15 pm
Hi, just can't understand how to set up container to use port mapping like this -p 8080:8080
Does somebody know how to set it?
own3r1138
Long time Member
Long time Member
Re: Set port mapping(-p) for new container
Thu May 04, 2023 7:21 pm
timo182
Thu May 04, 2023 7:29 pm
No, I mean how to configure both "side", not only external but mainly internal to container
For example this container required to pass -p 8080:8080 during run procedures, but I can't understand how to achieve it in routeros
https://hub.docker.com/r/flcontainers/guacamole
own3r1138
Long time Member
Long time Member
Thu May 04, 2023 7:36 pm
Internal? Elaborate, please.
The host is your ROS. So you should add a rule to dst-nat your public-ip:8080 to your veth-ip.
Parameters
-p 8080:8080 - Binds the service to port 8080 on the Docker host, required
timo182
Thu May 04, 2023 8:28 pm
I mean container just not expose 8080 port to outside if I don't specify -p 8080:8080 during run procedure( :8080 part)
I was trying to go to container shell and there simply no service that listen on 8080 port
Looks like I need to find out another container image or reconfigure this one to expose 8080 port regardless of whether this parameter was passed at startup or not
Users browsing this forum: No registered users and 4 guests
