darknight898989
Configuring PPPOE over VLAN  [SOLVED]
Sat May 06, 2023 1:39 am
I'm coming from pfsense. This is my first time with a mikrotik product. I have an ISP that requires PPOE over VLAN.
I have VLAN ID and credentials to access it provided by my ISP.
My ISP provides me with ethernet and it is connected to port 1 of my HEX S.
I started with default config, I then added a VLAN on ether1 and a ppoe connection on the newly created VLAN interface.
No connection at this point. On a forum and some people suggested i should add the ppoe connection to wan list (interface-> interface list -->WAN changed from ether1 to ppoe). So i did.
If i go to ip -> routes, i see this:
I censored my ip and src but ppoe seems to work.
I then also checked and i can ping 1.1.1.1
But I have no connection through the Lan bridge. Any suggestions?
EDIT:
I uploaded the new release and installed it, then reconfigured and it works now, i think there were some bugs in the preinstalled version, i cannot explain it otherwise...
To configure it:
https://wiki.mikrotik.com/wiki/Manual:U ... g_RouterOS Install mikrotik latest release
Set ISP VLAN on ether 1
Set pppoe_out1 on ISP VLAN
Add pppoe_out1 to interface list "WAN"
Users browsing this forum: Amazon [Bot], araqiel, LookUp, saahil and 41 guests
