dazmatic
RBM11G NL952 Modem, passthrough and admin access
Sat May 06, 2023 9:49 am
Hi all.
Hoping one of you lovely people might be able to assist with an issue I'm facing.
I have LTE internet, currently served by a VN007+ router in passthrough mode in an IP rated enclosure outside hooked up to a pair of parabolics.
I'm upgrading from that router because it doesn't aggregate all the band's I need and so purchased an RBM11G and NL952 modem (also got RM500Q) but I've only got a single ethernet cable going to the box outside.
Obviously, I need to keep the passthrough mode as my provider serves me a public IP (no cgnat) but would also like to retain access to the admin interface.
I know the modem can do passthrough, I've tested it straight through to the ethernet port and it was fine.
I've tried various methods, including VLAN APN to ethernet, VLAN APN to bridge and port to ethernet, VLAN APN to ethernet 2 ports and bridge the ports.
Nothing has worked to get passthrough and access to interface on the same ethernet port. I'm really struggling now, I've read every piece of material I can find online but most are specific to other routers or specific Mikrotik modem/routers.
Any pointers would really help
TIA
dazmatic
Re: RBM11G NL952 Modem, passthrough and admin access
Sun May 07, 2023 2:25 am
Got it
add admin-mac=00:11:22:33:44:55 auto-mac=no name=bridge1
/interface lte
set [ find default-name=lte1 ] allow-roaming=no
/interface vlan
add interface=bridge1 name=vlan1 vlan-id=1
add interface=bridge1 name=vlan2int vlan-id=2
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] apn=3internet passthrough-interface=vlan2int \
    passthrough-mac=auto use-network-apn=no
/ip hotspot profile
/port
set 0 name=serial0
add interface=lte1 list=WAN
add interface=ether1 list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
    192.168.88.0
add address=192.168.5.1 interface=bridge1 network=192.168.5.1
/system clock
set time-zone-name=Europe/London
Users browsing this forum: No registered users and 45 guests
