Anyone6643
High CPU usage on one core in PPPoE concentrator
Sat May 06, 2023 5:19 pm
Hello everyone,
I am facing an issue with one of the cores of my Mikrotik router which is running at 100% CPU usage while the other cores are free. Even when I use fasttrack, it alleviates the problem but the CPU usage still remains elevated.
This router is being used as a PPPoE concentrator with an average of 600 sessions and a traffic rate of 1.4Gbit/s. It is virtualized on a KVM server with a host machine of 48x Intel(R) Xeon(R) CPU E5-2670 v3 @ 2.30GHz and 47GiB RAM. The Mikrotik virtual machine is allocated 10GiB RAM and 32 cores.
Despite having a high-end configuration, the CPU usage remains high only on one core. I have attached some screenshots that might help in identifying the issue.
Can anyone suggest any solution to this problem? Any help would be greatly appreciated.
Thank you.
RajaMani
Re: High CPU usage on one core in PPPoE concentrator
Sat May 13, 2023 5:11 pm
i am also facing the same issue on RB4011. But still unable to got any solution :(
Anyone6643
Mon May 15, 2023 8:44 pm
I see. I tried almost everything but, nothing can solve this.
loloski
Tue May 23, 2023 7:14 am
You can try vyos or accel-ppp if you are having problems with Mikrotik PPPoE implementation, PPPoE is single thread in linux and among bsd
dineshplp
Mon Aug 28, 2023 1:36 pm
I am using version 7.10 on a proxmox host with 18 CPUs. It's doing almost 1 gig of traffic and I don't see issues as yours. CPU sits close to 30 percent and 450 PPPoE sessions.
Using host CPU in the CHR and intel 10G card. Using PCI passthrough for NIC.
Users browsing this forum: No registered users and 16 guests
