aldo142
DDOS attack need help
Sun May 07, 2023 4:12 pm
hello i have many ddos attacks who can help to configure my mikrotik to stop that ? thx
rextended
Re: DDOS attack need help
Sun May 07, 2023 4:22 pm
@anav is waiting your reply from 2022
viewtopic.php?p=908859#p908941
Would you like help without even thanking or replying?
Ask your ISP, you can not do anything useful for stop DDoS, except close all your open services to the world, that cause the attacks.
aldo142
Sun May 07, 2023 4:26 pm
hello its long story its very important for to let at least 1 opened port can u help me ?
rextended
Sun May 07, 2023 4:27 pm
I already gave you the correct answer.
aldo142
Sun May 07, 2023 4:33 pm
can i see u in private im really confused and this ddos attack will make me heart attack soon :(
rextended
Sun May 07, 2023 4:38 pm
Isn't it clear to you that only and exclusively your ISP can do something?
Whatever you do, however, is completely useless.
(Aside from shutting down all internet services you provide, which attract attacks)
AntiUltimate
Sun May 07, 2023 4:42 pm
What are the symptoms of the so called "DDoS attack" and how did you realize it was one?
aldo142
Sun May 07, 2023 4:44 pm
i have a application on linux server who use 1 port one guy send me a flood attack when i start using it after only 5..10 mins the router crash
rextended
Sun May 07, 2023 4:49 pm
Is not exactly the same thing....
If you don't explain yourself well, how do you expect to have correct help?
One person flood your connection. This is "many DDoS attacks"?
Drop on /firewall raw prerouting his IP.
aldo142
Sun May 07, 2023 4:58 pm
il newbee on security i buy this mikrotik to secure trafic from my local server to my remote vps ( ovh vps ) in way to let traffic only from a specific ip to specific ip and all all other trafic will be blocked
rextended
Sun May 07, 2023 5:01 pm
aldo142
Sun May 07, 2023 5:29 pm
still confused if we can make a direct contact will be good pls !
rextended
Sun May 07, 2023 5:43 pm
https://mikrotik.com/consultants
anav
Sun May 07, 2023 5:55 pm
1. Provide a detailed network diagram
2. Post complete config
/export file=anynameyouwish {prior to posting here, remove router serial#, public WANIP information and any keys}
@rextended, whenever you post make habit of checking mail :-)
chechito
Sun May 07, 2023 7:01 pm
looks like was not so urgent after all
aldo142
Sun May 07, 2023 7:14 pm
1- network diagram
ubuntu server with cccam server with 1 port opened 9011 the local network conect to vps
this attached config , what i want is to close all incoming trafic and all outgoing trafic only will use 9011 to conect to specific vps ip
# may/07/2023 17:09:37 by RouterOS 7.2
# software id = N19D-NGAV
# model = RouterBOARD 750G r3
# serial number =
add admin-mac=64:D1:54:A0:C8:01 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    use-peer-dns=yes user=GUA24328442
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
    192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment="serveur cccam11" dst-port=9011 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.88.251
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Africa/Algiers
/tool mac-server
/tool mac-server mac-winbox
Reason: Use proper tags: quote to quote, code for code - keep forum tidy
aldo142
Sun May 07, 2023 7:32 pm
the first aproch is to close all all incoming trafic and all outgoing trafic then i will open and manage desired port
Larsa
Sun May 07, 2023 7:50 pm
Unfortunately, Mikrotik ROS has no ability to stop DDOS attacks. If it's important, you simply have to supplement or replace it with another solution. However, for other common questions regarding firewall settings, you might get good help from folks in this thread.
For tips and suggestions regarding DDOS protection, Google for example "firewalls that protects against ddos attacks".
aldo142
Sun May 07, 2023 8:59 pm
u can see attached the SYN flood
chechito
Sun May 07, 2023 9:04 pm
if 154.54.220.138 traffic is not relevant or important to you drop it
/ip firewall raw
add action=drop chain=prerouting src-address=154.54.220.138
lowering tcp timeout can help
set tcp-established-timeout=16m
aldo142
Sun May 07, 2023 10:15 pm
154.54.220.138 PORT 9011 is important can i make in white list and drop all other traffic throw 9011 from another ip's ?
anav
Mon May 08, 2023 12:12 am
Does everyone understand now why I want zerotrust cloudflare as an options package for devices, (not even part of stock RoS like wireguard).
No need to expose public IP and worry about this sheite.
HEY MICROTIK WAKE UP!!!
mkx
Mon May 08, 2023 12:16 am
Well, if my link partner started to SYN flood me, I'd block it anyways ... and tgen I'd have a serious talk with admin of link partner. The thing is: if link partner runs software, which can use random source port, what exactly prevents that software to hijack the all important port?
aldo142
Mon May 08, 2023 1:36 am
u are right but now i must found solution because its not easy to block him with only a simple call !! so i need help
rextended
Mon May 08, 2023 2:16 am
But you can know what the hell are you writing?
Want to stop the synflood of a moron you know but at the same time have to allow him to continue?
For me you're making fun of us all or you're stoned.
aldo142
Mon May 08, 2023 2:38 am
i think u dont understand what i mean !! its sure i need stop this sys flood throw mikrotik if there is other solution tel me !
aldo142
Mon May 08, 2023 2:41 am
lets block the attack then i will try to have a serious talk with her isp or vps reseler
Larsa
Mon May 08, 2023 9:29 am
Please don't count on it too much as an ISP normally has non at all or very limited ability to protect you from DDOS attacks. To make a real difference you probably need to take other measures like cloudflare and similar solutions.
Meanwhile and to mitigate the whole thing as a temporary solution you might put the attackers in a block list. Anav and Extended can show you how.
mkx
Mon May 08, 2023 11:04 am
@chechito in post #20 above already showed you how to drop all traffic from the "criminal" ...
anav
Mon May 08, 2023 2:20 pm
Add a source address list to the port forwarding rule.
All users need to provide you with their static public IP
OR
All users need to provide you with their DYNDNS URL and the MT will resolve it.
This will at least reduce visibility and access to those allowed. I have no clue what anybody means by link partner.
In terms of eliminating or cutting out the problem, I believe the Columbian knows of what he speaks.
optio
Long time Member
Long time Member
Tue May 09, 2023 9:36 pm
@aldo142
You can setup IP firewall with SYN/DoS/DDoS protection by following this guide: https://help.mikrotik.com/docs/pages/vi ... d=28606504.
This works against non spoofed/randomized source IP addresses, I have similar setup, BUT when attacker uses random source IP addresses in packet it will fill your blocked IP's address list and it will eventually result out of memory on ROS (this means DoS is still present for ROS). For this purpose it will be better to have MAC address lists in ROS (which ROS don't have), blocking by MAC address will be more effective for these kind of attacks.
You can test attack with hping3, eg:
Non randomized source IP flood:
~ root# hping3 -c 15000 -d 120 -S -w 64 -p <TCP_PORT> --flood <ROUTER_IP>
Randomized source IP flood:
~ root# hping3 -c 15000 -d 120 -S -w 64 -p <TCP_PORT> --flood --rand-source <ROUTER_IP>
Larsa
Tue May 09, 2023 9:58 pm
A nice thought, but the MAC address will unfortunately not travel along with the attacker's IP packets. In other words, you will more or less only see MAC addresses of your ISP's default gateways. Botnet attacks that utilize their full power generally only target high-priority prey, thus a regular blocklist is sufficient for the normal consumer and will not crash RoS if it becomes full.
FWIW, intrusion to gather classified/important information are far more common when targeting POI working at home.
optio
Long time Member
Long time Member
Tue May 09, 2023 10:01 pm
Thus, a blocklist is sufficient for the normal consumer and will not crash the RoS if it becomes full.
There is a limit for address list size in ROS?
Larsa
Tue May 09, 2023 10:04 pm
Yes, storage and ram may impose a limit depending on your model.
optio
Long time Member
Long time Member
Tue May 09, 2023 10:11 pm
Good to know, I guess I have enough RAM on my device, when I tested this with random IP, I had hundreds of IP's in list, didn't crash but I had to reboot to clean that up...
EDIT: I remember now which list caused out of memory crash while ago - DNS server static entries, I had huge list generated by some script... I was by mistake thought it was address lists, that's why I mentioned it as potential DoS attack vector against ROS.
Larsa
Tue May 09, 2023 10:20 pm
I've used several hundreds of thousands without problems. However, it may take some time to load and delete them thus that amount of entries might be better suited in a dedicated firewall for that particular purpose.
anav
Tue May 09, 2023 11:12 pm
All avoidable if we do not have to expose public IPs..................... drumrollllllllllll ................ zerotrust cloudflare tunnel as an options package for all devices.
Larsa
Tue May 09, 2023 11:22 pm
Yeah, such a solution would fit perfectly in this case!
anav
Tue May 09, 2023 11:31 pm
In most every case where a home user has servers of one ilk or another!
anovojr
Tue Apr 23, 2024 3:13 pm
Are you sure you're having DDoS attacks?
Users browsing this forum: CGGXANNX, duquesnoyinfo, jaclaz, miker3000, trmns, zalciukaz and 128 guests
