tiran
Install basic opensource firewall as docker container for control my whole LAN
Sun May 07, 2023 5:28 pm
I am looking for solution to control my branch LAN devices by basic open source firewall. I use RB450G4 devices for branch core router. is that possible to install a basic firewall in the RB450G4 as a docker container
rextended
Re: Install basic opensource firewall as docker container for control my whole LAN
Sun May 07, 2023 5:41 pm
An absurd request...
There is already the firewall in the same device where you would install the container, what would be the logic in wanting another add-on?
BartoszP
Sun May 07, 2023 9:31 pm
@Tiran
Could you explain your plans for simpler firewal embeded in a firewall?
Is it Inception-like proof of concept project?
tiran
Mon May 08, 2023 9:04 am
As a service partner we install and provide connection to customers. we use RB450G4 as the main router and VPN. we do not provide login access to RB450 router for end clients. but if we can install firewall on docker we can give access to responsible person to manage their firewall.
Larsa
Forum Veteran
Forum Veteran
Mon May 08, 2023 10:39 am
It depends of what type of firewall solutions you are looking for thus how it will effect performance, memory and storage usage.
It we are talking about more sophisticated firewall solutions with IDS, DDOS-proection, etc I personly think it would suite better with a separate box on the side. This also gives you the ability to install and operate sophisticated solutions if your custmors customers requres it without risking disruption of normal communications, IMHO.
normis
Mon May 08, 2023 11:04 am
The idea is nice, but like others said, if we are talking about home users - most likely the device they use will not have enough resources to run a firewall container on top of RouterOS. Containers usually take quite a bit of CPU/RAM
tiran
Allow some webs and block all others
Wed Jun 07, 2023 1:46 pm
assume I have router RB450 as a gateway router of my LAN. I have added masquerade for LAN Internet from my RB450. it is working fine. but now I want to allow outlook mail, any desk, TeamViewer, Microsoft teams and some important services and block all other sites. how can i do it
optio
Re: Allow some webs and block all others
Wed Jun 07, 2023 6:36 pm
Not a simple task on ROS, when I worked on my mangle rules to add connection marks to some services connection for prioritization in Queues, I had to investigate which ports are using, eg. for MS Teams https://answers.microsoft.com/en-us/mst ... c810bc7a87, and I identified that service by application src port range, but if used in browser for web app is not the same, I use only app so I did not bother to seek solution for web Teams.
For others you mentioned, depends on service, some combination of dst port and dst ip range or src ports like Teams.
I think when you are blocking like that, It is always best to include dst ip in combination with ports (either is dst or src), because someone can create connection with allowed src port and avoid block if dst ip is not always checked.
tiran
Sat Jun 10, 2023 3:43 pm
@rextended
Can you explain how can I do with existing firewall
rextended
Sat Jun 10, 2023 4:59 pm
@rextended
The answer I gave you, in post #2 is perfectly adequate to what you did NOT write in your opening post.
Users browsing this forum: No registered users and 1 guest
