Hi I have a situation where I need to have 2 ports on separate networks but want a VlAN for each network that would go to the unifi AP as I want SSIDs for those networks,
Example
port 2 192.168.1.1/24 main lan with trunk port for vlans and unifi AP
port 3 192.168.10.1/24 and a vlan that goes to the ssid 3 (example vlan 10)
port 4 192.168.11.1/24 and a vlan that goes to the ssid 2 (example vlan 11)
Any help on how to do this? or a better plan ?as I might be going about this wrong? I tried to put the ports 3 and 4 on a VLAN while trunking to port 2 for the AP but couldn't do it in ROS.
Thanks A LOT for any ideas
Regards
btw any idea why in the switch menu I do not have VLAN tab?
