autonomous
Unable to sniff traffic on bridge
Sun May 07, 2023 10:40 pm
I recently purchased a Hex S (RB760iGS / MT7621A) to replace a configuration I was running inside of a VM, and am having some problems.
I bridge two ports together as a transparent filtering bridge between my modem and my (non-microtik) router. On my virtual machine instance I am able to see the traffic flowing in torch as well as observe this traffic be using Traffic Flow feature to send IPFIX flows to my netflow receiver. :-D However on my Hex S, I cannot see traffic on the bridge using torch, nor can Traffic Flow see any traffic on that interface. :(
[admin@RouterOS] /interface/bridge/settings> print
              use-ip-firewall: yes
     use-ip-firewall-for-vlan: no
    use-ip-firewall-for-pppoe: no
              allow-fast-path: no
      bridge-fast-path-active: no
     bridge-fast-path-packets: 0
       bridge-fast-path-bytes: 0
  bridge-fast-forward-packets: 0
    bridge-fast-forward-bytes: 0
[admin@RouterOS] /interface/bridge> print detail
 0 R ;;; wan bridge
     name="br-wan" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=48:A9:8A:72:1B:7D protocol-mode=rstp fast-forward=no igmp-snooping=no auto-mac=no admin-mac=48:A9:8A:72:1B:7D ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6
     vlan-filtering=no dhcp-snooping=no
[admin@RouterOS] /interface/bridge> port/print detail
Flags: X - disabled, I - inactive; D - dynamic; H - hw-offload
 0     ;;; SWITCH
       interface=ether3 bridge=br-wan priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=no auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
       unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query fast-leave=no
 1     ;;; MODEM
       interface=ether4 bridge=br-wan priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=no auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
Is there something different about the Hex S hardware that makes this impossible?
Users browsing this forum: Ahrefs [Bot], Bing [Bot], giovanniv and 84 guests
