mikrotikcechiscz
Routing traffic from wlan to lan ports using VLANs
Mon May 08, 2023 1:43 am
Hello fellow users, I've run into a wall after 2 days of refactoring my network.
For simplicity, my network as as follows:
Now I have internet access from all, the issue is accessing between wlan interface and Access interfaces of the same VLAN on the CRS109. However wlan <-> Trunk/hybrid and Access <-> Trunk/hybrid goes through
To sum up:
PC1 can ping PC2, PC3 and PC4
PC2 can ping PC1 only
PC3 can ping PC1 and PC4
PC4 can ping PC1 and PC4
My guess is the issue is with the HW switch. I configured the VLANs using the switch chip and tagged the wlan_home with PVID19 thinking that might be enough. Though I wasn't able to fix it by removing vlans from the switch and configuring them on the bridge. I'm hoping someone could enlighten me whether the current setup is impossible to fix due to the constrains between the hw switching and wlans or maybe see an error in the configuration
Thanks a lot in advance!
export-2023-05-08.rsc
Users browsing this forum: Adrijan, astelsrl, CGGXANNX, h3x00r, mada3k, syahmi5650 and 96 guests
