DoubleDB
Script - get item numbers
Tue May 09, 2023 5:17 pm
Hey guys,
I'd like to create a comma-separated string containing the actual ***numbers*** of each elements (not the *An's) so I can then call /user-manager/user generate-voucher numbers=<the generated list of IDs> . . . .
numbers_list "";
foreach i in=[/user-manager/user/find where disabled=no] do={
xxx
How to get/convert the *A5 / *Awhatever to the actual numbers shown in /user-manager/user print detail where disabled=no ???!
I've tried everything I could think of - I can either print *A5 *A23978382459348, or - nothing at all.
Regards,
D
pe1chl
Re: Script - get item numbers
Tue May 09, 2023 5:49 pm
Item numbers are only valid in the user interface, not in scripts. The numbers are generated when a "print" command is used and are only valid for that login session.
To refer to items in scripts you always need to use [find ...], not item numbers.
rextended
Tue May 09, 2023 6:03 pm
/user-manager user generate-voucher [find where disabled=no]
DoubleDB
Tue May 09, 2023 6:23 pm
So, how do I pass the [find] to generate-vouchers for only the active items?
***edt - thanks for the above post.
Users browsing this forum: No registered users and 62 guests
