Newbienoob
Buying CHR Licence - No Luck
Wed May 10, 2023 12:31 am
Hello to all,
I would like to buy an AWS CHR Licence in order to remove the 1Mbit Shaper,
Found and tried to follow the wiki regarding this. https://help.mikrotik.com/docs/display/ ... idlicenses'
I am guessing that my account on the forum is not considered a Mikrotik Account.
Tried to register but it says I am already registered.
Tried to log in to MT with my forum credentials (https://mikrotik.com/client/) but no luck.
Tried to reset the password but I never receive the recover your password email either.
Any ideas? Is this common?
mkx
Re: Buying CHR Licence - No Luck
Wed May 10, 2023 8:55 am
I suggest you to contact Mikrotik support via e-mail at support@mikrotik.com
This forum is user forum, while MT staff do read (and answer) some threads, their feedback here is not guaranteed.
normis
Re: Buying CHR Licence - No Luck  [SOLVED]
Wed May 10, 2023 10:54 am
It means this email is used. Request a password with that same email.
Login - Email.
Forum login will not work .
Newbienoob
Wed May 10, 2023 9:55 pm
Login - Email.
Thank you very much for the quick reply.
Unfortunately, when i try to reset the password, i never get that email for the reset link.
Maybe, something has happened with my email in the database not sure.
Should I just send support an email about it?
Newbienoob
Wed May 10, 2023 10:05 pm
Hey hey!
I saw normis reply again and it worked.
LOGIN = Email (not username)
Sorry for the inconvenience!
Users browsing this forum: Amazon [Bot], lego11 and 74 guests
