EdPa
v7.10beta [testing] is released!
Wed May 10, 2023 11:23 am
RouterOS version 7.10beta has been released on the "v7 testing" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.10beta8 (2023-May-22 18:52):
!) ipv6 - fixed DNS server processing by IPv6/ND services (CVE-2023-32154);
!) route - added BFD (CLI only);
*) bgp - allow to filter BGP sessions by AFI;
*) bgp - changed default VPNv4 import distance to iBGP value (200);
*) bgp - do not check route distinguisher on import;
*) bgp - fixed "as-override" and rename to "output.as-override";
*) bgp - fixed "remove-private-as" and rename to "output.remove-private.as";
*) bgp - show address family in advertisements;
*) bgp - show approximate received prefix count by the session;
*) branding - fixed custom logo (introduced in v7.8 );
*) conntrack - added read-only "active-ipv4" and "active-ipv6" fields to "/ip/firewall/connection/tracking" (CLI only);
*) console - fixed "print without-paging" output in some cases;
*) defconf - allow to use device factory preset credentials in Flashfig and Netinstall configuration files;
*) dhcpv4-server - added name for "IPv6-Only Preferred" option (108) in debug logs;
*) doh - less verbose logging;
*) ipsec - added hardware acceleration support for IPQ-5010 (hAP ax lite);
*) ipsec - removed "ec2n185" and "ec2n155" values from proposal configurations;
*) l3hw - added "autorestart" option to L3HW settings;
*) l3hw - added error message and reset "l3-hw-offloading=no" if L3HW driver fails to start;
*) l3hw - fixed offloading of /32 IPv4 and /128 IPv6 routes;
*) l3hw - improved offloading of IPv6 hosts after L3HW driver restart;
*) l3hw - improved performance of partial offloading;
*) l3hw - improved route offloading after gateway change;
*) lora - improved gateway card detection and upgrade logic;
*) lora - updated firmware version for LoRaWAN gateway (for R11e-LoRa8, R11e-LoRa9 cards);
*) lte - fixed APN authentication for R11e-LTE6 modem;
*) lte - improved MBIM modem firmware reported error handling when settings RAT modes;
*) lte - improved modem firmware upgrade stability for MBIM modems;
*) lte - reduced SIM slot switchover time for MBIM modems with UUIC reset support;
*) netwatch - added warning about non-running probe due to "startup-delay" (CLI only);
*) poe - fixed bogous "poe-in-voltage" values when using DC jack for RB5009;
*) qos-hw - renamed VLAN "priority" field to "pcp" to avoid confusion;
*) rose-storage - added support for multiple smb users and smb shares;
*) routerboot - increased "preboot-etherboot" maximum value to 30 seconds ("/system routerboard upgrade" required);
*) scheduler - fixed incorrectly started scheduler during reboot or shutdown;
*) sfp - fixed combo-sfp linking at 1G rate for CRS312 switch;
*) sfp - improved module compatibility with bad EEPROM data for RB4011, RB5009, CCR2xxx, CRS312 and CRS518 devices;
*) sniffer - fixed large .pcap file limit;
*) snmp - added BGP peer table support IPv4 only (1.3.6.1.2.1.15.3.1);
*) tr069 - added 5G SCC "SNR" parameter for modems that report it;
*) vrrp - added warning if "sync-connection-tracking=yes" while the global connection tracking is inactive;
*) vrrp - added warning if the VRRP group is misconfigured;
*) vrrp - added warning if VRRP or its interface does not have an IP address;
*) vrrp - do not start connection synchronization if the global connection tracking is inactive;
*) vrrp - fixed issue where disabled VRRP interface is affecting group;
*) vrrp - fixed VRRP interface state on physical cable disconnection;
*) vrrp - improved system stability on changing "group-authority" or "sync-connection-tracking";
*) vrrp - renamed "group-master" to "group-authority" to avoid confusion with VRRP master;
*) vrrp - send VRRP announcements only by "group-authority";
*) wifiwave2 - do not include in radio hardware capability list a parameter irrelevant to end users (introduced in 7.10beta5);
*) wifiwave2 - fixed CAP interface name when using "name-format";
*) wifiwave2 - fixed connectivity issues wheen access-list is used;
*) wifiwave2 - fixed wireless throughput issues after 802.11r client roaming events on 802.11ac devices;
*) wifiwave2 - improve protections against DoS attacks on WPA3-PSK;
*) wifiwave2 - less verbose logging when WPA3-PSK clients are connecting;
*) wireguard - retry "endpoint-address" DNS query on failed resolve;
What's new in 7.10beta5 (2023-May-09 13:38):
*) bridge - fixed HW offloaded STP state on port disable;
*) bridge - fixed HW offloading for vlan-filtered bridge on devices with multiple switches (introduced in v7.8 );
*) certificate - fixed displaying of certificate serial number;
*) certificate - improved error reporting for Let's Encrypt certificate;
*) certificate - restore available "key-usage" property options;
*) console - added timeout error for configuration export;
*) console - changed time format according to ISO standard;
*) console - disable output when using "as-value" parameter;
*) console - fixed ":terminal inkey" input when resizing terminal;
*) console - hide past commands with sensitive arguments;
*) container - fixed "container pull" to support OCI manifest format;
*) container - fixed crash due to missing system directories;
*) container - improved default internal environment values;
*) defconf - fixed default configuration for RBSXTLTE3-7;
*) dhcp-server - fixed accounting on RADIUS interim update;
*) firewall - added "endpoint-independent-nat" support;
*) firewall - added "nth" option for IPv6 firewall;
*) gps - expose GPS port for Quectel RM520N-GL;
*) ike2 - improved child SA delete request processing;
*) iot - added option to send Modbus function code commands directly from RouterOS (CLI only);
*) ipsec - refactor public key authentication;
*) ipv6 - fixed IPv6 address removal;
*) l3hw - added advanced configuration options for fine-tuning the L3HW offload (l3hw-settings are cleared after upgrade or downgrade) (CLI only);
*) l3hw - added monitoring options for L3HW utilization (CLI only);
*) l3hw - fixed /32 route deletion;
*) l3hw - improved system stability for partial routing table offload;
*) lte - added serving cell query for MBIM modems with necessary MBIM extension;
*) lte - disable DHCP request filtering (UDP port 67) for Chateau 5G;
*) lte - fixed Google Pixel 7 tethering support;
*) lte - improved stability for Chateau 5G LTE modem firmware upgrade;
*) lte - stop "cell-monitor" on LTE interface configuration change for MBIM modems;
*) mpls - added FastPath support;
*) ovpn - added initial support for V2 data transfer protocol;
*) ovpn - improved system stability;
*) pppoe - fixed PPPoE client scan when server is sending PADO messages without Service-Name tag;
*) qos-hw - added QoS marking support for 98DXxxxx switches (CLI only);
*) route - improved system stability when removing multicast forwarding entries;
*) routerboard - fixed memory test on CCR2116-12G-4S+ ("/system routerboard upgrade" required);
*) routerboard - improved RouterBOOT stability for Alpine CPUs ("/system routerboard upgrade" required);
*) sfp - fixed combo-ether link monitor for CRS328-4C-20S-4S+ switch;
*) sfp - improved Q/SFP interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) sfp - improved SFP interface handling for RB4011, RB5009, CCR2xxx and CRS518 devices;
*) sfp - improved system stability with certain SFP modules for CCR2216 and CRS518 devices;
*) sfp - report EEPROM data even if "auto-init-failed" has occurred;
*) smb - improved SMB v1 operation;
*) snmp - added "engine-id-suffix" setting and display actual "engine-id" as read-only property;
*) snmp - added new "mtxrInterfaceStatsTxRx1024ToMax" OID to MIKROTIK-MIB;
*) ssh - added inline key "passphrase" property;
*) switch - added more precise "storm-rate" configuration options for 98DXxxxx switches (CLI only);
*) switch - fixed storm rate on 10G links for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255 switches;
*) system - improved watchdog reporting in log after reboots for several ARM and ARM64 devices;
*) tile - fixed support for microSD card;
*) upgrade - do not run manual upgrade if some packages are missing;
*) ups - fixed updating of "battery-voltage" property;
*) w60g - improved interface stability for PTMP setups;
*) webfig - added high-resolution favicon;
*) webfig - allow limitless upper bounds for number range;
*) webfig - allow to set "0" second time for fields with default values;
*) webfig - changed time format according to ISO standard;
*) webfig - display date and time in local time zone;
*) webfig - fixed missing "WifiWave2" menu;
*) webfig - fixed missing property names in "WifiWave2" menu;
*) webfig - redesigned item configuration display;
*) webfig - redesigned top menu bar;
*) webfig - removed "Tools/Telnet" menu;
*) webfig - removed auto-login with default credentials (admin without a password);
*) wifiwave2 - avoid transmitting extra bytes at the end of the packet after stripping a VLAN tag;
*) wifiwave2 - do not show placeholder transmit power values on interface startup;
*) wifiwave2 - fixed CAP connection when provisioning "manager=capsman";
*) wifiwave2 - fixed DFS channel availability warning (introduced in v7.9);
*) wifiwave2 - fixed dynamic interface adding to bridge on CAP device;
*) wifiwave2 - fixed inability to disable CAPsMAN when there are RADIUS-authenticated clients connected;
*) wifiwave2 - fixed incorrect limits on number of interfaces in station mode;
*) wifiwave2 - fixed interface name change when restoring backup;
*) wifiwave2 - fixed key handshake timeout with re-associating clients;
*) wifiwave2 - fixed OWE authentication compatibility with 802.11ax client devices;
*) wifiwave2 - fixed OWE authentication compatibility with third-party client devices (introduced in v7.8 );
*) wifiwave2 - improved logging when an interface is unable to assign a VLAN tag to client;
*) wifiwave2 - improved system stability when trying to exceed virtual AP limit;
*) wifiwave2 - improved system stability;
*) wifiwave2 - restore interface running state when connection to CAPsMAN is lost;
*) winbox - added "Queues" configuration tab when creating new entries under "IPv6/DHCP-Server" menu;
*) winbox - rename "URL" property to "Action data" under "IP/Web-Proxy/Access" menu;
*) wireguard - fixed IPv6 traffic processing with multiple peers;
*) x86 - ice driver update to v1.11.14;
*) zerotier - make "identity" setting sensitive;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
honzam
Re: v7.10beta [testing] is released!
Wed May 10, 2023 11:33 am
CubeSA upgraded without problems
Rox169
Wed May 10, 2023 11:54 am
I reported this bug. FYI Hikvision cameras should be able to use MT router USB as FTP remote storage for recording or recorging motion.
Thank you Mikrotik :) Now I will have to buy another hap AX3 :)
own3r1138
Long time Member
Long time Member
Wed May 10, 2023 11:56 am
The supout file is available, Ticket #SUP-96432.
DeGlucker
Wed May 10, 2023 12:03 pm
What is ice driver ? I am still waiting for fix for Atheros AR9380 for x86...
volkirik
Wed May 10, 2023 12:05 pm
bug-report:
endpoint-independent-nat:
ether1 (wan port) has one static IP address to reach modem's WEBUI that is in bridge mode: 192.168.0.2/24
ether1 (wan port) has one dynamic IP address to reach internet via DHCPv4 client: 178.233.176.XX/20
if i disable static IP, endpoint-independent-nat works.. otherwise it will route WAN connections back to 192.168.0.2 address
volkirik
Wed May 10, 2023 12:21 pm
bug-report:
connections timeout in 10 seconds, instead of 3 minutes (udp stream timeout)
lyubomirtraykov
Wed May 10, 2023 12:36 pm
I can report that IPSec has integrity check failure with DH Group modp3072 and up in Profile.
Railander
Wed May 10, 2023 12:43 pm
could someone expand on this?
lyubomirtraykov
Wed May 10, 2023 12:48 pm
The WebFig does not save my last used username as in previews versions.
Rox169
Wed May 10, 2023 12:49 pm
raimondsp
viewtopic.php?t=196068
nichky
Wed May 10, 2023 12:50 pm
coddy
Wed May 10, 2023 1:00 pm
Hap-AX3 remote CAPsMAN controlled dynamic VLAN addition to bridge does not work still. I need to manually bridge wifi interfaces to correct vlan, and ensure the upstream ethernet port (trunk port) is marked as not hardware offloaded, to get ithe wifi interfaces to pass traffic.
holvoetn
Wed May 10, 2023 1:43 pm
Smart to add this. Too many reports lately from people with AX devices forgetting an important part during manual upgrade.
rextended
Wed May 10, 2023 1:46 pm
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
FINALLY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ahhhhhhhhhh............. also this...........
anav
Wed May 10, 2023 2:12 pm
Now rextended has no excuses for missing appointments. :-)
rextended
Wed May 10, 2023 2:29 pm
Oh...... welldone!!!!
Another bug fixed...
Clever...
WHEN ALSO ON WINBOX?
msilcher
Wed May 10, 2023 2:31 pm
Bravo!!!
Can someone elaborate on this? I experienced rekey issues to Cisco devices with PFS enabled, I wonder if this might help...
eworm
Wed May 10, 2023 2:37 pm
Oh... 😳 While I welcome this in general... I guess it will break a lot of existing scripts. So watch out...
rextended
Wed May 10, 2023 2:39 pm
@eworm / @all
viewtopic.php?t=196072
Please remove the SHITTY 4-modes from logs:
1) only time is just happened,
2) only day if is the same month
3) only month-day if is the same year
4) full date (year-month-day) only if the log is of another year....
LOG MUST HAVE EVERYTIME FULL DATE...
holvoetn
Wed May 10, 2023 2:42 pm
See (very sensible) comment from msatter in other thread.
viewtopic.php?p=1001179#p1001175
For backwards compatibility, best to leave the old format as it was.
Introduce new variable which can be used moving forward.
Everybody happy.
rextended
Wed May 10, 2023 2:46 pm
anav
Wed May 10, 2023 2:54 pm
For backward compatibility, this approach with new variable is the only way forward. Old stuff will still work. New stuff can use the new format. Everybody happy.
CONCUR Holvoe!
mSATTER brilliance, after silly hats, clogs, dykes, legalized weed and prostitution the dutch provide.......
@EdPa"Something like: [/system clock get isodate]"
rextended
Wed May 10, 2023 2:57 pm
@EdPa "Something like: [/system clock get isodate]"
Sorry, but is better this:
Since the date format is changed also on LOGs, certificates, system scheduler, etc. and WebFig (and on future I hope Winbox)
Better add something like this, that influence all the places where a date can be retrieved [clock / log / certificate, etc.].
/system clock set format=<VALUE>
format can be yyyy-MM-dd or mmm/dd/yyyy, the default is yyyy-MM-dd
leonardogyn
Wed May 10, 2023 2:58 pm
Great one, really enjoyed the new design! Also enjoyed the removal (not listed on the changelogs) of the actual RouterOS version on the webfig login screen.
inline comments are still a thing, and that's not a good one :( Please consider reverting to the old style or, at least, give us the option to choose which one to use! The inline comments really blew up the usage experience, specially when using large comments, on not-huge screens!
mazel
Wed May 10, 2023 3:10 pm
hAP ax2 - issue with wireless clients (not able to connect to WiFi and receive IP address - viewtopic.php?t=195929, viewtopic.php?t=190902, viewtopic.php?t=191304,...) still persists...
holvoetn
Wed May 10, 2023 3:19 pm
Also when you disable WPA3 ?
marsbeetle
Wed May 10, 2023 3:41 pm
Any chance we will get additional wireless interface modes for WifiWave2 anytime soon e.g. ap-bridge ?
radeksima
Wed May 10, 2023 4:52 pm
What´s this meaning? :)
volkirik
Wed May 10, 2023 5:00 pm
hello dear mikrotik team
could you please allow to specify firewall address list in routing->rules?
fasttrack doesnt work due to mark-routing rules, but we can use routing->rules page, if you add ability to specify dynamic address list for a routing rule.
this will be nice speed improvement for VPN tunnels
thanks and regards
volkirik
Wed May 10, 2023 5:08 pm
Unfortunately, it is not possible, linux kernel does not support address lists in route rules.
Māris B.
but you can write kernel module or user-space program to sync address list into route rules and remove them when address-list entry times out
example script: viewtopic.php?p=1001255#p1001255
please MikroTik Team! this is very important!
rpingar
Long time Member
Long time Member
Wed May 10, 2023 5:11 pm
qsfp28 modules issue still persists on CCR2216
modules flap failed to inizialize, failed to get the link on, or some times get the link but disconnect randomly (very weird behavior)
[SUP-115401] updated about supout with 7.10beta5
modules that works on qsfp2-1 doesn't work on qsfp1-1 and vice versa.
massinia
Wed May 10, 2023 5:12 pm
Wireless for me now seems stable.
hAP ax3 7.10beta5 (CAPsMAN)+hAP ax2 7.10beta5 (cAP)+hAP ax2 7.10beta5 (cAP), approximately 25 wireless clients connected.
ToTheCLI
Wed May 10, 2023 5:15 pm
PPPoE Scan in RB5009 works now in 7.10beta5.
Larsa
Wed May 10, 2023 5:29 pm
Nice that the date format issue is finally being addressed even if the initial implementation creates compatibility issues completely unnecessarily IMO. Seriously Mikrotik, please consider a different implementation.
It can easly be solved using my proposal: viewtopic.php?p=1001227#p1001227
Ullinator
Wed May 10, 2023 6:05 pm
For me neither....additionally 7.10Beta5 breaks my AX WLAN completly.
After upgrading my working config from 7.9 stable to 7.10Beta5 the CAPsMAN (CHR without local Wifi interfaces) shows the following error:
and all WLAN´s where unavailable.
Interestingly the 4 radios from the two CAPS were connected ....
rextended
Wed May 10, 2023 6:19 pm
Sorry, my proposal is closer to RouterOS language and is easy manageable instead to add parameters to all points where date can be retrieved.
viewtopic.php?t=196061#p1001195
Amm0
Wed May 10, 2023 6:40 pm
Speaking of datetimes...
/terminal/inkey timeout=time ... is still broken in v7.10beta5
sirbryan
Wed May 10, 2023 6:53 pm
I do like the attempt to clean up/modernize Webfig. I've used Webfig almost exclusively for the past three years because it's 1) universally accessible and 2) I can get to and see all the settings in one place, unlike Winbox, where it takes more effort to see/change information & settings.
Since some of the changes are messing with my muscle-memory and workflow, I'm going to throw out what suggestions I can before things get too cemented into place. (Presuming anybody is listening....)
  • I love the addition of Safe Mode (would have saved me a trip to a site yesterday)
  • Centering the details in the middle of the screen is jarring visually when we've got browser windows open wide to see/monitor the huge amounts of data in the tables and we're generally looking at the left side already (in LTR languages). Also, when quickly moving through settings or information pages (setting up new devices, troubleshooting existing installations, or turning up new BGP sessions), that added distance adds extra mouse travel time (i.e. hand fatigue), as opposed to having the DIV left-aligned.
  • The huge amount of white space (well, gray) below the scrollable DIV in the absence of the OK/Apply/Cancel buttons gives the user the impression that they're at the end of available options. That DIV needs some kind of visual indicators that there's more data/settings hidden behind the invisible block, such as a hairline border around it, or maybe arrows or something.
  • Grouping on the detail page is nice, but adds extra clicks. Perhaps an "expand all" button would be useful here.
  • Comments need to go back above the line they're a part of, or that option should be configurable. I have a lot of multi-word/multi-sentence comments. (They've been multi-line in Winbox forever, why shrink it on the details page and make it harder to see everywhere else?)
  • What is with this trend of removing the software version from the top of the screen? Ubiquiti is doing it too on their radios and I hate having to dig further to determine what release I'm running. I get into dozens of devices per day and am testing a number of software versions across hundreds of devices. That is vital information if I'm either configuring a device, if it needs upgrading, or if I'm troubleshooting known or unknown issues. With Webfig, there's plenty of room where the version used to be. The hostname does not need to take up 75% of the width of my browser window.
Short version of the rant: Please don't hide information that was readily visible before. Or else, make a "pretty" skin and a "utility" skin.
That all said, I'm really excited about everything else in 7.10.
Jotne
Wed May 10, 2023 7:06 pm
And the same for Syslog
RFC 5424 is 14 years old !!!!
Larsa
Wed May 10, 2023 7:40 pm
Sorry, my proposal is closer to RouterOS language and is easy manageable instead to add parameters to all points where date can be retrieved. forum.mikrotik.com/viewtopic.php?t=196061#p1001195
Absolutely not! 😄😘 viewtopic.php?p=1001272#p1001272
anav
Wed May 10, 2023 8:09 pm
Please gato and mouse take your time quibbles to another thread LOL. I think MT gets the picture ...........half baked time solution creates more work then it solves, they need to go back to the drawing board.
mazel
Wed May 10, 2023 8:27 pm
Nope, even disabling WPA3-PSK and Disable PMKID did not help - wlan devices unable to connect and obtain IP from DHCP (using vlans). Still the same issue...
mazel
Wed May 10, 2023 8:30 pm
I dunno but it is still the same for me (seems like SW+HW issue to me). If you could check my config at viewtopic.php?t=195929 I would be really glad if you find something problematic there.
npeca75
Wed May 10, 2023 9:50 pm
well, maybe it is too early for joy, but looks like WireGuard IPv6 spoke&hub finally working on mmips
it was known problem that only last enabled WG peer will route properly IPv6, others will be lost, but now ...wooow
dakobg
Wed May 10, 2023 11:30 pm
For some unknown reason for me I expect to see ros v8.0 after v7.9 .. I was excited since from what I see BFD will be available in ros v8.0 .. now I'm disappointed .. no v8.0 no BFD
note: I hope everyone understand this is a ironic joke :) .. however my disappointment for missing BDF is not :(
note2: however I appreciate the hap ax lite ipsec hw offload , thank you!
leonardogyn
Thu May 11, 2023 12:04 am
[*]Comments need to go back above the line they're a part of, or that option should be configurable. I have a lot of multi-word/multi-sentence comments. (They've been multi-line in Winbox forever, why shrink it on the details page and make it harder to see everywhere else?)
This forced inline comments on the webfig really discourages the use of comments(which is bad!), as expanding the column to see the comments forces you to scroll horizontally. It might be a good one for big monitors people, but for laptop guys, like me, this is a TERRIBLE change.
Please revert or, at least, have it configurable!
depe
Thu May 11, 2023 2:39 am
Already sent in a different post.
Any chance to add queue type to winbox or cli ? or even Scripts in IPV6 ?
nz_monkey
Thu May 11, 2023 4:06 am
Can we please get more details of MPLS FastPath in version 7
e.g. is this Forwarding only ? or does it support Push/Pop ?
Kaldek
Thu May 11, 2023 4:51 am
Message me directly and I'll see if I can help you. I have VLANs with 7.9 and 7.10beta5 working.
dragoalato1988
Thu May 11, 2023 5:38 am
I agree, you could get more information on what's new in the implementation of MPLS FastPath. Thanks
mazel
Thu May 11, 2023 9:28 am
Unfortunately, I am not able to find a way to send you a PM. So, may we continue in my topic viewtopic.php?t=195929?
EgidijusL
Thu May 11, 2023 9:34 am
Wifi issues same as 7.9. Reported, SUP-115948
hap ax3
holvoetn
Thu May 11, 2023 10:46 am
Yup, upgraded only AX Lite to 7.10b5 and using it as AP for my PC so I can keep an eye on it and I am seeing the infamous PMKSA errors in log.
[mac address]@wifi1 rejected, can't find PMKSA
Also have PingInfoView running on local PC targetting that AX Lite (via wifi), seeing a bit over 4% packet loss.
EDIT: 1hr later, didn't see that error anymore, packet loss dropped to 1.25%.
Startup issues ? Dust needs to settle first ? Who knows ...
parham
Thu May 11, 2023 3:42 pm
anymore info please for *) ovpn - added initial support for V2 data transfer protocol;
ToTheFull
Thu May 11, 2023 6:10 pm
The only thing I can find in my configuration of 7.10b5 is QOS simple queues Upstream isn't working as expected. But even better news, switching over to FQ_Codel is working very well. WiFi in general seems a lot more stable.
johnsonX
Thu May 11, 2023 6:25 pm
CCR2116 upgrades 7.10beta5, the file is lost, and the NVME DISK is unavailable
rextended
Thu May 11, 2023 6:29 pm
From what version?
johnsonX
Thu May 11, 2023 7:45 pm
From what version?
7.9 stable upgrade 7.10beta5
pants6000
Thu May 11, 2023 8:36 pm
I like most of the webfig changes (including/especially the inline comments!), but the centered detail screens just strike me as odd, like the pages aren't rending correctly.
maigonis
Thu May 11, 2023 10:49 pm
What device give that error? I got on my Samsung S22, but S10+ is fine.
holvoetn
Thu May 11, 2023 10:56 pm
Laptop with Intel Wireless AC9560.
Samsung S20 was ok too.
fakeusername2022
Fri May 12, 2023 12:47 am
Please add reboot command to containers.
Sometime it is required to reboot my container on a regular basis due to some bugs... Could not achieve this by scripting Stop and Start commands of the container...
attila123
Fri May 12, 2023 9:28 am
Could you please explain what it means? Will this solve the problem with our CCR2116, which is rebooting every 1-2 days with a watchdog timer error?
buset1974
Fri May 12, 2023 1:05 pm
Oh my god,
The problem still exist on v7? I
The hardware already diff with ccr1xxx , the software also already on v7, but the problem still hapen.
I dont think they now and seek what the cause it.
Unless someone can clear reproduce the problem, eventhough alot of people reported having the same issues.
Thx
gigabyte091
Fri May 12, 2023 3:37 pm
ax2, 7.10rc5 same SSID for 2.4 and 5 GHz, default config, same PMKSA error, phone can't connect to 5GHz WiFi, on 2.4 work just fine. Laptop connects to 5 GHz (Preferred band 5GHz in driver)
ToTheFull
Fri May 12, 2023 4:32 pm
Sadly I've had to downgrade to 7.9 due to problems with QOS.
rextended
Fri May 12, 2023 4:43 pm
I hope you open a supoort ticket wit supout.rif before downgrade....
massinia
Fri May 12, 2023 4:50 pm
Just out of curiosity, have you tried disabling WPA3?
I am now using WPA2 only (hAp ax3+hAP ax2) and have no PMKSA error.
gigabyte091
Fri May 12, 2023 8:35 pm
I tried to enable only WPA2 and now error is gone and i can see in logs that phone connects to 5 GHz no problem. So why is WPA 3 making a problem ?
massinia
Fri May 12, 2023 8:45 pm
I don't know, it only happens with some devices using WPA 3.
gigabyte091
Fri May 12, 2023 8:55 pm
Yea, but for eg. if I have separated SSID for 2.4 and 5 GHz, then I don't have a problem with connecting.
massinia
Fri May 12, 2023 8:59 pm
OK then try with a single SSID, WPA 3 but with FT enabled.
gigabyte091
Fri May 12, 2023 9:32 pm
I set my AX200 WiFi card back to "preferred band: None" just to see if now laptop connects to 5 GHz and now it's working like a charm. I will leave my laptop and phone connected to ax2 instead of my U6-Lite.
ivicask
Fri May 12, 2023 9:48 pm
Seeing alot of Handshake timeouts and pkmsa errors also...
npeca75
Fri May 12, 2023 10:49 pm
looks like beta5 break wireguard IPv6 on ARM
IPv4 works fine
# model = RB3011UiAS
# serial number = 783D085F624D
/interface wireguard peers
add allowed-address=fdff:255::/112,169.254.255.192/26 endpoint-address=xxx.yyy.224.42 endpoint-port=8000 interface="wg: Mgmn (NMS)" persistent-keepalive=15s public-key=\
    "xxxxxxx="
same config works fine with 7.9 but beta5 have a problem with IPv6
it simply does not work
if i try to ping WG HUB i get this error
 ping fdff:255::200
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0                                                              126 (No error information)
    0 fdff:255::202                             104  64 588us      address unreachable
    1                                                              126 (No error information)
    1 fdff:255::202                             104  64 495us      address unreachable
MIPSBE and MMIPS works fine
soonwai
Fri May 12, 2023 11:23 pm
ax3 standalone 7.9 wifi lasted 7 days. viewtopic.php?t=191304#p1001468
Time to test out 7.10beta5.
• Containers ok (have not tested docker pull)
• Wifi ? (it's only been 10 mins.)
• Zerotier ok
maigonis
Fri May 12, 2023 11:43 pm
Disabling WPA3 should eliminate PMKSA error, as it is WPA3 related.
https://documentation.meraki.com/MR/Wi- ... tion_Guide
gigabyte091
Sat May 13, 2023 6:32 am
WiFi is now stable, no random disconnects, signal is better now, I have full signal upstairs with speed between 573 and 626 Mbps reported by phone. (Concrete floor with metal armature)
I didn't test FT, and it's default configuration but for now it's looking good. Much stable than before, at least for me. I hope that Mikrotik will solve a problem with WPA3
holvoetn
Sat May 13, 2023 10:44 am
I am not so sure about that.
2GHz SSID with WPA2 and WPA3 which gives me frequent PMKSA errors (as in: multiple times per day I see it appearing in log).
Another 2GHz SSID using both WPA2 and WPA3, slave of first one, no issues.
5GHz SSID with ONLY WPA3, no problems for days.
pe1chl
Sat May 13, 2023 12:06 pm
What did you configure w.r.t QoS and what problems do you have? I presume it isn't related to qos-hw.
ToTheFull
Sat May 13, 2023 12:12 pm
I need to do more testing, that would mean starting fresh from 7.10 and setting up again which I didn't have the time for. I do however have my cAP ax working with Zero issues and i'm pretty impressed so far with that but the firewall is not being used on that device, only on my hAP ax with queues enabled on ether1. I think 7.10 for me and my devices with wpa2/wpa3 enabled just works well. I'm hoping it's just a silly configuration in my config which is causing it.
ToTheFull
Sat May 13, 2023 12:19 pm
My uploads were aweful, like I said above, i need to test more! but whatever type i used over time it got worse be-it cake/FQ_Codel or simple queues.
now i've downgraded all is well.
Edit
No it's not related to HW QOS
gigabyte091
Sat May 13, 2023 12:27 pm
Did you try same SSID 2.4 and 5 only with WPA3 ?
soonwai
Sat May 13, 2023 12:33 pm
ax3 7.10beta5
It's only been 12 hours but so far 1 x "can't find PMKSA" on the 2.4Ghz. No "key handshake timeout."
2.4Ghz is wpa & wpa2. 5Ghz is wpa2 & wpa3.
holvoetn
Sat May 13, 2023 12:34 pm
No, I didn't. Don't want it like that at home for now.
gigabyte091
Sat May 13, 2023 12:42 pm
So I did a little test, same SSID for 2.4 and 5 GHz, WPA3 only, no errors, devices connects to 5 GHz no problem. WPA2 and WPA3 PMKSA error and devices connects to 2.4 only
pe1chl
Sat May 13, 2023 12:46 pm
For sure it is. But it depends on the connected clients. It may well be that your modern clients on 5GHz have no problem, and the old crap or IoT devices (ESP based) have problems.
pe1chl
Sat May 13, 2023 12:49 pm
Ok I use only DSCP-based marking of traffic and translation to 802.11p priority tagging which is processed by my DSL modem. No queues required.
This is similar to what qos-hw also does.
gigabyte091
Sat May 13, 2023 12:56 pm
Interesting, in my case all devices that experienced problems were at most year and a half old, also had problem on Intel AX200.
ToTheFull
Sat May 13, 2023 1:16 pm
Could VPN traffic cause anything like that to happen with queues, thats the only other thing that might of been running but at the time of testing I didn't see any traffic above a few kb's here and there.
ToTheFull
Sat May 13, 2023 1:19 pm
It's all very frustrating isn't it, we have a load of old tat connnecting here with wpa2/wpa3 enabled with zero PMKSA fualts seen since 7.8
pe1chl
Sat May 13, 2023 1:27 pm
It is actually quite common to see issues like this whenever new WiFi standards are introduced and also when they are implemented by AP manufacturers...
I have seen it all on our Unifi system.
It will take some time before the perfect balance between new features and compatibilty is found.
For now, I would not recommend the use of WPA3. (independent from the use of MikroTik WiFi)
holvoetn
Sat May 13, 2023 1:28 pm
The old crap IoT devices in my home are on the slave 2GHz network and show ZERO errors.
So I'm still not sure about that.
gigabyte091
Sat May 13, 2023 1:37 pm
Well, it is... But with 7.10rc5 I can see improvements, it's default config for now only, no VLANs for now and no multiple SSIDs so it's looking good for me right now but i think that i will wait a little bit longer until i return ax2 and 3 as AP in my house.
gigabyte091
Sat May 13, 2023 1:39 pm
I don't have problems with WPA3 on Ubiquiti AP, i have combo WPA2/3 but then, i only have them for like 2-3 months now.
Also, all IoT devices have their own network, 2GHz and no problem with them on Mikrotik or Ubiquiti. Also is true for my security cameras, own network and SSID 2GHz WPA/WPA2
pe1chl
Sat May 13, 2023 4:27 pm
I have tested with WPA2/WPA3 on Ubiquiti and I find that some devices won't connect to that either.
Unfortunately on these APs it is not possible to see which devices connect in WPA2 and which in WPA3, nor which devices cannot connect at all after you change settings.
FezzFest
Sat May 13, 2023 4:41 pm
Unfortunately, I've just had to reboot my hAP ax^2 again because none of my clients could associate anymore ("key handshake timeout"). Seems this issue hasn't been fully resolved yet in 7.10beta5. WPA2 only, so WPA3 compatibility issues are excluded.
soonwai
Sat May 13, 2023 4:56 pm
@FezzFest That's not good. How long did it last?
I upgraded my ax3 to 7.10beta5 17hrs ago. So far so good. The ax3's v7.9 record is 7 days and a few hrs Mine is 2.4Ghz, wpa & wpa2 and 5Ghz, wpa2 & wpa3.
gigabyte091
Sat May 13, 2023 5:24 pm
What kind of devices ? On Ubiquiti only device that was giving me a problem was heating gateway... Everything else works just fine.
pe1chl
Sat May 13, 2023 5:52 pm
We have over 700 devices and not all of them connected. As mentioned, impossible to know which ones.
FezzFest
Sat May 13, 2023 8:59 pm
Lasted about 3 days, installed 7.10beta5 right after it was released. Sent MikroTik a supout, let's hope that'll help them solve the issue.
ivicask
Sun May 14, 2023 2:29 am
Exactly the same issue here both on stable 7.9 and 7.10, wifi works for one day then all clients get handshake timeout and I need to reboot to fix it.
Im loosing all faith in mikrotik wireless at this point..
soonwai
Sun May 14, 2023 1:08 pm
Mine just died.
Update:
14 May 5:00pm. ax3 7.10beta5 wifi died again. Total wifi uptime: 1 days 12hrs.
15 May 12:20pm. ax3 7.10beta5 wifi died again. Total wifi uptime: 7 hrs 20 mins. (Had FT turned on. Maybe shouldn't have done that. Back to off.)
May 14: key handshake timeout: 117 (in a space of 40mins), can't find PMKSA: 0
May 15: key handshake timeout: 64 (in a space of 2hrs), can't find PMKSA: 0
As usual, had to reboot.
massinia
Sun May 14, 2023 1:21 pm
Mine hAP ax3 resists for now, uptime 2d and 20h.
If it happens again before restarting generate the supout.rif file to send to support.
Kaldek
Sun May 14, 2023 1:24 pm
For what it's worth, I seem to have gotten some WiFi stability by disabling all of my access list rules in WiFi. I had noticed that in 7.8, some of my ACLs just did not apply, when those same rules (for a specific MAC address) worked on CAPsMANv1. When I upgraded to 7.9 and had the issue with not being able to connect, I removed all my ACLs. It seemed to resolve the issue.
Units are cAP ax, CAPsMAN controller is RB5009, all running 7.10beta5 currently.
gigabyte091
Sun May 14, 2023 7:05 pm
My ax2 uptime 2d 3h still going strong, no signs of any kind of error. I updated ax2 at my parents house, no problems for now.
oliver0513
Sun May 14, 2023 9:11 pm
i hope this means full compatibility with openvpn 2.6 personally
coddy
Mon May 15, 2023 12:11 am
7.10beta5 - Remote CAPsMAN managed AX3 - Uptime approximately 4 days 10 hours, "invalid password" prompt across Win11 Laptop, iPhone and Samsung phone - again... Rebooting AX3 resolved problem.
Created SUP-116195 with support.rif file whilst it was in its failed state.
The other AX3 (acting as CAPsMAN server) was still working correctly, and moving devices in range of that AX3 resulted in them reconnecting. Moving the devices back in range of the failed AX3 resulted in the invalid password after multiple attempts of it trying to connect... After this testing I created a support.rif file on the failed AX3, and rebooted it. The reboot cleared the problem (for now....).
Waiting on the other AX3 to fail now, I am guessing that is only a matter of time...
dewitpj
Mon May 15, 2023 1:42 am
Please give us themes for the UI changes - the new one sucks for me
Jotne
Mon May 15, 2023 8:18 am
Starting with V7.9 the following commands stopped returning the right information:
interface/ethernet/print proplist=speed
interface/ethernet/print proplist=full-duplex
Both commands return "empty" values.
Mauricio
Broken in 7.10beta5 as well. Did work fin in 7.6 (Testet on RB951)
DarkNate
Forum Veteran
Forum Veteran
Mon May 15, 2023 9:00 am
I hope MikroTik adds proper support for TCP NAT punching as well with the full cone NAT feature now:
viewtopic.php?p=1000604&hilit=full+cone#p998143
EgidijusL
Mon May 15, 2023 11:19 am
Mine just died.
Update: 14 May 5:00pm
From support get alpha version, 3d 22hours no problems
mh04
Mon May 15, 2023 11:40 am
Since version 7.9 there is an error when you fetch the routing table via SNMP (1.3.6.1.2.1.4.24.4.1.4):
snmpwalk -v1 -c public 192.168.88.1 1.3.6.1.2.1.4.24.4.1
iso.3.6.1.2.1.4.24.4.1.1.0.0.0.0.0.0.0.0.0.10.44.10.69 = IpAddress: 0.0.0.0
iso.3.6.1.2.1.4.24.4.1.1.0.0.0.0.0.0.0.0.0.0.0.0.0 = IpAddress: 0.0.0.0
Error: OID not increasing: iso.3.6.1.2.1.4.24.4.1.1.0.0.0.0.0.0.0.0.0.10.44.10.69
 >= iso.3.6.1.2.1.4.24.4.1.1.0.0.0.0.0.0.0.0.0.0.0.0.0
The error did not exist in previous versions.
soonwai
Mon May 15, 2023 1:48 pm
Hung again. (Had FT turned on. Maybe shouldn't have done that. Back to off.)
Been meaning to send support an email and supout but keep forgetting to generate it. Gonna do that the next time it dies.
I was really happy when 7.9 went on for 6 days. Then it died on the 7th day. :-(
connectlife
Mon May 15, 2023 3:22 pm
MLAG on 4 CRS326-24S+2Q+ starting from version 7.7 up to 7.10 beta 5 is broken..
On 7.6 everything works fine. The problem seems to start from 7.7, version which makes several changes to the bridges
SUP-116274
SUP-115519
SUP-116233
leonardogyn
[*]Centering the details in the middle of the screen is jarring visually when we've got browser windows open wide to see/monitor the huge amounts of data in the tables and we're generally looking at the left side already (in LTR languages). Also, when quickly moving through settings or information pages (setting up new devices, troubleshooting existing installations, or turning up new BGP sessions), that added distance adds extra mouse travel time (i.e. hand fatigue), as opposed to having the DIV left-aligned.
[*]The huge amount of white space (well, gray) below the scrollable DIV in the absence of the OK/Apply/Cancel buttons gives the user the impression that they're at the end of available options. That DIV needs some kind of visual indicators that there's more data/settings hidden behind the invisible block, such as a hairline border around it, or maybe arrows or something.
Kind of adding to these, in some places "centering" everything is plain dumb. When editing big scripts, for example, the amount of actual "script space" on 7.10 is greatly reduced while compared to 7.9 and older. Screenshots are editing the same script, on the same monitor/resolution, only changing from 7.9 to 7.10b5. The difference is HUGE, being 7.10 absolutely worst.
ROSv7.9
ROSv7.10b5
rextended
Mon May 15, 2023 3:31 pm
Is it the same programmer / "artist" / "GUI expert" who on Windows 11 weighed well to center the taskbar and remove "ungroup" icons?
A damn good choice that prevents me from migrating to Windows 11 for this crap that interferes with productivity...
Also forcing inline comments...
Truly GUI experts both...
infabo
Long time Member
Long time Member
Mon May 15, 2023 4:03 pm
I am still wondering why the comment is now a column? And I actually wonder and question the decision-process behind this change. This is either some input from some "UX expert" ("streamline the interface and remove that disruptive comment line" )or simply a bad design decision by some newcomer. People may write long comments, that's why this was a really dumb change.
infabo
Long time Member
Long time Member
Mon May 15, 2023 4:06 pm
And when centering all the form fields is the result of this change, then: holy batman. please get external expertise in web design or hire someone who knows how to do it.
pe1chl
Mon May 15, 2023 5:06 pm
I think it is great! It has always been possible in winbox, and the setting "inline comments" is always the first thing I do when using winbox on a new device.
Probably it would have been better to put comment in the rightmost column just as it is in winbox, instead of in the second column.
What I would like to see is the capability to add/remove/re-order columns in webfig like it is in winbox. (and saved for later visits)
leonardogyn
Mon May 15, 2023 5:10 pm
I think it is great! It has always been possible in winbox, and the setting "inline comments" is always the first thing I do when using winbox on a new device......
In winbox it was always possible to CHOOSE which one you'd like to use: inline comments or "newline" ones. Having the option to choose which one to use is the key here. It was simply changed to FORCED inline comments on webfig, interface in which you cannot reorder columns.
Would be awesome to have inline comments as an OPTION on webfig.
infabo
Long time Member
Long time Member
Mon May 15, 2023 6:15 pm
I think such an toggle-option (inline comments yes/no) could be part of the webfig skin-editor.
Are you having an ultra wide display? I did not even know about that option, as I hardly use Winbox. But when I use Winbox every now an then, I use it with at least 6 windows arranged inside the main window. And "inline comments" adds a dramatically huge horizontal scrollbar (when I set the fitting width for comments column, so I can read even long comments). But YMMV. And being able to choose, makes this not worth to start a "inline vs separate line"-war. User's personal choice.
DSprecic
Mon May 15, 2023 10:34 pm
For now, I would recommend trying Aruba 5xx APs with WPA3, probably Ruckus no different, same with Ciscrap.
WPA3 is a change in security, not in rf waves, if your client has it implemented as expected and your AP too it just works. Got a few Aruba APs running and if there's something that has been working no matter what it's WPA3.
Unless you have a crap Android phone that doesn't even get those patches anymore.
Or if the implementation of WPA3 sucks on your AP. It's the same story as wether your wifi has a proper WPA2-KRACK counter implementation or not, done properly no issues, done wrong and you will see issues.
pe1chl
Tue May 16, 2023 10:41 am
That is what I mean. It does not work on all clients, and when your clients are not under your own control (e.g. it is your home wifi) it is difficult to make sure
that it will work. Of course you can use WPA2/WPA3 transition mode, but even that does not guarantee it will always work.
It is like enabling 802.11k/r/v. On most devices it is OK, but some devices will either fail to connect or they will connect once and then fail to roam.
Not a problem when it is your home wifi and you can determine which devices have problems (e.g. your doorbell), not so good when it is an office with company
and visitor devices and you never know who wants to use it.
gigabyte091
Tue May 16, 2023 5:03 pm
Regarding roaming in ROS, i found this at Mikrotik help:
So if I have for eg. ax3 and ax2, for devices to be able to roam i have to have capsman enabled ?
leonardogyn
Tue May 16, 2023 5:11 pm
..... Of course you can use WPA2/WPA3 transition mode, but even that does not guarantee it will always work.
Some days ago I had my first real problem with a device not being able to connect to a WPA2/WPA3 transition mode enabled SSID. I have already setup that way in several locations, but never had a problem or, at least, nobody ever complained about it. And funny enough, it was an Apple device, a Gen1 Apple TV. It simply refused to even ask the password for the network, giving a -100 error. I really had to "downgrade" the network to WPA2 mode only, and it worked immediately.
From all sort of devices, I would really not expect an Apple device to give me headaches on that matter, while all other chinese cheap crap can use the network with no problems :)
massinia
Tue May 16, 2023 5:20 pm
Yes, and there are many useful discussions about this.
gigabyte091
Tue May 16, 2023 5:36 pm
For eg ? Have any links ? I will pretty soon return home wifi from Ubiquiti to Mikrotik again and want to test it further with configuration that will be in use.
massinia
Tue May 16, 2023 5:46 pm
We are very OT here…
The first ones i found:
viewtopic.php?t=194331
viewtopic.php?t=194778
gigabyte091
Tue May 16, 2023 6:12 pm
Thanks, no more OT. Right now I migrated my IoT devices to Mikrotik and it's stable for now, tomorrow i will migrate security cameras.
naxus
Tue May 16, 2023 11:03 pm
And after few days again (getting this when not using/using capsmanv2)
so WPA3 is bit unusable...
Getting in on 2 hapax2 and audience as well
Created SUP-116463 with supout
Xx:xx...@wifi2 rejected, can't find PMKSA
mantouboji
Wed May 17, 2023 2:33 pm
maybe IPv6 is broken.
I use dynv6 to register a dynamic domain name with only IPv6 address . and then try to get a LetsEncrypt centification using:
`/certificate/enable-ssl-certificate dns-name=MYNAME.dynv6.net `
and then get a "resolv error"
switch back to 7.9, it's OK .
hAP AX3
attila123
Wed May 17, 2023 4:27 pm
Our CCR2116 has rebooted with watchdog timer error after 4 days of uptime. SUP-116550 was created.
arnaudf92
Wed May 17, 2023 6:01 pm
Dear Mikrotik,
I see some movement about QoS, pcp and dscp.
Therefore regarding this pcp and dscp thing, could it be possible to fix the long-lasting bug that I could summarize by :
==> "priority set from ROS firewall or bridge rules is not translated into vlan pcp header"
Ie. SUP-80065
Regards.
pe1chl
Wed May 17, 2023 7:35 pm
That must be a bug that involves more than setting a priority, as I use that to set 802.1p priority and it mostly works for me.
I know about one peculiar bug: a GRE tunnel with "DSCP inherit" and IPsec transport, over PPPoE on a VLAN with 802.1p priority, will not work on the 4011 while the same config works on the 2011. SUP-64360.
arnaudf92
Thu May 18, 2023 12:20 am
Which MT device do you use ? (for me it's a CRS326-24G-2S+).
Currently, the only approach that works to set 802.1p is to use switch rules, and thus only works for traffic that ingress ports (not for traffic passing through router processes).
nichky
Thu May 18, 2023 7:54 am
not enough, need more info
volkirik
Thu May 18, 2023 11:19 am
is it the time for 7.10 next beta release? or rc1?
Rox169
Thu May 18, 2023 12:21 pm
You can see many problems and you are asking RC version after first beta? :)
holvoetn
Thu May 18, 2023 1:42 pm
Better they stick a bit longer to beta now before moving to rc ... my 0.02€
naxus
Thu May 18, 2023 1:57 pm
I don't really understand such questions... It will come when ready, sometimes it's fast, sometimes takes longer to properly test...
Jotne
Thu May 18, 2023 2:27 pm
naxus answer it the correct one.
If looking at the past, you can see here how many betas has been released to the public (posted here on the forum) before RC was released:
ver #beta
7.9 1
7.8 2
7.7 5
7.6 5
7.5 4
7.4 3
7.3 4
7.2 0 (no beta found)
7.1 5
7.0 3
raimondsp
Thu May 18, 2023 3:14 pm
ver #beta
7.9 1
7.8 2
7.7 5
7.6 5
7.5 4
7.4 3
7.3 4
7.1 5
7.0 3
To be precise, the above are numbers of public betas. As you may notice, the first public 7.10beta is beta5, meaning there were four private betas before that didn't pass QA to become a public release. We are not aiming at any number - it depends on how many betas pass QA but are not stable enough yet to become release candidates.
leonardogyn
Thu May 18, 2023 6:42 pm
Absolutely NOT! Let the dev team take the time they need to get it to the closest to stable conditions. There's absolutely no need to rush anything :)
volkirik
Fri May 19, 2023 8:24 am
alpha, beta, and rc releases do not have to be stable.. actually they could release alpha's in dev channel (if they dont brick the hardware)
even MS windows has insider program for that purpose..
ToTheFull
Fri May 19, 2023 12:11 pm
It looks like I started getting these 4 days in on both radios on cAP ax. About 1 per day across both radios and different devices.
Any thoughts please.
05-11 06:31:45 system,info router rebooted
05-15 10:25:43 wireless,info F4:XX:XX:XX:XX@wifi2 disconnected, association SA Query timed out, signal strength -42
05-16 05:07:41 wireless,info 62:XX:XX:XX:XX@wifi1 disconnected, association SA Query timed out, signal strength -62
05-17 06:49:07 wireless,info 3A:XX:XX:XX:XX@wifi1 disconnected, association SA Query timed out, signal strength -69
05-18 07:35:17 wireless,info 1C:XX:XX:XX:XX@wifi2 disconnected, association SA Query timed out, signal strength -87
uptime: 1w1d2h35m30s
version: 7.10beta5 (development)
build-time: May/09/2023 10:38:53
factory-software: 7.7
free-memory: 612.8MiB
total-memory: 928.0MiB
cpu: ARM64
cpu-count: 4
cpu-frequency: 864MHz
cpu-load: 3%
free-hdd-space: 95.2MiB
total-hdd-space: 128.5MiB
write-sect-since-reboot: 460
write-sect-total: 71592
bad-blocks: 0%
architecture-name: arm64
board-name: cAP ax
platform: MikroTik
Rox169
Sat May 20, 2023 9:40 am
I have the same problem as SUP-116195. All devices are disconnected and mobile cannot join WiFi it says wrong password after reboot all ok. I did downgrade to 7.9 stable and I had the same situation happened.
I turn off wpa3 but I'm not sure if this will help.
Do you have any advice how to eliminate this problem?
My WiFi needs WiFi working for her home office...
nonolk
Sat May 20, 2023 10:19 am
@Rox169, downgrade to 7.8, it’s rock solid for more than 20 days on my side (3 ax2 and 1 ax lite, with capsman).
holvoetn
Sat May 20, 2023 10:27 am
First WiFi = wifey ? 🤣
bsiege
Sat May 20, 2023 5:05 pm
Could it be that time format changes include export config? This started with 7.10beta
In oxidized i get a "config change" on every run, because time changes in output:
--- a/rbhapax01.
+++ b/rbhapax01.
@@ -108,7 +108,7 @@
 # U device changed                            admin  write
 # U wifiwave2 configuration settings changed  admin  write
-# 2023-05-17 18:12:49 by RouterOS 7.10beta5
+# 2023-05-17 19:12:50 by RouterOS 7.10beta5
 # software id = B4G6-6IJM
 # model = C52iG-5HaxD2HaxD
of course i can omit this in rancid/oxidized config, but it is a unneeded change of behavior anyway....
rextended
Sat May 20, 2023 9:25 pm
I don't understand your problem, since the line where there is the date and time always has the current date and time, so it is always different, and it has ALWAYS been like this.The time chante on each export,
bsiege
Sat May 20, 2023 10:44 pm
Ok, doing config backups since 1901 days 12 hours with oxidized. This was RouterOS 6.41.2. And since 7.10beta5 detection of config changes is broken in oxidized. It was definitive NOT ALWAYS like this.
leonardogyn
Sat May 20, 2023 10:49 pm
I'm with @rextended ... /export *ALWAYS* had the current timestamp, so diffing two different exports, done at different times, would always show that difference, despite no other config changes. This always happened and it's really not new on 7.10beta or even RoSv7 at all. Data format indeed changed on 7.10, but the timestamp itself was always there and always different if generated at different times.
This from latest RoSv6 for example:
[admin@ShoppingGallo] > /export terse
# may/20/2023 16:47:07 by RouterOS 6.49.7
# software id = 7DZ4-DVS2
# model = RouterBOARD 3011UiAS
# serial number = .......
and this from RoSv7.9
[admin@CASAGCELdaOAB] > /export
# may/20/2023 16:50:13 by RouterOS 7.9
# software id = 3A7Y-M73T
# model = RB750Gr3
mkx
Sat May 20, 2023 10:58 pm
Perhaps oxidized recognizes the date part of export and filters it out ... but fails to do so with new datetime format?
rextended
Sat May 20, 2023 11:24 pm
[…] since 7.10beta5 detection of config changes is broken in oxidized […]
Is oxidized the problem, not RouterOS...
Instead of skipping the first line comparison, what does the program do?
I have been using "diff" for years and making it skip the first line, however it goes it always works even if the router version or the date and time change...
It's an oxidized problem, so ask on oxidized forum for it to be updated.
leonardogyn
Sun May 21, 2023 7:28 pm
I was looking at RouterOS procedures on the oxidizer sources ( https://github.com/ytti/oxidized/blob/m ... outeros.rb ) and to my best regexp knowledge, I couldn't find anywhere it would remove the first (timestamped) line on the /export ... maybe it's done in another place. But I fully agree with you, that's an oxidized problem, not RouterOS one.
EDIT: actually it seems line 48 would be the one that rejects the timestamped line ... that seems the one that needs to be adjusted to match the new timestamp (and the old as well, to keep compatibility with versions <7.10)
rextended
Sun May 21, 2023 7:38 pm
I do not want investigate this syntax, is uselessly precise at the start, for accept later all, for nonsense.
cfg = cfg.split("\n").reject { |line| line[/^#\s\w{3}\/\d{2}\/\d{4}.*$/] }
but why not simply
cfg = cfg.split("\n").reject { |line| line[/^#.* by RouterOS .*$/] }
or uselessly precise (like the original),
cfg = cfg.split("\n").reject { |line| line[/^#\s(\w{3}\/\d{2}\/\d{4}|d{4}-d{2}-d{2}).*$/] }
bsiege
Sun May 21, 2023 8:36 pm
Oh, did I? My intention was to confirm that datum changes affects oxidized too. And so it's written....
Why is the kitty so pitbully?
massinia
Sun May 21, 2023 11:39 pm
It just happened to me too, I only use wpa2.
Supout.rif generated before reboot and sent (SUP-116928), I hope it helps the support.
Rox169
Mon May 22, 2023 10:02 am
Hi Massinia,
do you know if it was only on one radio? 2,4 or 5,4? I tried to split one ssid to two and I hope when one will be blocked laptop will join the next one.
rpingar
Long time Member
Long time Member
Mon May 22, 2023 10:05 am
BFD has been marked as "initial support" in 7.10 here:
https://help.mikrotik.com/docs/display/ ... l+Overview
it is coming soon!!!!!!!
Phaere
Mon May 22, 2023 11:50 am
I didn't drink alcohol for about 3 years but now it's time i think :D
Rox169
Mon May 22, 2023 11:52 am
I would prefered to have stable wifi than BFD :)
rextended
Mon May 22, 2023 12:17 pm
I must have expressed myself badly, but in addition to complaining about how the code was written wrong, I also provided the solution.
Larsa
Mon May 22, 2023 12:23 pm
Yeah, that was just one example of the consequences with the new date format that totally unnecessary breaks script compatibility. I really hope MT rethinks and fixes this asap.
Pure stupidity IMO!
rextended
Mon May 22, 2023 12:28 pm
Sorry, but unfortunately it is the oxidized code that is done with the feet, in this case...
viewtopic.php?p=1003427#p1003306
If it was written right from the start, there was no problem.
Then the fact that it excludes other lines that I consider important from the comparison is another story...
leonardogyn
Mon May 22, 2023 4:24 pm
By Mikrotik staff comments, I would say it's here to stay, and scripts will have to be adjusted. At least for me, adjusts were simple to make, 2 minutes and everything was done.
rextended
Mon May 22, 2023 4:27 pm
Is possible to write scripts that work on both regardless the date format:
viewtopic.php?t=196072#p1001344
Larsa
Mon May 22, 2023 5:01 pm
Well, we'll see what they decide.
I want to emphasize that we welcome the new date format. HOWEVER, implementing it in a way that breaks compatibility, and in addition absolutely unnecessarily, is just plain stupidity.
And of course, you can "fix" the problem with various modifications, but the level of effort required varies depending on its occurrence. People who don't understand the implications of this issue shouldn't comment on the matter IMO.
leonardogyn
Mon May 22, 2023 5:59 pm
Well, I believe that you're having me among those "who don't understand the implications" ... and i'd say you're really wrong on that one. Accepting it will happen doesn't means I don't understand it. But that decision is not on me. I would have made it on different ways, but that's really not on me.
And that all being said, seems kind of censorship expecting that only those who agree with you can comment on something, doesn't it ??? Everybody is free to comment, no matter their opinions.
Larsa
Mon May 22, 2023 8:56 pm
You are, of course, entitled to say whatever you want!
And I still stand by the belief that individuals with a "fixer-upper" attitude (i.e., hacker hero) who lack insight into the implications of large-scale operations should refrain from commenting on that particular matter (in my opinion!)
Please feel free to continue this debate in the thread: "WARNING: RouterOS v7.10+ will break all scripts based on [/system clock get date] or other date(s)"
rextended
Tue May 23, 2023 2:19 am
@larsa
so you shouldn't comment?
Tell us from your wisdom what these blessed "implications of large-scale operations" are, that only you seem to know about them.
That by chance these operations are installing a beta in production? Or the inability to distribute "commands" beyond the update?
Tell me, from your highest and deepest vision, what these problems are, instead of continuing to insinuate that others don't have the insight.
Maybe the others are better than the mediocre employees of these large companies?
Yeah, a stupid and insignificant little person who can act in an instant,
instead of the giants who don't know what mediocre and banal employees they hire,
those big companies, they are much more organized and efficient, who are put into crisis MONTHS/YEARS before something beta and unstable go into production...
Yeah, luckily there are big companies that have smarter and better people who go into crisis for so little.
daaf
Tue May 23, 2023 7:26 am
RouterOS version 7.10beta has been released on the "v7 testing" channel!
BartoszP
Tue May 23, 2023 8:26 am
@daaf
Chalenge accepted but no clue what you report?
holvoetn
Tue May 23, 2023 8:37 am
Same sentiments when I saw it ...
I guess the error line about "no such item" ?
@daaf:
you need to be A LOT more detailed about what your specific issue is.
You're running a customized default script or the default ?
What are you expecting which is not there now ?
massinia
Tue May 23, 2023 10:17 am
hAP ax3 + hAP ax2 + cAP ax
After only two days the problem with the wifi returns.
No one can log in : wrong password error.
Now I have added a scheduled reboot every 24 hours but, please mikrotik, this bug is really urgent to fix...
Jotne
Tue May 23, 2023 10:18 am
Why is it urgent to fix? This is a beta, just for testing and not for production.
massinia
Tue May 23, 2023 10:20 am
It is urgent because the same problem exists also with the stable 7.9.1, there are many discussions about it.
holvoetn
Tue May 23, 2023 10:57 am
It seemed before there was some combination using WPA3 which triggered this.
I reverted back to 7.8 for quite a while on my AX devices to circumvent this, using only WPA2 just to be sure (no wifi for wifey can be ... "a challenge" at home 🤣).
Now running for 5 days already on AX2 and AX3 using 7.10b5 using both WPA2/WPA3, so far no lockouts seen (which I did have a couple of times on 7.9, so I assume also in 7.9.1).
Which indicates there is something else which triggers it ?
@massinia: send supout to support whenever you see it happening. It's the only way to make them aware and provide them enough info to investigate.
Chicken and egg problem. You need to have the problem to have it investigated but I understand you also want working devices.
Likely not an easy one to catch.
Rox169
Tue May 23, 2023 11:36 am
Holvoen,
I gave her instruction how to reset the router in case it freeze again :) Be carefull at version 7.10b5 it happen to me here as well and I had the same combination of WPA2/WPA3 allowed.
EdPa
Tue May 23, 2023 1:40 pm
What's new in 7.10beta8 (2023-May-22 18:52):
!) ipv6 - fixed DNS server processing by IPv6/ND services (CVE-2023-32154);
!) route - added BFD (CLI only);
*) bgp - allow to filter BGP sessions by AFI;
*) bgp - changed default VPNv4 import distance to iBGP value (200);
*) bgp - do not check route distinguisher on import;
*) bgp - fixed "as-override" and rename to "output.as-override";
*) bgp - fixed "remove-private-as" and rename to "output.remove-private.as";
*) bgp - show address family in advertisements;
*) bgp - show approximate received prefix count by the session;
*) branding - fixed custom logo (introduced in v7.8 );
*) conntrack - added read-only "active-ipv4" and "active-ipv6" fields to "/ip/firewall/connection/tracking" (CLI only);
*) console - fixed "print without-paging" output in some cases;
*) defconf - allow to use device factory preset credentials in Flashfig and Netinstall configuration files;
*) dhcpv4-server - added name for "IPv6-Only Preferred" option (108) in debug logs;
*) doh - less verbose logging;
*) ipsec - added hardware acceleration support for IPQ-5010 (hAP ax lite);
*) ipsec - removed "ec2n185" and "ec2n155" values from proposal configurations;
*) l3hw - added "autorestart" option to L3HW settings;
*) l3hw - added error message and reset "l3-hw-offloading=no" if L3HW driver fails to start;
*) l3hw - fixed offloading of /32 IPv4 and /128 IPv6 routes;
*) l3hw - improved offloading of IPv6 hosts after L3HW driver restart;
*) l3hw - improved performance of partial offloading;
*) l3hw - improved route offloading after gateway change;
*) lora - improved gateway card detection and upgrade logic;
*) lora - updated firmware version for LoRaWAN gateway (for R11e-LoRa8, R11e-LoRa9 cards);
*) lte - fixed APN authentication for R11e-LTE6 modem;
*) lte - improved MBIM modem firmware reported error handling when settings RAT modes;
*) lte - improved modem firmware upgrade stability for MBIM modems;
*) lte - reduced SIM slot switchover time for MBIM modems with UUIC reset support;
*) netwatch - added warning about non-running probe due to "startup-delay" (CLI only);
*) poe - fixed bogous "poe-in-voltage" values when using DC jack for RB5009;
*) qos-hw - renamed VLAN "priority" field to "pcp" to avoid confusion;
*) rose-storage - added support for multiple smb users and smb shares;
*) routerboot - increased "preboot-etherboot" maximum value to 30 seconds ("/system routerboard upgrade" required);
*) scheduler - fixed incorrectly started scheduler during reboot or shutdown;
*) sfp - fixed combo-sfp linking at 1G rate for CRS312 switch;
*) sfp - improved module compatibility with bad EEPROM data for RB4011, RB5009, CCR2xxx, CRS312 and CRS518 devices;
*) sniffer - fixed large .pcap file limit;
*) snmp - added BGP peer table support IPv4 only (1.3.6.1.2.1.15.3.1);
*) tr069 - added 5G SCC "SNR" parameter for modems that report it;
*) vrrp - added warning if "sync-connection-tracking=yes" while the global connection tracking is inactive;
*) vrrp - added warning if the VRRP group is misconfigured;
*) vrrp - added warning if VRRP or its interface does not have an IP address;
*) vrrp - do not start connection synchronization if the global connection tracking is inactive;
*) vrrp - fixed issue where disabled VRRP interface is affecting group;
*) vrrp - fixed VRRP interface state on physical cable disconnection;
*) vrrp - improved system stability on changing "group-authority" or "sync-connection-tracking";
*) vrrp - renamed "group-master" to "group-authority" to avoid confusion with VRRP master;
*) vrrp - send VRRP announcements only by "group-authority";
*) wifiwave2 - do not include in radio hardware capability list a parameter irrelevant to end users (introduced in 7.10beta5);
*) wifiwave2 - fixed CAP interface name when using "name-format";
*) wifiwave2 - fixed connectivity issues wheen access-list is used;
*) wifiwave2 - fixed wireless throughput issues after 802.11r client roaming events on 802.11ac devices;
*) wifiwave2 - improve protections against DoS attacks on WPA3-PSK;
*) wifiwave2 - less verbose logging when WPA3-PSK clients are connecting;
*) wireguard - retry "endpoint-address" DNS query on failed resolve;
FezzFest
Tue May 23, 2023 2:00 pm
BFD! And BGP prefix counters! And BGP SNMP support! It's Christmas in May!
wispmikrotik
Tue May 23, 2023 2:07 pm
Thank you very much mikrotik!
Rox169
Tue May 23, 2023 2:17 pm
MT please is in this new beta fixed SUP-116195? . All devices are disconnected and clients say wrong password after reboot all ok.
tpedko
Tue May 23, 2023 2:57 pm
BFD!!!! you heard us, yeah. it works!
Njumaen
Tue May 23, 2023 4:10 pm
Great idea! ;-) Thanks!
ivicask
Tue May 23, 2023 4:19 pm
@EdPa can you give more details about "wireguard - retry "endpoint-address" DNS query on failed resolve;"
How many times will it retry? Does this solve our problems with dynamic ips on peers where we need to re-toggle tunnel to fix it after IP change?
gabacho4
Re: v7.10beta [testing] is released!
Tue May 23, 2023 4:38 pm
I was expecting nothing more than the fix for the CVE. Holy crap! And finally all the BFD and BGP complaints will stop!!!!!
Amm0
Tue May 23, 2023 5:48 pm
F1/help is missing descriptions for the BFD attributes in CLI
Raf44
Tue May 23, 2023 5:55 pm
beta 10 : BGP VPN4 have same problems as before 7.9 ; type "copy" routes, and no BGP attributes
elmomac
Tue May 23, 2023 5:57 pm
SUP-114337 updated as even with the latest fixes in 7.10beta8, all routing ceases to work on my CCR2216 after a few minutes when the L3HW table fills up
[admin@ccr2216] > /interface/ethernet/switch/l3hw-settings/monitor
ipv4-routes-total: 146268
ipv4-routes-hw: 146233
ipv4-routes-cpu: 34
ipv4-shortest-hw-prefix: 0
ipv4-hosts: 137
ipv6-routes-total: 176865
ipv6-routes-hw: 645
ipv6-routes-cpu: 176219
ipv6-shortest-hw-prefix: 48
ipv6-hosts: 133
route-queue-size: 0
fasttrack-ipv4-conns: 0
fasttrack-hw-min-speed: 0
nexthop-cap: 8192
nexthop-usage: 339
https://help.mikrotik.com/docs/display/ ... ng-CCR2000 was last updated for ROS 7.1 - are these numbers still correct? As i am seeing more routes in the above table, although lots of instability!
mrz
Tue May 23, 2023 6:36 pm
Maybe you didn't actually upgrade, since since beta10 do not have "copy" routes anymore and BGP attributes are there for bgp vpn routes.
pe1chl
Tue May 23, 2023 7:36 pm
As expected (feared), the count is before route filtering, whereas in v6 it was after route filtering.
But still better than nothing!
rpingar
Long time Member
Long time Member
Tue May 23, 2023 7:41 pm
I like to have them before the filtering!!!!
MT why don't you develop both values (before and after route filtering)???? It could be very nice.
regards
leonardogyn
Tue May 23, 2023 8:17 pm
PLEASE Mikrotik staff that reads this thread ... reconsider the inline comments on the webfig and also the 'centering of everything', as it wastes A LOT of space on the new layout (please see my previous comment showing editing scripts at viewtopic.php?t=196061#p1002223 ).
While making things prettier is great, making everything worse to use is not. Some of these changes really adds too little while taking A LOT on the usability.
Please reconsider them, PLEASE :)
pe1chl
Tue May 23, 2023 8:40 pm
It looks like the BFD actually works fine! Hooray!
Next wish-list item: make the "BGP Sessions" tab in winbox auto-refreshing like the "BGP Peers" tab in version 6.
Right now the information displayed w.r.t. active sessions, prefixes, rx/tx messages and uptime is stale unless you press F5 all the time.
The "uptime" field is misleading as it is always counting up from the moment the tab has been opened, even when the session is not up at all...
holvoetn
Tue May 23, 2023 9:10 pm
One wish granted per year, ok ?
loloski
Tue May 23, 2023 9:14 pm
Finally, we can pickup where we left off in IX deployment and hope we can use our few dozen of MT gear as supplemental to the existing infrastructure, if only this is available last year we are not in the current predicament right now that we are mixing platform in DC.
@MT please next in your roadmap should be as follows :)
QinQ, VXLAN and MACSEC offload in hardware, Openflow,VPDN and 802.1ah-2008 if this happen MT will be a household name in DC :p
npeca75
Tue May 23, 2023 10:39 pm
still no IPv6 / WireGuard on ARM rb3011
ipv6/route/print
Flags: D - DYNAMIC; A - ACTIVE; c, s, y - BGP-MPLS-VPN; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#      DST-ADDRESS                    GATEWAY              DISTANCE
  DAc  fdff:255::/112                 wg: Mgmn (NMS)              0
ipv6/address/print
Flags: X, D - DYNAMIC; G, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
 #    ADDRESS                       INTERFACE            ADVERTISE
 8  G fdff:255::202/112             wg: Mgmn (NMS)       no
same config work on 7.9
mrz
Tue May 23, 2023 11:55 pm
If you refer to "filtered" by routing filters then there is no difference filtered or not filtered, total route count stays the same in both cases. And it does not makes sense to display count of just part of the routes stored in the memory.
pe1chl
Tue May 23, 2023 11:57 pm
In v7, yes. But in v6 that was not the case.
Kaldek
Wed May 24, 2023 3:01 am
I like the inline comments in WebFig. It's saving me a lot of time scrolling. I ask that Mikrotik don't change this back.
leonardogyn
Wed May 24, 2023 3:35 am
Actually we have asked, earlier on this thread and on the 7.9 threads as well, to have the OPTION to choose inline or "newline" comments, just like the winbox has (and always had) the option to choose which one the user prefers.
For those working on big monitors/resolutions, I agree that inline comments might work great. But for the laptop users, like me and A LOT of others, the inline comments are really bad. We even had people reporting that manages MK boxes, using webfig, from mobiles, in which it's even worst!
Since the introducion of the FORCED inline comments on the webfig, we have asked, actually, the ability to CHOOSE which one to use, and not THIS or THAT being force-choosed for us :)
nichky
Wed May 24, 2023 4:30 am
normis
Wed May 24, 2023 7:24 am
As you can see from other commenters, who like it ... This is a matter of taste. How is "left aligned" in your big monitor not wasting space, but centering is wasting space? It is the same amount of wasted space, just in a different place. Do not use webfig in a maximised window on a ultrawide.
mh04
Wed May 24, 2023 7:46 am
Still not fixed in newest beta. Please look at this problem.
mantouboji
Wed May 24, 2023 8:10 am
resolved
sirbryan
Wed May 24, 2023 11:02 am
But because comments are now inline, I have no choice but to widen my browser to see longer comments. The problem isn't a matter of taste when comments exceed 10-15 chars. It's a matter of usability/readability.
I gather the vast majority of webfig users don't use long comments. The problem is enough of us do. For me, I use them a lot, particularly in routers where I have a lot going on and use them to remind myself why routing filters or interfaces are configured the way they are, and in some cases, I even store tidbits of filter "code" in the comments for comparisons or for backup/emergency purposes.
With the comments now inline, the bulk of the information is cut off. In order to read them, I have to click on the line(s) I want to read.
In the name of aesthetics, this ends up creating more work.
Similarly, but to a lesser extent, centering and grouping everything requires more eye/mouse travel, and obscures information that was previously immediately visible. For example, I frequently check 60GHz AP's for station status (why isn't there a separate table for 60GHz radios? And why isn't the name or MAC of the CPE associated with their signal strength, etc.?). With everything hidden under "Status", I've got to click more times to get to what I need.
I know this may come across as silly to some of you, but when your daily workflow is impacted by UI changes like this, these little things tend to add up.
Raf44
Wed May 24, 2023 11:10 am
i don't know... how can we explain that ?..
i just upgrade from 7.10 - beta 5 -> 7.10 beta 8
the 2 RR are in 6.49.7
Already have a (long) ticket on problems about BGP VPN4, I can re-supply the schematic / supout of the 13*RB951 + 2*hap ac2 of my model if needed
pe1chl
Wed May 24, 2023 11:56 am
Of course the problem is that webfig has no options at all. To have an option for such a thing, first the development has to be done to have options.
Once that is done, of course it would be trivial to have an option like on winbox. And lots of other options as well, such as selectable colums/width/order, hide/show password, etc.
But to add that to an in-house-developed web framework can be somewhat of a job. I think it is more complicated than implementing BFD.
pe1chl
Wed May 24, 2023 12:00 pm
I don't understand exactly what you guys are complaining about. When you open a table with comments you see the truncated comment, and when you hover the mouse over that it expands into the full comment in a separate pop-up.
Why do you have "no choice to widen"? Does this mouse-hover not work in your browser? I use Firefox and it works there.
fragtion
Wed May 24, 2023 12:46 pm
This.
Right now I need to use this overkill script on schedule (every 10 min) to ensure that the wg tunnel stays alive..:
:local resolvedIP [:resolve "remote.peer.dns.com"];
:local peerparent "wg-interface";
:local peeraddr "jIASJDIasojdIOASJdioasjDIOASJiodjIOASDJASIODJ==";
:local currentPeer [/interface/wireguard/peers/find where interface=$peerparent and public-key=$peeraddr];
:local currentIP [/interface/wireguard/peers/get $currentPeer endpoint-address];
:local currentPort [/interface/wireguard/peers/get $currentPeer endpoint-port]
:if (([:find $currentIP $resolvedIP] < 0) && ([:len $currentPort] > 1)) do={
    /interface/wireguard/peers set $currentPeer endpoint-address=$resolvedIP
    /interface/wireguard/peers disable $currentPeer
    /interface/wireguard disable $peerparent
    /interface/wireguard enable $peerparent
    /interface/wireguard/peers enable $currentPeer
    /log info "Wireguard Peer $peeraddr (under $peerparent) endpoint-address updated from $currentIP to $resolvedIP";
:delay 5
if (([/interface/wireguard/peers/get $currentPeer last-handshake] > 180) || ([:len [/interface/wireguard/peers/get $currentPeer last-handshake]] = 0)) do={
  :local fwrule [/ip/firewall/filter/find where comment=("out-"."$peerparent")]
  if ([:len $fwrule] = 0) do={
    if ([:len $currentPort] > 1) do={ /ip/firewall/filter/add action=drop chain=output comment=("out-"."$peerparent") dst-port=$currentPort protocol=udp }
  } else={
      :local fwport [/ip/firewall/filter/get $fwrule dst-port]
      if ($fwport != $currentPort) do={ /ip/firewall/filter/set $fwrule dst-port=$currentPort }
    } else={ /ip/firewall/filter/remove $fwrule }
  if ([:len $fwrule] > 0) do={
    if ([/ip/firewall/filter/get $fwrule disabled] = true) do={
      /log info "Wireguard Peer $peeraddr (under $peerparent) unresponsive - Temporarily disabling...";
      /ip/firewall/filter/set [find where comment=("out-"."$peerparent")] disabled=no
    } else={
      /log info "Wireguard Peer $peeraddr (under $peerparent) unresponsive - Trying to restore...";
      /ip/firewall/filter/set $fwrule disabled=yes
It will be a great day when we can rely on built-in/native robustness of this and I can delete these scripts :)
Actually I haven't tested if the functionality has changed since early v7 betas (as my script works well for me so didn't need to check), so it would be good to have an answer to OP's question for better clarity
And while commenting, I want to throw in my 2c that inline comments are awesome, so rather an option should be provided in webfig to select preferred option, than revert to old style...
As much as I love winbox, it would be great if someday winbox and webfig are visually and functionally equivalent. This would preclude a need to develop a new winbox that is compatible with MacOS for instance, as we could all use a web app as a replacement for winbox. But right now there are still too many issues with webfig so I always use winbox where possible
mfrommel
Wed May 24, 2023 12:55 pm
There is a "mouse over" feature for the comment:
The waste of space by centering everything annoys me too.
msatter
Wed May 24, 2023 12:56 pm
I am using RoundRobin from the DNS and only restart the peer to have the next IP address to be resolved.
The retry itself was a longtime and many times requested feature and I am pleased that Mikrotik implemented this now.
viewtopic.php?p=908766
viewtopic.php?p=935134
viewtopic.php?p=930695
fragtion
Wed May 24, 2023 1:04 pm
Question not answered about how many times it retries, or if interface still needs to be toggled to re-establish a connection after IP change..
msatter
Wed May 24, 2023 1:10 pm
As long as it fails to resolve, seems to me the way it will work. There is no max times mentioned so it keeps trying......
.....every retry counts as one instance and then it starts again as it was a new detection.
sirbryan
Wed May 24, 2023 1:38 pm
I said "No choice but to widen", as in, I have to widen my browser window, in response to Normis' statement to not widen the browser all the way on ultrawide monitors.
I was not aware of the tooltip, but that's still an extra step to see stuff I'm accustomed to seeing right up front. Tooltips aren't really useful on a phone or tablet, where I use webfig a ton, too.
Again, most people won't notice/don't care about the inline comments change, but when you're in and out of dozens of devices per day, trying to troubleshoot problems, comparing settings, routes, results, etc., any extra work required to find the information, be it mouse-overs or extra taps/clicks or drilling down through menus is time taken away from getting the work done, solving the problem, and restoring service. Every fraction of a second counts.
One example is the DHCP lease tables. I have scripts that go through each of my edge routers (20ish at present) and makes current leases static for use by UISP and traffic shaping. Sometimes I have the customer's full name in the comment field, but more often than not I pull the hostname from the DHCP request. Every single comment entry exceeds the column width, so I see 10 characters out of 20-40, whatever it is. Sure, I can widen the columns or mouseover, but I have to do that for each of my routers. And what might work for my desktop is too large for the laptop and way too much for my phone.
holvoetn
Wed May 24, 2023 1:43 pm
Just tested with mAP on 7.9.1.
Boot without ether1, no wireguard communication.
Insert ether 1. Still nada.
Toggle peer after a while, traffic starts flowing as expected with the bug as we know it.
Upgrade to 7.10b8
Boot without ether1, no wireguard comm (logical 🤦‍♂️).
Insert ether1, a couple of seconds and traffic starts flowing.
So yes, it seems they FINALLY solved that bug.
pe1chl
Wed May 24, 2023 1:46 pm
I would advise you to make (a couple of) API programs to retrieve and view information like that, this is so much more convenient than using webfig or similar!
I do that all the time, also for our Unifi WiFi system. The "modern GUI" environments are unreadable and unusable, but with API you can generate a page in the style you prefer, and it renders in 100ms instead of several seconds.
leonardogyn
Wed May 24, 2023 2:45 pm
No, it's really not the same amount of wasted space, which I clearly showed on some pictures ( viewtopic.php?t=196061#p1002223 ). Please check that.
And again, for laptop users who works with no fix office most of the time, using an ultrawide monitor is really not an option.
ivicask
Wed May 24, 2023 3:30 pm
I cant upgrade my hap ac2 from 7.10 beta 5 to beta 8, after reboot i get
router was rebooted without proper shutdown, probably kernel failure..
Paternot
Forum Veteran
Forum Veteran
Wed May 24, 2023 4:48 pm
Because before it was possible to skim all the comments. Now one have to either widen the field or hover the mouse. Both are worse than the previous case.
And I say this as someone who liked the inline comments. But they DO have this problem.
pe1chl
Wed May 24, 2023 6:55 pm
Well I guess that with any change in any system there will be people claiming it is a problem because their niche use is now no longer possible...
I use a lot of comments, but as I have switched over to winbox quite some time ago (after initially using webfig because I use Linux and did not want to install Windows software), and I have used inline comments ever since then, my comments are always single-line and normally like 40 characters or less. They fit in the column that I allocate for it in winbox.
"general notices" go in the /system note section, where there is room for a lot of prose.
Hopefully MikroTik will develop the webfig framework a bit further, so it can use "site data" (storage for dynamic data from sites similar to cookies) and you thus have the equivalent of a winbox "session file" in webfig. That would open the possibility for user-settable options like "inline comments", "show passwords", "center forms" and of course selectable columns.
Larsa
Wed May 24, 2023 7:04 pm
As an alternative to fix WebFib weirdness, the ViolentMonkey (or GreaseMonkey) might come in handy.
Since the layout in WebFig is quite strict in terms of table layouts and row order, it should be reasonably straightforward to create a function that realigns, resizes or removes comments according to your needs. Also, you might save per-table/session settings and stores them as cookies or in a session database much like Winbox.
sirbryan
Thu May 25, 2023 12:11 am
OK, so after updating several routers to 7.9.1 during tonight's maintenance window, and then losing two AF60LR's this morning to a bad/failed firmware update procedure, I had to use my phone while in the field to get the replacement Wave LR's online. The routers at the two sites involved in the outage have 7.10b8 (was hoping to test BFD, but then read that it's for BGP-only, not OSPF), and I had to browse into them to verify the radio link had returned.
Anyway, the new mechanism for handling tables is horrible when used on a phone browser. I don't know if it's a scrollable DIV or an iframe or what (I haven't looked at the underlying HTML--not something you do while restoring from an outage), but I was having a heck of a time trying to zoom, then scroll to find the DHCP-assigned address for the new radio. Normally I can browse into any router or radio and move around the page with ease. But as of 7.10, something is screwy and that table slides back and forth under the items on the left, and pinch zooming is nigh impossible. Maybe I should just make a video of it.
Needless to say it was frustrating since it took 2-3x as long to accomplish the task today.
ZupoLlask
Thu May 25, 2023 2:13 am
I think the video may be useful to defend your case... 😉
buset1974
Thu May 25, 2023 8:01 am
Bgp prefix count work now, not realtime but is ok for now.
Hope in 7.10, show bgp advertise also fixed.
Before both work i will not upgrade my production router.
Long wait
Thx
massinia
Thu May 25, 2023 9:49 am
I just updated and there is no problem with hap ac2.
pe1chl
Thu May 25, 2023 10:31 am
Indeed I also update a hAP ac2 without problems, but on that device the flash memory space is getting very tight.
When you have put files of your own on the device, remove them. When you have installed extra stuff like user-manager, remove it (move to some other device).
When you have done upgrade after upgrade, it may be required to do a netinstall. Export the config and download it beforehand, when you have a lot of special things on it.
When not, just netinstall it, put the defaults, and work from there.
Rox169
Thu May 25, 2023 2:27 pm
I had another error login with WiFi on this 7.10beta8. It has been reported as SUP-116195. Mobile can not join WiFi mobile say the password is not correct and after reboot all is OK and mobile can join the WiFi without any chage. Im using only WPA/WPA2. I will go back to ROS7.8..
volkirik
Thu May 25, 2023 2:33 pm
same here. i can confirm the bug.
ivicask
Thu May 25, 2023 2:38 pm
I guess i just need to buy new device, i dont have anything special installed and i did neinstall few months ago...
Rox169
Thu May 25, 2023 2:40 pm
it is very sad to see that MT is still selling devices with 16MB of storage. I think we will cat a lot of device without support soon.
volkirik
Thu May 25, 2023 2:43 pm
16 mb flash chips should be cheaper than 32 mb. they count each and every penny
sad, but it is trading. if it is working, they will use it.
pe1chl
Thu May 25, 2023 3:09 pm
Did you do backup before the netinstall and restore afterwards? Don't do that!
Use export/import when you really need to transport some config. Better is to use default settings and do manual reconfig.
I have a hAP ac2 configured as an AP in bridge mode and it has about 1MB free. Still not a comfortable situation, of course!
I think there is another issue at the 16MB boundary where going beyond that capacity requires extra I/O lines from the processor which may not be available because they are used for something else, e.g. LEDs or buttons.
Rox169
Thu May 25, 2023 4:07 pm
This is dilema...ROS 7.9.1,ROS 7.10beta8 contains wifi bug which keeps mobile disconected but they also contains fix for CVE-2023-32154. I can only use 7.8 for stable wifi but without fix for CVE-2023-32154. MT please issue the fix as soon as possible.
pe1chl
Thu May 25, 2023 4:09 pm
CVE-2023-32154 will not affect most people.
mkx
Thu May 25, 2023 4:13 pm
Another possibility: use two devices. One running newest ROS version as border gateway (which is realistically the target for CVE-2023-32154 related attacks) and the other running whatever ROS version works for your wireless (and doesn't have to accept RAs because you use IPv4 for management) ...
pe1chl
Thu May 25, 2023 5:06 pm
In a reasonably configured ISP network, no device at all would require to receive RAs. If it uses that, it will get only a /64 and you will run into problems when routing a local network anyway.
(as demonstrated by the people here who write "my ISP gives me only a /64")
Even when you really need RA to get an IPv6 address from the ISP (or more correctly: the prefix and gateway), you still are not likely to be vulnerable because attacks would have to come from the ISP router itself, not the internet. And of course they could come from the devices on your LAN, because RA enable cannot be configured per interface.
So when you more or less can trust your own devices, the risk of attack is not very high, and for most people it can be zero when they did not tinker with their IPv6 settings.
Znevna
Thu May 25, 2023 5:52 pm
But this fix for an issue that nobody in my network can/will exploit is more important than stable WiFi, please understand. /sarcasm
mkx
Thu May 25, 2023 6:56 pm
How so?
One of ISPs around here are delivering internet "natively". So the router is configured to request a prefix using DHCPv6 client (ISP is handing out sensibly large /56 prefixes). And then router receives its upstream gateway via RAs (sent out by ISP's router; BTW, it's a link-local address as it should be). How would things work without the later? (Without relying on iffy "add default route" feature of MT's DHCPv6 client)?
Another ISP uses PPPoE and with that one reception of RAs is indeed not needed.
pe1chl
Thu May 25, 2023 8:02 pm
When using DHCPv6, the router can get its gateway via that. Nothing iffy about that. It does not need a RA receiver to receive a link-local address, that is assigned automatically derived from the MAC. The RA receiver is only required to set a global address on the link, which isn't required as you correctly indicate.
The only thing iffy is when routers are configured to get their default gateway both via PPPoE and DHCPv6. And unfortunately most "standard recipes on the internet" tell you to do that.
pe1chl
Thu May 25, 2023 8:08 pm
In v6 the BFD logged messages using the facility "bfd". So I added that to the logging to get informative messages about bfd dead link detection.
In the current version it does not seem to log anything, neither from bfd nor from bgp. I only see the lower uptime of the BGP session (and that only after hitting F5).
Please add some logging or document how logging can be enabled/seen in the current version.
mkx
Thu May 25, 2023 8:22 pm
I'm trying to find a reference to a document describing how DHCPv6 distributes gateway information ... but could not find any such document. The best I could find is some 10+ years old draft proposal for DHCPv6 extension which doesn't seem to be finished nor accepted as formal RFC.
anav
Thu May 25, 2023 10:17 pm
@EdPa Reference this item I missed the first time reading thru. - *) wireguard - retry "endpoint-address" DNS query on failed resolve
First thanks for listening and actually responding to input. Now just do the same for zerotier Cloudflare tunnel as an options package! :-)
Does this replace the need for scripts, to keep wireguard running not stuck, in case the "Server" is in the middle of an IP change, or power interruption etc............ and its taking some time to resolve the IP address??
Larsa
Thu May 25, 2023 10:40 pm
I only see the lower uptime of the BGP session (and that only after hitting F5). Please add some logging or document how logging can be enabled/seen in the current version.
We noticed the same thing while running some lab tests. It doesn't have to be a detailed user guide, just a very brief summary would be enough to start with.
rpingar
Long time Member
Long time Member
Thu May 25, 2023 10:46 pm
prefixcount about ipv6 sessions go grazy after a while
EdPa
Fri May 26, 2023 1:09 pm
RouterOS v7.10rc1 has been released
viewtopic.php?t=196500
Users browsing this forum: emunt6, Majestic-12 [Bot] and 19 guests
