blingblouw
Atheros 8227 - Port-Isolation
Wed May 10, 2023 12:39 pm
https://help.mikrotik.com/docs/display/ ... tisolation
According to the docs, if you're using vlan-mode secure, fallback etc then you should create a switch rule with a new-dst-ports, however if you try do that, the switch complains that it is not supported.
/interface ethernet switch rule> add ports=ether2,ether3,ether4,ether5 new-dst-ports=ether1  switch=switch1
failure: not supported for this switch
So how do you enable port-isolation using this switch chip?
blingblouw
Re: Atheros 8227 - Port-Isolation
Fri May 12, 2023 11:38 am
anyone know?
rextended
Fri May 12, 2023 12:01 pm
anyone know?
What is your device? RouterOS version?
Provide everytime details.
You are sure that the device have one Atheros8227 ???
blingblouw
Fri May 12, 2023 1:58 pm
Yes, I'm sure it is. Thats what the router shows
[admin@Switch-1-2] > sys routerboard print
       routerboard: yes
        board-name: PowerBOX
             model: RouterBOARD 750P r2
     serial-number: 5BBC052DEA60
     firmware-type: qca9531L
  factory-firmware: 3.22
  current-firmware: 3.22
  upgrade-firmware: 6.48.6
[admin@Switch-1-2] > interface ethernet switch print
Flags: I - invalid
 #   NAME                                                         TYPE             MIRROR-SOURCE                                                       MIRROR-TARGET                                                       SWITCH-ALL-PORTS
 0   switch1                                                      Atheros-8227     none        none
[admin@Switch-1-2] > interface ethernet switch rule add ports=ether1,ether2,ether3,ether5 new-dst-ports=ether4
switch: switch1
Running 6.48.6 (long-term)
rextended
Fri May 12, 2023 2:33 pm
Uh.... upgrade firmware with
/sys rou upgrade
Because your device still use the old 3.22
Can be the problem.
Your device is supposed to support such feature.
If not work the update, contact directly support@mikrotik.com
chechito
Fri May 12, 2023 10:42 pm
rules not supported on that switch
you must use
/interface ethernet switch port-isolation
Users browsing this forum: Bing [Bot], GoogleOther [Bot], johnson73, miks and 80 guests
