danieltnc1981
FailOver Mikrotik
Wed May 10, 2023 11:50 pm
Good evening everyone
I have a problem
My failover doesn't work, or rather it works partially
Here is my configuration
WAN 1 - 192.168.1.X/24
WAN 2 - 192.168.220.X/24
LAN - 192.168.88.X
On WAN 1 I have an ADSL modem
On Wan 2 I have a 4g modem
These are the set routes
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 AS ;;; Primary WAN1
0.0.0.0/0 8.8.8.8 1
1 SD 0.0.0.0/0 192.168.1.1 1
2S ;;; Secondary WAN2
0.0.0.0/0 192.168.220.1 2
3 AS ;;; Validate Primary
8.8.8.8/32 192.168.1.1 1
4 ADCs 192.168.1.0/24 192.168.1.9 ether1 0
5 ADC 192.168.88.0/24 192.168.88.1 bridge 0
6 ADCs 192.168.220.0/24 192.168.220.10 ether2 0
The problem is as follows
If I unplug the WAN 1 cable on the mikrotik manually then it automatically switches to WAN 2
If instead I disconnect the ADSL cable on the modem of wan 1 the switch does not work
Where am I wrong?
Looking forward to your suggestions
anav
Re: FailOver Mikrotik
Thu May 11, 2023 12:52 am
Is what I would attempt to config.............
add distance=5 check-gateway=ping dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=10 target-scope=12
add dst-address=8.8.8.8 gateway=192.168.1.1 routing-table=main scope=10 target-scope=11
add distance-10 dst-address=0.0.0.0/0 gateway=192.168.220.1 routing-table=main
As for your issue, concur it seems to make no sense. Either way the router is not getting a signal on the WAN port.
Users browsing this forum: No registered users and 59 guests
