rextended
AX: Since reg-info, on v7.9 and lower, produce only "failure: not implemented" I make these tables for all...
Thu May 11, 2023 11:43 am
On 7.10beta5 is implemented, but on meantime...
Currently there is a discrepancy between the settable values and in RouterOS, I hope they fix it sooner or later...
For each country, it is possible that depending on the chosen frequency, DFS may or may not be used and a lower power may be allowed.
The one indicated is the maximum possible (usually at 5825 if allowed from the country).
hAP ax³ RouterOS 7.9 5GHz
Frequencies that RouterOS consider on 5GHz band (all allowed from software, for each specific country see the table)
5180 5200 5220 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825
see next posts for REAL TX Power
Actual FULL Power and Channels and NO DFS winners:
(based on successive post RAW values...)
30 indoor AND outdoor NO DFS on interval 5170-5250
Canada
5180 5200 5220 5240 5260 5280 5300 5320 - 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 - 5745 5765 5785 5805 5825
36 indoor AND outdoor NO DFS on interval 5250-5330 and 5490-5590
Argentina or Mexico
24 indoor AND outdoor NO DFS on interval 5590-5650
Malaysia
5180 5200 5220 5240 5260 5280 5300 5320 - 5500 5520 5540 5560 5580 5600 5620 5640 56605680 5700 5720 - 5745 5765 5785 5805 5825
30 indoor AND outdoor WITH DFS on interval 5590-5650
Australia
36 indoor AND outdoor NO DFS on interval 5650-5730
Argentina or Mexico
36 indoor AND outdoor NO DFS on interval 5735-5835
Australia
Out of band, unsupported from the chipset:
4940-4990 [4950, 4960, 4970, 4980] @33 indoor AND outdoor NO DFS American Samoa, Guam, Northern Mariana Islands, Puerto Rico, Virgin Islands
5825-5895 [5835, 5845, 5855, 5865, 5875, 5885] @30 indoor AND outdoor NO DFS Barbados, Canada, Uruguay, Venezuela
5850-5900 [5860, 5870, 5880, 5890] @30 indoor AND outdoor NO DFS Philippines, Ukraine
5910-5925 and 5922-5932 useless for 20Mhz for Philippines, Ukraine
rextended
Re: AX: Since reg-info, on v7.10beta5 and lower, produce only "failure: not implemented" I make these tables for all...
Thu May 11, 2023 11:50 am
hAP ax³ RouterOS 7.9 2,4GHz
Frequencies that RouterOS consider on 2,4GHz band (all allowed from software, for each specific country see the table)
2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472
Since 2484 is Japan only 802.11b, and the "b" is no longer supported (finally), the 2484 is not available, neither on Japan.
Actual FULL Power and Channels winner:
36
Papua New Guinea
holvoetn
Thu May 11, 2023 12:43 pm
Frequencies that RouerOS consider on 5GHz band (all allowed from software, for each specific country see the table)
Small typo (or copy/paste error).
2.4GHz band.
rextended
Thu May 11, 2023 12:45 pm
Yes thanks :P
holvoetn
Re: AX: Since reg-info, on v7.9 and lower, produce only "failure: not implemented" I make these tables for all...
Thu May 11, 2023 12:48 pm
And RouerOS on both posts -> RouterOS :lol:
rextended
Thu May 11, 2023 12:49 pm
Rox169
Thu May 11, 2023 12:57 pm
thanks for effort but this is not helping a lot. For example in the Czech rep. you have 30 Dbi but it depends on chosen channel. Some channels are with 30 Dbi but some with 22Dbi.
rextended
Thu May 11, 2023 1:00 pm
Is not finished ;)
Only the 2,4GHz.... ;)
rextended
Thu May 11, 2023 2:18 pm
RAW Table, but it is unused:
ROuterOS v7.10rc5 code
Afghanistan
  ranges: 2402-2482/20
          5170-5250/23
          5250-5330/23/dfs
Aland Islands
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Albania
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Algeria
          5170-5250/23
          5250-5330/23/dfs
          5735-5835/33
American Samoa
  ranges: 2402-2472/30
          4940-4990/33
Andora
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Anguilla
          5170-5250/23
          5250-5330/23/dfs
Antigua and Barbuda
(empty)
Argentina
  ranges: 2402-2482/30
          5170-5250/23
          5250-5330/36
          5490-5590/36
          5650-5730/36
          5735-5835/30
Armenia
          5170-5250/20
          5250-5330/20/dfs
          5735-5835/20
Aruba
          5170-5250/23
          5250-5330/23/dfs
Australia
          5170-5250/23/indoor
          5250-5330/23/indoor/dfs
          5490-5730/30/dfs
          5735-5835/36
Austria
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Azerbaijan
          5170-5250/23
          5250-5330/23/dfs
          5490-5710/24/dfs
          5735-5835/24
Azerbaijan
          5170-5250/23
          5250-5330/23/dfs
          5490-5710/24/dfs
          5735-5835/24
Bahamas
(empty)
Bahrain
          5170-5250/17
          5250-5330/24
          5490-5590/24
          5650-5730/24
          5735-5835/30
Bangladesh
          5735-5815/20
Barbados
          5170-5250/24
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5895/30
Belarus
          5170-5250/23
          5250-5330/23/dfs
Belgium
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Belize
          5170-5250/23
          5250-5330/23/dfs
          5490-5710/24/dfs
          5735-5835/24
Bermuda
(empty)
Bhutan
          5170-5250/23
          5250-5330/23/dfs
Bolivia
(empty)
Bosnia and Herzegovina
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Brazil
(empty)
British Virgin Islands
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Brunei Darussalam
(empty)
Bulgaria
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Burkina Faso
(empty)
Cambodia
          5170-5250/23
          5250-5330/23/dfs
Cameroon
          5170-5250/23
          5250-5330/23/dfs
Canada
          5170-5250/30
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5895/30
Cayman Islands
(empty)
Central Africa Republic
(empty)
Chad
          5170-5250/23
          5250-5330/23/dfs
Chile
(empty)
China
          5170-5250/23/indoor
          5250-5330/23/indoor
          5735-5835/33
Christmas Island
          5170-5250/23/indoor
          5490-5730/30/dfs
          5735-5835/36
Colombia
(empty)
Cook Islands
          5170-5250/17/indoor
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5835/30
Costa Rica
(empty)
Croatia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Cyprus
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Czech
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Denmark
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Dominica
          5170-5250/23
          5250-5330/23/dfs
          5735-5835/30
Dominican Republic
(empty)
Ecuador
(empty)
Egypt
          5170-5250/18
          5250-5330/18/dfs
El Salvador
(empty)
Estonia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Ethiopia
          5170-5250/23
          5250-5330/23/dfs
Falkland Islands
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Faroe Islands
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Finland
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
France
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
French Guiana
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
French Polynesia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
French Southern Territories
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Georgia
          5170-5250/23
          5250-5330/23/dfs
Germany
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Ghana
(empty)
Gibraltar
          5170-5250/23
          5250-5330/23/dfs
Greece
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Greenland
          5170-5250/23
          5250-5330/23/dfs
Grenada
(empty)
Guadeloupe
          5170-5250/23
          5250-5330/23/dfs
Guam
          4940-4990/33
Guatemala
          5170-5250/23/indoor
          5490-5730/30/dfs
          5735-5835/33
Guernsey
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Guyana
          5735-5815/20
Haiti
(empty)
Heard Island and McDonald Islands
          5170-5250/23/indoor
          5490-5730/30/dfs
          5735-5835/36
Holy See
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Honduras
(empty)
Hong Kong
(empty)
Hungary
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Iceland
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
India
          5170-5250/23/indoor
          5490-5730/30/dfs
          5735-5835/33
Indonesia
(empty)
Iraq
          5170-5250/23
          5250-5330/23/dfs
Ireland
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Isle of Man
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Israel
          5735-5835/30
Italy
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Ivory Coast
(empty)
Jamaica
(empty)
Japan
(empty)
Jersey
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Jordan
          5170-5250/20
          5250-5330/20/dfs
          5735-5835/20
Kazakhstan
  ranges: 2402-2482/23
          5170-5250/23/indoor
          5490-5710/23/dfs
Kenya
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Kuwait
          5170-5250/23
          5250-5330/23/dfs
Latvia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Lebanon
(empty)
Lesotho
          5170-5250/23
          5250-5330/23/dfs
Liechtenstein
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Lithuania
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Luxembourg
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Macau
(empty)
Macedonia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Malawi
          5170-5250/23
          5250-5330/23/dfs
Malaysia
          5170-5330/24
          5250-5330/24
          5490-5730/24
          5735-5835/30
Maldives
          5250-5330/30/dfs
          5735-5835/30
Malta
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Marshall Islands
(empty)
Martinique
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Mauritania
          5170-5250/23
          5250-5330/23/dfs
Mauritius
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Mayotte
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Mexico
          5170-5250/23
          5250-5330/36
          5490-5590/36
          5650-5730/36
          5735-5835/30
Micronesia
(empty)
Moldova
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Monaco
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Mongolia
(empty)
Montenegro
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Montserrat
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Morocco
          5170-5250/18
          5250-5330/18/dfs
Myanmar
          5735-5815/20
Namibia
(empty)
Nepal
(empty)
Netherlands
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Netherlands Antilles
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
New Caledonia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
New Zealand
          5170-5250/17/indoor
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5835/30
Nicaragua
Nigeria
          5250-5330/30/dfs
          5735-5835/30
Niue
          5170-5250/17/indoor
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5835/30
Norfolk Island
          5170-5250/23/indoor
          5490-5730/30/dfs
          5735-5835/36
          4940-4990/33
Norway
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Oman
          5170-5250/23
          5250-5330/23/dfs
Pakistan
          5735-5815/20
Palau
(empty)
Panama
(empty)
Papua New Guinea
(empty)
Paraguay
(empty)
Peru
(empty)
Philippines
          5170-5250/20/indoor
          5250-5330/20/indoor/dfs
          5490-5710/27/dfs
          5850-5900/30
          5910-5925/30
          5922-5932/30
Poland
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Portugal
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Puerto Rico
          4940-4990/33
Qatar
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/30/dfs
          5735-5815/30/dfs
Reunion
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Romania
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Rwanda
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Saint Barthelemy
          5170-5250/23
          5250-5330/23/dfs
Saint Kitts and Nevis
          5170-5250/30
          5250-5330/30/dfs
          5490-5710/30/dfs
          5735-5875/30
Saint Lucia
          5170-5250/30
          5250-5330/30/dfs
          5490-5710/30/dfs
          5735-5875/30
Saint Martin
          5170-5250/23
          5250-5330/23/dfs
Saint Pierre and Miquelon
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Saint Vincent and the Grenadines
          5170-5250/23
          5250-5330/23/dfs
Samoa
          5170-5250/23
          5250-5330/23/dfs
San Marino
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Sao Tome and Principe
(empty)
Saudi Arabia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Senegal
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Serbia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Singapore
(empty)
Sint Maarten
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Slovakia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Slovenia
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
South Africa
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
South Korea
(empty)
Spain
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Sri Lanka
          5170-5250/16
          5735-5875/14
Suriname
          5170-5250/23
          5250-5330/23/dfs
Svalbard and Jan Mayen
          5170-5250/23
          5250-5330/23/dfs
Sweden
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Switzerland
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Taiwan
(empty)
Tanzania
          5170-5250/16
          5735-5875/14
Thailand
(empty)
Togo
          5170-5250/23
          5250-5330/23/dfs
Trinidad and Tobago
(empty)
Tunisia
          5170-5250/18
          5250-5330/18/dfs
Turkey
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Turks and Caicos
(empty)
Uganda
(empty)
Ukraine
          5170-5250/20/indoor
          5490-5710/27/dfs
          5850-5900/30
          5910-5925/30
          5922-5932/30
United Arab Emirates
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
United Kingdom
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
United States
          5170-5250/30
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5835/30
United States Minor Outlying Islands
          5170-5250/30
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5835/30
Uruguay
          5170-5250/24
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5895/30
Uzbekistan
          5170-5250/18
          5250-5330/18/dfs
Vanuatu
(empty)
Venezuela
          5170-5250/24
          5250-5330/24/dfs
          5490-5730/24/dfs
          5735-5895/30
Viet Nam
          5170-5250/16
          5735-5875/14
Virgin Islands
          4940-4990/33
Wallis and Futuna
          5170-5250/23
          5250-5330/23/dfs
Yemen
          5170-5250/23
          5250-5330/23/dfs
Zimbabwe
          5170-5250/23
          5250-5330/23/dfs
rextended
Thu May 11, 2023 4:27 pm
If one country is not present on one or more of these list, is because do not support that channel.
REAL TX power @5180 (ignoring antenna gain)
11
Argentina, Mexico, Nicaragua
14
Maldives, Nepal, Nigeria
17
Afghanistan, Aland Islands, Albania, Algeria, Andora, Anguilla, Armenia, Aruba, Australia, Austria, Azerbaijan, Bahrain, Belarus,
Belgium, Belize, Bhutan, Bosnia and Herzegovina, British Virgin Islands, Bulgaria, Cambodia, Cameroon, Canada, Chad, China,
Christmas Island, Cook Islands, Croatia, Cyprus, Czech, Denmark, Dominica, Egypt, Estonia, Ethiopia, Falkland Islands,
Faroe Islands, Finland, France, French Guiana, French Polynesia, French Southern Territories, Georgia, Germany, Gibraltar,
Greece, Greenland, Guadeloupe, Guernsey, Heard Island and McDonald Islands, Holy See, Hong Kong, Hungary, Iceland, Indonesia,
Iraq, Ireland, Isle of Man, Israel, Italy, Japan, Jersey, Jordan, Kazakhstan, Kenya, Kuwait, Latvia, Lesotho, Liechtenstein,
Lithuania, Luxembourg, Macedonia, Malawi, Malta, Martinique, Mauritania, Mauritius, Mayotte, Moldova, Monaco, Montenegro,
Montserrat, Morocco, Namibia, Netherlands, Netherlands Antilles, New Caledonia, New Zealand, Niue, Norfolk Island, Norway, Oman,
Philippines, Poland, Portugal, Qatar, Reunion, Romania, Rwanda, Saint Barthelemy, Saint Helena,
Ascension and Tristan da Cunha, Saint Kitts and Nevis, Saint Lucia, Saint Martin, Saint Pierre and Miquelon,
Saint Vincent and the Grenadines, Samoa, San Marino, Saudi Arabia, Senegal, Serbia, Singapore, Sint Maarten, Slovakia, Slovenia,
South Africa, South Korea, Spain, Sri Lanka, Suriname, Svalbard and Jan Mayen, Sweden, Switzerland, Tanzania, Thailand, Togo,
Tunisia, Turkey, Ukraine, United Arab Emirates, United Kingdom, Uzbekistan, Viet Nam, Wallis and Futuna, Yemen, Zimbabwe
18
Chile, Jamaica
23
American Samoa, Antigua and Barbuda, Bahamas, Barbados, Bermuda, Bolivia, Brazil, Brunei Darussalam, Burkina Faso,
Cayman Islands, Central Africa Republic, Colombia, Costa Rica, Dominican Republic, Ecuador, El Salvador, Ghana, Grenada,
Guam, Guatemala, Haiti, Honduras, India, Ivory Coast, Lebanon, Macau, Malaysia, Marshall Islands, Micronesia, Mongolia,
Northern Mariana Islands, Palau, Panama, Papua New Guinea, Paraguay, Peru, Puerto Rico, Sao Tome and Principe, Taiwan,
Trinidad and Tobago, Turks and Caicos, Uganda, United States, United States Minor Outlying Islands, Uruguay, Vanuatu,
Venezuela, Virgin Islands
REAL TX power @5260 (ignoring antenna gain)
14
Malta, Nepal, Netherlands, Niue
16
Azerbaijan, Belarus, Belgium, Belize, Bhutan, Bosnia and Herzegovina, British Virgin Islands, Bulgaria, Cambodia, Cameroon,
Chad, China, Christmas Island, Cook Islands, Croatia, Cyprus, Czech, Denmark, Egypt, Estonia, Ethiopia, Falkland Islands,
Iraq, Ireland, Isle of Man, Israel, Italy, Japan, Jersey, Kazakhstan, Kenya, Kuwait, Latvia, Lesotho, Liechtenstein, Lithuania,
Luxembourg, Macedonia, Malawi, Maldives, Martinique, Mauritania, Mauritius, Mayotte, Moldova, Monaco, Montenegro, Montserrat,
Morocco, Namibia, Netherlands Antilles, New Caledonia, New Zealand, Nigeria, Norfolk Island, Norway, Oman, Philippines, Poland,
Portugal, Qatar, Reunion, Romania, Rwanda, Saint Barthelemy, Saint Kitts and Nevis, Saint Lucia, Saint Martin,
Saint Pierre and Miquelon, Saint Vincent and the Grenadines, Samoa, San Marino, Saudi Arabia, Senegal, Serbia, Singapore,
Sint Maarten, Slovakia, Slovenia, South Africa, South Korea, Spain, Sri Lanka, Suriname, Svalbard and Jan Mayen,
Sweden, Switzerland, Tanzania, Thailand, Togo, Tunisia, Turkey, Ukraine, United Arab Emirates, United Kingdom, Uzbekistan,
17
Afghanistan, Aland Islands, Albania, Algeria, American Samoa, Andora, Anguilla, Antigua and Barbuda, Aruba, Australia,
Austria, Bahamas, Bahrain, Barbados, Bermuda, Bolivia, Brazil, Brunei Darussalam, Burkina Faso, Canada, Colombia, Costa Rica,
Dominica, El Salvador, Ghana, Grenada, Guam, Haiti, Honduras, India, Ivory Coast, Lebanon, Macau, Malaysia, Marshall Islands,
Mongolia, Nicaragua, Northern Mariana Islands, Palau, Puerto Rico, Saint Helena, Ascension and Tristan da Cunha,
Sao Tome and Principe, Taiwan, Trinidad and Tobago, Turks and Caicos, United States, Vanuatu, Virgin Islands
18
Argentina, Chile, Jamaica, Mexico, Micronesia, Panama, Papua New Guinea
20
Cayman Islands, Central Africa Republic, Dominican Republic, Ecuador, Guatemala, Paraguay, Peru, Uganda,
United States Minor Outlying Islands, Uruguay, Venezuela
rextended
Thu May 11, 2023 5:30 pm
REAL TX power @5600 (ignoring antenna gain)
14
Reunion
17
American Samoa, Jersey, Kenya
18
Chile, Colombia, Guernsey, Iraq, Jamaica, Japan, Niue, Panama, Papua New Guinea, Poland, United Arab Emirates
20
Antigua and Barbuda, Bahamas, Bermuda, Bolivia, Brazil, Brunei Darussalam, Burkina Faso, Cayman Islands, Central Africa Republic,
Costa Rica, Dominican Republic, Ecuador, El Salvador, Ghana, Grenada, Guam, Guatemala, Haiti, Honduras, India, Ivory Coast,
Lebanon, Macau, Malaysia, Marshall Islands, Micronesia, Mongolia, Nicaragua, Northern Mariana Islands, Palau, Paraguay, Peru,
Puerto Rico, Sao Tome and Principe, Taiwan, Trinidad and Tobago, Turks and Caicos, Uganda, United States,
United States Minor Outlying Islands, Vanuatu, Virgin Islands
23
Afghanistan, Aland Islands, Albania, Algeria, Andora, Anguilla, Aruba, Austria, Azerbaijan, Belarus, Belgium, Belize, Bhutan,
Bosnia and Herzegovina, British Virgin Islands, Bulgaria, Cambodia, Cameroon, Chad, Cook Islands, Croatia, Cyprus, Czech,
Denmark, Estonia, Ethiopia, Falkland Islands, Faroe Islands, Finland, France, French Guiana, French Polynesia,
French Southern Territories, Georgia, Germany, Gibraltar, Greece, Greenland, Guadeloupe, Holy See, Hong Kong, Hungary,
Iceland, Ireland, Isle of Man, Israel, Italy, Kazakhstan, Kuwait, Latvia, Lesotho, Liechtenstein, Lithuania, Luxembourg,
Macedonia, Malawi, Malta, Martinique, Mauritania, Mauritius, Mayotte, Moldova, Monaco, Montenegro, Montserrat, Namibia,
Netherlands, Netherlands Antilles, New Caledonia, New Zealand, Norway, Oman, Philippines, Portugal, Qatar, Romania, Rwanda,
Saint Barthelemy, Saint Helena, Ascension and Tristan da Cunha, Saint Kitts and Nevis, Saint Lucia, Saint Martin,
Sint Maarten, Slovakia, Slovenia, South Africa, South Korea, Spain, Sri Lanka, Suriname, Svalbard and Jan Mayen, Sweden,
Switzerland, Tanzania, Thailand, Togo, Turkey, Ukraine, United Kingdom, Viet Nam, Wallis and Futuna, Yemen, Zimbabwe
REAL TX power @5825 (ignoring antenna gain)
8
Albania, Andora, Armenia, Australia, Austria, Azerbaijan, Bangladesh, Belgium, Belize, Bosnia and Herzegovina,
British Virgin Islands, Bulgaria, Christmas Island, Cook Islands, Croatia, Cyprus, Czech, Denmark, Estonia, Falkland Islands,
Faroe Islands, Finland, France, French Guiana, French Polynesia, French Southern Territories, Germany, Greece, Guernsey,
Guyana, Heard Island and McDonald Islands, Holy See, Hong Kong, Hungary, Iceland, Ireland, Isle of Man, Israel, Italy, Jersey,
Jordan, Kenya, Latvia, Liechtenstein, Lithuania, Luxembourg, Macedonia, Maldives, Malta, Martinique, Mauritius, Mayotte, Moldova,
Monaco, Montenegro, Montserrat, Myanmar, Namibia, Nepal, Netherlands, Netherlands Antilles, New Caledonia, New Zealand, Nigeria,
Niue, Norfolk Island, Norway, Pakistan, Philippines, Poland, Portugal, Qatar, Reunion, Romania, Rwanda,
Saint Pierre and Miquelon, San Marino, Saudi Arabia, Senegal, Serbia, Singapore, Sint Maarten, Slovakia, Slovenia, South Africa,
Spain, Sweden, Switzerland, Thailand, Turkey, Ukraine, United Arab Emirates, United Kingdom
23
China, South Korea
24
Argentina, Chile, Guatemala, India, Jamaica, Malaysia, Mexico, Nicaragua, Panama
27
Bahrain
28
American Samoa, Antigua and Barbuda, Bahamas, Barbados, Bermuda, Bolivia, Brazil, Brunei Darussalam, Burkina Faso, Canada,
Cayman Islands, Central Africa Republic, Colombia, Costa Rica, Dominica, Dominican Republic, Ecuador, El Salvador, Ghana,
Grenada, Guam, Haiti, Honduras, Ivory Coast, Lebanon, Macau, Marshall Islands, Micronesia, Mongolia, Northern Mariana Islands,
Palau, Papua New Guinea, Paraguay, Peru, Puerto Rico, Sao Tome and Principe, Taiwan, Trinidad and Tobago, Turks and Caicos,
Uganda, United States, United States Minor Outlying Islands, Uruguay, Vanuatu, Venezuela, Virgin Islands
rextended
Thu May 11, 2023 5:49 pm
REAL TX power @2437 (ignoring antenna gain)
16
Afghanistan, Aland Islands, Albania, Algeria, Andora, Anguilla, Antigua and Barbuda, Argentina, Armenia, Aruba, Australia,
Austria, Azerbaijan, Bahamas, Bahrain, Bangladesh, Barbados, Belarus, Belgium, Belize, Bhutan, Bolivia, Bosnia and Herzegovina,
Brazil, British Virgin Islands, Brunei Darussalam, Bulgaria, Burkina Faso, Cambodia, Cameroon, Cayman Islands,
Central Africa Republic, Chad, Chile, China, Christmas Island, Cook Islands, Costa Rica, Croatia, Cyprus, Czech, Denmark,
Egypt, El Salvador, Estonia, Ethiopia, Falkland Islands, Faroe Islands, Finland, France, French Guiana, French Polynesia,
French Southern Territories, Georgia, Germany, Ghana, Gibraltar, Greece, Greenland, Guadeloupe, Guatemala, Guernsey, Guyana,
Heard Island and McDonald Islands, Holy See, Honduras, Hong Kong, Hungary, Iceland, India, Indonesia, Iraq, Ireland,
Isle of Man, Israel, Italy, Ivory Coast, Jamaica, Jersey, Jordan, Kenya, Kuwait, Latvia, Lebanon, Lesotho, Liechtenstein,
Lithuania, Luxembourg, Macau, Macedonia, Malawi, Malaysia, Maldives, Malta, Martinique, Mauritania, Mauritius, Mayotte, Mexico,
Moldova, Monaco, Mongolia, Montenegro, Montserrat, Morocco, Myanmar, Namibia, Nepal, Netherlands, Netherlands Antilles,
New Caledonia, New Zealand, Nigeria, Niue, Norfolk Island, Norway, Oman, Pakistan, Papua New Guinea, Paraguay, Peru,
Saint Vincent and the Grenadines, Samoa, San Marino, Sao Tome and Principe, Saudi Arabia, Senegal, Serbia, Singapore,
Sint Maarten, Slovakia, Slovenia, South Africa, Spain, Sri Lanka, Suriname, Svalbard and Jan Mayen, Sweden, Switzerland,
Tanzania, Thailand, Togo, Trinidad and Tobago, Tunisia, Turkey, Turks and Caicos, Uganda, Ukraine, United Arab Emirates,
United Kingdom, Uruguay, Uzbekistan, Vanuatu, Venezuela, Viet Nam, Wallis and Futuna, Yemen, Zimbabwe
18
Japan, Kazakhstan, South Korea
27
American Samoa, Bermuda, Canada, Colombia, Dominica, Dominican Republic, Ecuador, Grenada, Guam, Haiti, Marshall Islands, Micronesia, Nicaragua,
Northern Mariana Islands, Palau, Panama, Puerto Rico, Taiwan, United States, United States Minor Outlying Islands, Virgin Islands
ToTheFull
Thu May 11, 2023 6:14 pm
Thanks, very useful!
rextended
Thu May 11, 2023 6:19 pm
Thanks, added the 2,4GHz 2437 test.
rextended
Thu May 11, 2023 7:16 pm
Added 5260 test on previous post
rextended
Thu May 11, 2023 8:04 pm
Added the last 5600 and now I think are all most important tests present.
Users browsing this forum: Bing [Bot], Google [Bot] and 68 guests
