CzarnyLewis
SXT LTE6 kit - place for second cable
Fri May 12, 2023 1:48 pm
I bought this device and everything works fine. But I needed two Ethernet ports, but from what I can see there is only one cable pass.
Did the manufacturer really not provide two places for the passage of Ethernet cables?
Photos in attach.
massinia
Re: SXT LTE6 kit - place for second cable
Fri May 12, 2023 1:58 pm
Yes, you have to stretch the hole slightly to pass the second cable.
Better a hole to stretch when needed than insects inside, said a wise old man :lol:
holvoetn
Fri May 12, 2023 3:41 pm
Most of the times that device will be used with only one cable.
So yes, for the second cable you need to cut a bit out of the closing lip.
It is foreseen on the inside (plastic is a lot thinner there). Directly to the right of where your picture shows the cable.
I just checked: my SXT LTE was hanging out in France for well over a year (sold the place last year november). I just noticed tiny spiders still managed to create some cobwebs inside ...
So when you have made that hole and applied the cables, maybe not a bad idea to add some minor sealing or so on the left-over openings to avoid something gets in.
Make sure you use something which can be removed easily.
Users browsing this forum: Majestic-12 [Bot] and 193 guests
