ToTheFull
Firewall Rules Fast-Track
Fri May 12, 2023 2:11 pm
I deleted my fastforward rule instead of dissabling it when I started using QOS. I am having a bit of a problem with QOS at the moment and would like to disable that and re-instate the fastforward firewall rule. Can anybody give me a leg-up please. firewalls arn't my strong point! hAP-ax
own3r1138
Long time Member
Long time Member
Re: Firewall Rules Fast-Forward
Fri May 12, 2023 2:13 pm
Did you mean Fast-Track?
ToTheFull
Fri May 12, 2023 2:15 pm
Yes that :)
ToTheFull
Re: Firewall Rules Fast-Track
Fri May 12, 2023 2:24 pm
Don't worry I've reset the device!
own3r1138
Long time Member
Long time Member
Re: Firewall Rules Fast-Forward  [SOLVED]
There is not much to it. Reboot after applying these rules. If you Marked your QOS, you could also use connection-mark=no-mark in the Fast-track rule.
add action=accept chain=input comment="Established, Related, Untracked" connection-state=established,related,untracked
add action=fasttrack-connection chain=forward comment=FastTrack connection-state=established,related
add action=accept chain=forward comment="Established, Related, Untracked" connection-state=established,related,untracked
ToTheFull
Fri May 12, 2023 2:27 pm
Thanks for that much appreciated
own3r1138
Long time Member
Long time Member
Fri May 12, 2023 2:30 pm
<3.
ToTheFull
Fri May 12, 2023 2:51 pm
I'm reloading my config and forcing myself to DO it!
ToTheFull
Fri May 12, 2023 3:14 pm
Their we go, does it matter that the rule is at the bottom ?
own3r1138
Long time Member
Long time Member
Fri May 12, 2023 3:28 pm
The order does matter. export all of your /ip firewall filter and share them.
ToTheFull
Fri May 12, 2023 3:32 pm
I'm having masive problems here, I've downgraded to 7.9 now.
Edit: Also using simple queues with that stock firewall
Rules:
Flags: X - disabled, I - invalid; D - dynamic
 0    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 1    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 2 X  ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp log=no log-prefix=""
 3    ;;; defconf: accept to local loopback (for CAPsMAN)
      chain=input action=accept dst-address=127.0.0.1
 4    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
 5    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
 6    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
 7    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
 8    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
 9    ;;; defconf: drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
own3r1138
Long time Member
Long time Member
Fri May 12, 2023 3:38 pm
In the screenshot, you have at least 13 filter rules. Now you have less than that. What is going on?
add chain=input action=drop connection-state=invalid
add chain=input action=accept protocol=icmp log=no log-prefix=""
add chain=input action=accept dst-address=127.0.0.1
add chain=input action=drop in-interface-list=!LAN
add chain=forward action=accept ipsec-policy=in,ipsec
add chain=forward action=accept ipsec-policy=out,ipsec
add chain=forward action=drop connection-state=invalid
add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
ToTheFull
Fri May 12, 2023 3:43 pm
Yes I've downdraged to 7.9 from 7,10 and reloaded my working config again hence less rules, My queues were are a mess since I updated to 7.10 yesterday I was just wanting to try FastTrack to see if that was working ok. WFH is arriving back soon so I only have a short window to play so i need to move fast
own3r1138
Long time Member
Long time Member
Fri May 12, 2023 3:48 pm
I see, so the order in post #12 is okay if you wish to use it.
ToTheFull
Fri May 12, 2023 3:52 pm
Thankyou so much @own3r1138 I will add those fresh next chance i get.
I'm out of time! arrrrrrrrrrgghh WFH is back.
I feel I need to add WFH is Work From Home, not the wife!
ToTheFull
Fri May 12, 2023 4:11 pm
I think the best thing to do now is export my config and add those.
Edit:
So this is the same but i just wanted to keep the format the same as whats in the .rsc file before uploading when next able.
    invalid
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
Users browsing this forum: nik247 and 22 guests
