Kentzo
Long time Member
Long time Member
How to assign an IPv6 address to an IPsec roadwarrior client?
Sat May 13, 2023 4:21 am
What needs to be enabled to so that a client can get an IPv6 assigned? So far it seems like the it operates in IPv4-only mode.
To simplify, I want all traffic to get routed over the IPsec IKEv2 tunnel.
Kentzo
Long time Member
Long time Member
Re: How to assign an IPv6 address to an IPsec roadwarrior client?
Fri May 19, 2023 12:10 am
Still cannot figure out how to get RouterOS's IPsec responder to assign an IPv6 address.
I can see in Wireshark that my client requests INTERNAL_IP6_* attributes, but the responder ignores them and replies only with INTERNAL_IP4_*. However, RouterOS logs this under the "ipsec" topic:
May/18/2023 13:45:34 ipsec ipsec: preparing internal IPv6 subnet
What am I missing?
Kentzo
Long time Member
Long time Member
Tue Jun 06, 2023 12:26 am
Tried the eap-radius as the authentication method. On radius (RouterOS's User Manager) I specified the "Framed-IPv6-Address" attribute, that did not work: RouterOS only allocated the IPv4 address.
Nightowl82
Sat Feb 10, 2024 12:33 am
We are struggeling with the same question.
viewtopic.php?t=204321
Any updates on this?
Kentzo
Long time Member
Long time Member
Tue Feb 13, 2024 8:23 pm
I don't think that's supported by RouterOS's IPsec client.
Nightowl82
Thu Feb 15, 2024 7:56 pm
I was able to create a workarround! Look in the linked post!
Kentzo
Long time Member
Long time Member
Thu Feb 15, 2024 8:43 pm
Great that it works for you!
Was not feasible in my setup where clients want to derive network configuration from the IPsec responder.
Nightowl82
Thu Feb 15, 2024 9:07 pm
It’s not perfect, but it will do for the clients that is dependent on IPv6 for their work.
It seems that other clients like phones,etc, still can get IPv4-addresses from the responder.
lets hope MT fixes this, and hopefully updates their documentation, with both limitations and the workaround.
Users browsing this forum: Bing [Bot], Guntis, Harlikin, xicu and 131 guests
