TronID
Cannot be accessed through via wireguard
Sat May 13, 2023 6:22 am
Hello, Hope someone can help me.
I have 3 routers that are connected via wireguard in order to access the internal network of each router.
The problem is that from network 192.168.20.0/24 I cannot access or ping the network 192.168.30.0/24 (vice versa), but from network 192.168.10.0/24 I can access both networks 192.168.20.0/24 and 192.168.30.0/24. I am attaching a picture of my network.
Does anyone know where the problem is?
THANK YOU
anav
Re: Cannot be accessed through via wireguard
Sun May 14, 2023 6:15 pm
Yes, I know exactly where the problem is..............
You will find the answers to this and all your other questions ---> viewtopic.php?t=182340
TronID
Mon May 15, 2023 6:00 am
Do I have to create a second tunnel to access remote sites between 192.168.20.0/24 <-> 192.168.30.0/24?
holvoetn
Mon May 15, 2023 10:48 am
Did you read the info in the link ? Really ?
You might want to read this one, paragraph B:
viewtopic.php?t=191442
The picture you provided is already fine.
But we don't see anything regarding the config of your devices.
How is anyone supposed to know then what's wrong ?
Maybe we should all look together in a crystal ball to see what comes up ...
Post your configs please (minus serial, public WAN IP, private keys, ...)
And between code quotes thankyouverymuch (much better for readability).
[code] config [/code]
TronID
Re: Cannot be accessed through via wireguard  [SOLVED]
Tue May 30, 2023 7:05 am
I have 3 routers that are connected via WireGuard in order to access the internal network of each router.
THANK YOU
Finally I've found answers and solutions from this website https://www.procustodibus.com/blog/2022 ... wireguard/.
Thanks to Justin Ludwig
holvoetn
Tue May 30, 2023 8:25 am
Which definitely means something was wrong with your config, which you never wanted to show.
Good for you that you found the problem yourself.
anav
Tue May 30, 2023 6:58 pm
Glad you passed on to others where you erred and how it was solved.
Users browsing this forum: Aska, GoogleOther [Bot], Javokhir, plastilin, qwertykolea and 204 guests
