MrBulldops
ERROR: couldn't resolve dns name
Sat May 13, 2023 2:04 pm
I would like to ask you for help with home network issue.
Problem is that I can't update the RouterOS on the Router B. Error message is "could not resolve dns names". Updates on Router A is working fine.
I am a real beginner and it is my home network. May I ask someone for help, please? Here are the settings of the router A.
Router A:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="czech republic" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=Pejchal wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
/interface vlan
add interface=ether1 name=vlan-848 vlan-id=848
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-848 keepalive-timeout=60 \
    max-mru=1480 max-mtu=1480 mrru=1600 name=pppoe-ERI use-peer-dns=yes user=\
    e22140599
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
    192.168.88.0
/ip dhcp-client
set allow-remote-requests=yes servers=84.19.64.3,84.19.64.4,8.8.8.8
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface=pppoe-ERI
/ipv6 route
add disabled=no dst-address=::/0 gateway=pppoe-ERI routing-table=main scope=30 \
    target-scope=10
/ipv6 address
# address pool error: pool not found: ERI (4)
add eui-64=yes from-pool=ERI interface=bridge
/ipv6 dhcp-client
add interface=pppoe-ERI pool-name=ERI pool-prefix-length=56 request=prefix
/ipv6 nd
set [ find default=yes ] mtu=1480
/system clock
set time-zone-name=Europe/Prague
/system scheduler
add interval=1d name=reboot on-event="/system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=may/05/2021 start-time=03:00:00
/tool mac-server
/tool mac-server mac-winbox
MrBulldops
Re: ERROR: couldn't resolve dns name
Sat May 13, 2023 2:05 pm
Router B:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="czech republic" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Pejchal wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="czech republic" disabled=no distance=indoors frequency=5240 installation=indoor mode=ap-bridge ssid=Pejchal wireless-protocol=802.11
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set auth=sha1,md5
add address=192.168.88.2/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.2 netmask=24
set allow-remote-requests=yes servers=192.168.88.1,8.8.8.8
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.88.1 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add interval=1d name=reboot on-event="/system reboot\r\
    \n" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/07/2022 start-time=02:00:00
Thanks for any help!
holvoetn
Re: ERROR: couldn't resolve dns name  [SOLVED]
Sat May 13, 2023 2:09 pm
Try to set dns on router b the same as a, since that one works.
MrBulldops
Sat May 13, 2023 2:20 pm
I did that and I turned my router B from Home AP into Bridge AP and now it's working. Thank you very much!
Users browsing this forum: JmJ17, unhuzpt and 114 guests
