Doraemon309
eMMC memory
Sun May 14, 2023 1:56 pm
Can anyone tell me if eMMC memory can run Router Os on x86?
Buckeye
Forum Veteran
Forum Veteran
Re: eMMC memory
Mon May 15, 2023 2:26 am
What made you ask that question?
What problem are you trying to solve?
r00t
Long time Member
Long time Member
Re: eMMC memory
Mon May 15, 2023 3:32 am
Some mini PCs have eMMC drive to boot from (like Intel Compute Stick and others), same for SD card... so maybe that? ROS would need some drivers for that I think, never tried that.
Or maybe trying to ask if you can boot ROS from M.2 drive and it got lost in translation somewhere?
Doraemon309
Re: eMMC memory
Mon May 15, 2023 4:10 am
I tried to install Routeros on R86S with the message "No harddrives found"
Doraemon309
Re: eMMC memory
Mon May 15, 2023 4:13 am
Do you guys have a solution to this problem? :?:
Doraemon309
Re: eMMC memory
Mon May 15, 2023 4:22 am
Is SSD 2208 on the router's driver list?
r00t
Long time Member
Long time Member
Re: eMMC memory
Mon May 15, 2023 5:52 pm
I suggest you just boot it off flash drive, it pretty much works every time on every machine as usb drivers are stable and universal.
Then you can check what hardware can ROS actually see on R86S platform...
Doraemon309
Re: eMMC memory
Tue May 16, 2023 5:41 am
Yes, what you said I understand! Looks like eMMC can't see in bootloader! Because eMMC only accepts GPT!
Users browsing this forum: philipwillemse, plastilin, vagrik and 213 guests
