maigonis
ax series lineup WiFi issues
Sun May 14, 2023 2:52 pm
I see quite a lot issues reported in forums about ax lineup WiFi issues, lets collect them here whit possible workarounds and fixes.
I have notices these issues:
1. The mostly known "rejected, can't find PMKSA". It affects my Samsung S22 the most, but I have also seen it affecting S10+ and my laptop whit Intel AX210 WNIC. This should be WPA3 related, if you disable it and use WPA2 only this issue should go away.
2. "association SA Query timed out" - it is 802.11w Protected Management Frame related. Looks like it started when i turned on FT (Fast BSS Transition (802.11r)).
Please don't post about slow WiFi speeds, that's another story, post only issues that make WiFi unstable or otherwise are software or hardware related.
soonwai
Re: ax series lineup WiFi issues
Tue May 16, 2023 10:14 am
Here's mine. Been meaning to send support an email and supout but keep forgetting to generate it. Gonna do that the next time it dies.
I have had very few "can't find PMKSA" errors. It's always "key handshake timeout" when the wifi hangs.
hAP ax3 v7.9
13 May 3:50am. ax3 7.9. Wifi uptime: 7 days 2hrs.
hAP ax3 v7.10beta
14 May 5:00pm. ax3 7.10beta5. Wifi uptime: 1 days 12hrs.
15 May 12:20pm. ax3 7.10beta5. Wifi uptime: 7 hrs 20 mins.
(I had FT turned on. Maybe shouldn't have done that. Back to off.)
18 May 8:00am. ax3 7.10beta5. Wifi uptime: 3 days 6 hrs.
19 May 9:16am. ax3 7.10beta5. Wifi uptime: 1 days 1 hr.
My current config (since May 5 or 6)
# may/09/2023 04:15:47 by RouterOS 7.9
# model = C53UiG+5HPaxD2HPaxD
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=disabled .width=20/40/80mhz \
    configuration.country=Malaysia .mode=ap .ssid=mtk disabled=no security.authentication-types=wpa2-psk,wpa3-psk \
    .disable-pmkid=no .encryption=ccmp,gcmp,ccmp-256,gcmp-256 .wps=push-button
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=disabled .width=20mhz configuration.country=\
    Malaysia .mode=ap .ssid=mtk disabled=no mtu=1500 security.authentication-types=wpa-psk,wpa2-psk .disable-pmkid=no \
gigabyte091
Wed May 17, 2023 8:10 pm
I disabled WPA2 and for now I'm only using WPA3 on ax2, and for now it's working without any problem, uptime 5d 6h. I was getting PMKSA errors only when WPA2/WPA3 was selected. I'm running 7.10beta5
ToTheFull
Wed May 17, 2023 9:06 pm
Still going strong here, wpa2/wpa3 enabled no PMKSA errors.
uptime: 6d11h29m2s
version: 7.10beta5 (development)
build-time: May/09/2023 10:38:53
factory-software: 7.7
free-memory: 619.1MiB
total-memory: 928.0MiB
cpu: ARM64
cpu-count: 4
cpu-frequency: 864MHz
cpu-load: 0%
free-hdd-space: 95.2MiB
total-hdd-space: 128.5MiB
write-sect-since-reboot: 382
write-sect-total: 71514
bad-blocks: 0%
architecture-name: arm64
board-name: cAP ax
platform: MikroTik
gigabyte091
Wed May 17, 2023 9:51 pm
I bought my routers before cap ax was released... So now there is no chance to explain my wife that we need yet another APs...
I was thinking about setting up capsman but i don't have third device that should act as controller... And that is just another layer of complexity... And just for roaming...
holvoetn
Wed May 17, 2023 10:27 pm
AX, AX2, AX3 and cAP AX can all be used as controller, even for their own radios.
soonwai
Thu May 18, 2023 3:22 am
 ___________________
< ax3 crashed again >
        \   ^__^
         \  (oo)\_______
            (__)\       )\/\
                ||----w |
...and I forgot to supout.rif again... :-(
gigabyte091
Thu May 18, 2023 6:08 am
Is it worth the trouble for just 2 AP ?
Topic related, two PMKSA errors for 2.4 GHz on ax2 after almost 6 days but wifi is still working, it didn't crash or anything.
holvoetn
Thu May 18, 2023 10:01 am
Certainly not. :D
maigonis
Thu May 18, 2023 11:45 am
 ___________________
        \   ^__^
         \  (oo)\_______
            (__)\       )\/\
                ||----w |
Interfaces crashed? Like ax2 reported? Or device itself? autosup should be created if device crashes.
maigonis
Thu May 18, 2023 11:46 am
Certainly not. :D
I do use capsman at home for 2 APs, its a learning opportunity.
holvoetn
Thu May 18, 2023 12:00 pm
Oh but for learning there is no problem.
It's just not needed. I have AX2 and AX3 at home, no capsman.
I have toyed with it too (briefly) to see differences with legacy capsman (I used to have a setup with that for another place) but some of the quirks need to be ironed out before I will try it again.
Or is VLAN handling for ether-ports now sorted out properly ?
Last time I tried it, all VLAN handling needed to be disabled on AP-bridge, hence also for ether-ports.
gigabyte091
Thu May 18, 2023 12:06 pm
Yea, i was thinking about that, just to try it, I saw some default configutations on Mikrotik wiki.
Sooo... I ordered two cAP ax... you know... for when drivers get even better...
ToTheFull
Thu May 18, 2023 12:12 pm
Hahahahahahahaha too funny!
maigonis
Thu May 18, 2023 12:35 pm
I never had issues whit VLANs in general, but I did had issue whit interface dynamic add to bridge (so I did it manually). As I revisited config its now working as it should, but system is not perfect. Maybe I don't know how to do it the right way, but now, afaik, I have to tag interface in capsman interface list and on AP datapath. By logic I understand that server does not know APs datapaths, so this have to be set manually per AP, but vlan tagging should be passed from server, only server side configuration required.
maigonis
Thu May 18, 2023 12:36 pm
Sorry, double post.
gigabyte091
Thu May 18, 2023 3:55 pm
@maigonis
So we can expect some CAPsMAN tutorial from you ? :D :D
maigonis
Thu May 18, 2023 5:17 pm
@maigonis
I am planning to do tutorials, but not right now. For that I need time and be sure my knowledge is solid, so I'm not spreading false information.
soonwai
Thu May 18, 2023 5:34 pm
When its wifi dies, the ax3 is still running. Switch, ethernet and containers all ok. Just that nothing connects to the wifi anymore. Logs show “handshake key timeout” whenever any device tries to connect. Nothing in the registration table. For both 2.4 and 5Ghz.
gigabyte091
Thu May 18, 2023 7:09 pm
Does enable/disable of the interfaces helps ? Or you have to reboot the router ?
maigonis
Thu May 18, 2023 8:26 pm
What does wifi scan app say? Aka, beacons are fine? Anyone tried sniff WiFi interface and station to see what frames are there?
soonwai
Thu May 18, 2023 8:27 pm
Only reboot does the trick. Enable/disable no go.
gigabyte091
Thu May 18, 2023 9:42 pm
I had that problem on ROS 7.8, but that is gone on 7.10beta5
holvoetn
Thu May 18, 2023 9:55 pm
Using WPA3 ? That was the killer for me on 7.10b5.
gigabyte091
Thu May 18, 2023 10:32 pm
WPA2/WPA3 combo and WPA3 only. On 7.10beta5 i'm using only WPA3 and there are no problems at all. That is why i ordered cap ax, wifi on mikrotik, at least for me, is starting to work like it should and ax2 is needed elsewhere.
I'm still thinking about trying capsman but i don't know, multiple ssid, vlans etc... Only real benefit is roaming... but that i plan to solve by reducing tx power and using ACL. That seems to me like a much easier approach.
At my parents house is ax2, on ROS 7.8 and i leave only WPA2, older phones and i didn't want to risk potential problems with wifi
soonwai
Fri May 19, 2023 1:39 pm
ax3 wifi gone again. same old, same old, tons of "key handshake timeout"
gigabyte091
Fri May 19, 2023 2:27 pm
Try only WPA2 or WPA3.
Little update:
I recieved my 2 cap ax, those things are huge... My old cap ac looks like a shirt button when compared to cap ax
Little update:
So WPA3 only, phone connects to 5 GHz, but 573 MHz speed only (channel width 80 MHz) and laptop connects to 2.4 GHz, no error for now. For comparison, on ax 2, same settings phone and laptop connects to 5 GHz no problem.
EDIT: It was my stupidity... I forgot to set country... now all devices connects to 5GHz and full speed, no errors.
ajmxco
Fri May 19, 2023 5:42 pm
Ever since the 7.9 upgrade I'm have this exact same problem and am having to reboot every couple days. I opened a support request and provided my supout.rif file.
Quickly loosing patient with this problem, hopefully they'll fix it soon, and will return the product if I have to keep rebooting it for another week.
gigabyte091
Fri May 19, 2023 6:08 pm
Here is my basic setup for AP, no VLANs for now, no interface lists or anything, this is only to test stability.
# 2023-05-19 17:01:45 by RouterOS 7.10beta5
# software id =
# model = cAPGi-5HaxD2HaxD
# serial number =
add name=bridge
set [ find default-name=wifi1 ] channel.band=5ghz-ax .width=20/40/80mhz \
    configuration.country=Croatia .mode=ap .ssid=Mikrotik disabled=no \
    security.authentication-types=wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .width=20/40mhz \
add bridge=bridge interface=ether1
add bridge=bridge interface=wifi1
add bridge=bridge interface=wifi2
add address=172.16.0.1/24 comment=mgmt interface=ether2 network=172.16.0.0
add address=10.10.88.3/24 comment=AP_IP interface=ether1 network=10.10.88.0
add disabled=no dst-address=0.0.0.0/0 gateway=10.10.88.1 routing-table=main \
    suppress-hw-offload=no
/system note
set show-at-login=no
massinia
Fri May 19, 2023 6:27 pm
For now 9 days of uptime without problems.
WPA2 without VLANs
gigabyte091
Fri May 19, 2023 11:34 pm
One floor between cap ax and phone (concrete floor with a lot of metal rebar)
Not bad, bot bad at all.
ToTheFull
Sat May 20, 2023 12:30 pm
How much power are you using, all of it ?
gigabyte091
Sat May 20, 2023 1:34 pm
Don't know, it's on the default settings and U6 lite is broadcasting wifi
ToTheFull
Sat May 20, 2023 1:48 pm
 /interface/wifiwave2/radio/reg-info
country: Croatia
number: 0
  ranges: 2402-2482/20
          5170-5250/23
          5250-5330/23/dfs
          5490-5730/20/dfs
          5735-5875/20/dfs
Minus antenna gain of course!
gigabyte091
Sat May 20, 2023 5:31 pm
By default TX power is at maximum ? Right now I have only one cAP ax operational, another one is in the box.
I think that next weekend i will replace U6 lite with cap ax, i think that wifi is now stable enough for me. Only, i will have to leave WPA2 so my wife can connect to wifi with her laptop
Switching from 5 to 2.4 GHz works, i tested that today, no problems or errors in logs.
ajmxco
Sat May 20, 2023 5:39 pm
Still rebooting everyday and I have WPA3 disabled. Before the 7.9 upgrade everything worked great.
No response from Mikrotik support on my support ticket.
Would installing the 7.10 beta help?
ToTheFull
Sat May 20, 2023 6:20 pm
Glad to here it all seems to be working out for you. I have my cAP ax (wpa2/wpa3 5G&2.4G V-7.10) upstairs and hAP ax (wpa2 2.4G V-7.9) in my living room. when I walk in the house from the Kitchen my phone connects to the 2.4G cAP ax upstairs if I then walk upstairs it switches over to 5G, if I then walk back into my living room my phone will then move to the hAP ax. So all good.
Stability is the best it's been so far in this product line!
I have a problem with my hAP ax, it used to just reboot itself for no reason. It turns out that the power socket/switch is faulty. I've ordered a new socket and will fit it in due course. In the mean-time I'm using the PoE Injector that was provided with the cAP ax for power. So just a little food for thought to waggle and check the power socket.
https://mikrotik.com/product/RBGPOE
ToTheFull
Sat May 20, 2023 6:38 pm
For your country yes. For other countries No!
Take a look here viewtopic.php?p=1001491&hilit=ranges%3A ... 0#p1001491
gigabyte091
Sat May 20, 2023 7:35 pm
@ajmxco
You should try 7.10b5, it's much more stable WiFi, i try it on ax3, ax2, cap ax and i have much better wifi experience than 7.9
@ToTheFull
Same here but with my previous setup with ax3 and ax2 i decreased TX power on ax2 downstairs so my devices connects to the upstairs ap once i move to rooms upstairs. And that worked quite good, a little bit of testing was needed ofc and i didn't need to use acl or capsman, it was "redneck roaming" haha.
maigonis
Sat May 20, 2023 8:31 pm
What device is it?
ajmxco
Sat May 20, 2023 8:39 pm
What device is it?
It's an HAP ax2
ajmxco
Sat May 20, 2023 8:40 pm
@ajmxco
@ToTheFull
Thanks for the info. With 7.10b5, do you have WPA3 enabled?
gigabyte091
Sat May 20, 2023 9:55 pm
Yes, i use only WPA3 and it's working great for now.
ajmxco
Sun May 21, 2023 3:41 am
I installed the 7.10b5 + firmware and it lasted a few hours before showing the "key handshake timeout" errors again so I had to reboot it.
I have a router that needs rebooting 1-2 a day and a support ticket with zero response from Mikrotik. Ridiculous...
I'll process a refund on the device this week if Mikrotik support ghosts me.
gigabyte091
Sun May 21, 2023 8:48 am
I'm sorry to hear that 7.10b5 wasn't improvement for you, my ax2 works so much better now.
Maybe is something in your configuration ? Can you post it ?
ToTheFull
Sun May 21, 2023 11:52 am
Oh your rebooting it!
Something is causing a driver crash surely then.
wpa2/wpa3 here 10 days and still going, I would hang on for the next release if you can at least before you throw in the towl
uptime: 1w3d2h10m35s
free-memory: 611.6MiB
cpu: ARM64
cpu-count: 4
cpu-frequency: 1320MHz
cpu-load: 5%
free-hdd-space: 95.3MiB
write-sect-since-reboot: 543
write-sect-total: 71675
bad-blocks: 0%
board-name: cAP ax
platform: MikroTik
ajmxco
Sun May 21, 2023 1:50 pm
Thanks for your help and below is my config from 7.8 (didn't change config with upgrade). Everything worked great before the 7.9 upgrade and I really want this to work. I hope support will contact me this week and I don't want to return the product.
For now, I've turn it off and am using an old HAP AC that works fine for now.
# apr/06/2023 14:36:19 by RouterOS 7.8
# software id = software id
# model = C52iG-5HaxD2HaxD
# serial number = serial number
add ingress-filtering=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=guest-vlan vlan-id=100
add interface=bridge1 name=homeco-vlan vlan-id=88
add name=WAN
add name=VLAN
/interface wifiwave2 channel
add band=5ghz-ax disabled=no frequency=5240,5765,5805 name=channel-5ax \
    skip-dfs-channels=all
add band=2ghz-n disabled=no name=channel-2n
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=wifi-homeco wps=\
    disable
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=wifi-guest wps=\
    disable
/interface wifiwave2 configuration
add channel=channel-5ax country="United States" disabled=no name=\
    cfg-homeco-5ghz security=wifi-homeco ssid=mywls
add channel=channel-2n country="United States" disabled=no name=cfg-guest \
    security=wifi-guest ssid=mywls.guest
add channel=channel-2n country="United States" disabled=no name=\
    cfg-homeco-2ghz security=wifi-homeco ssid=mywls
set [ find default-name=wifi1 ] configuration=cfg-homeco-5ghz \
    configuration.mode=ap disabled=no
set [ find default-name=wifi2 ] configuration=cfg-homeco-2ghz \
add configuration=cfg-guest configuration.mode=ap disabled=no mac-address=\
    4A:A9:8A:22:77:6C master-interface=wifi2 name=wifi2-guest
add name=pool-homeco ranges=192.168.88.100-192.168.88.200
add name=pool-guest ranges=192.168.100.100-192.168.100.200
add address-pool=pool-homeco interface=homeco-vlan lease-time=2d name=\
    server-homeco
add address-pool=pool-guest interface=guest-vlan lease-time=2d name=\
    server-guest
/queue simple
add max-limit=5M/20M name=queue-guest target=guest-vlan
/queue type
add kind=cake name=queue-cake
/queue simple
add max-limit=80M/20M name=queue-cake target=ether1 total-queue=queue-cake
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether2 pvid=88
    interface=wifi1 pvid=88
    interface=wifi2 pvid=88
    interface=wifi2-guest pvid=100
set discover-interface-list=VLAN
/ipv6 settings
set max-neighbor-entries=15360
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 vlan-ids=88
add bridge=bridge1 tagged=bridge1 vlan-ids=100
add interface=ether1 list=WAN
add interface=guest-vlan list=VLAN
add interface=homeco-vlan list=VLAN
add address=192.168.88.1/24 interface=homeco-vlan network=192.168.88.0
add address=192.168.100.1/24 interface=guest-vlan network=192.168.100.0
/ip cloud
set update-time=no
/ip dhcp-client
add interface=ether1 use-peer-dns=no
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1
set allow-remote-requests=yes servers=1.1.1.3,1.0.0.3
/ip dns static
add address=192.168.88.10 name=server.mynet.com
add address=192.168.88.1 name=router.mynet.com
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" \
    in-interface=homeco-vlan
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
    "drop access to clients behind NAT from WAN" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="Default masquerade" \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.88.0/24
set ssh address=192.168.88.0/24
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=router
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes local-clock-stratum=4 manycast=yes \
    use-local-clock=yes
/system ntp client servers
add address=pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool graphing interface
add allow-address=192.168.88.0/24 interface=ether1
/tool graphing resource
/tool mac-server
set allowed-interface-list=VLAN
/tool mac-server mac-winbox
ajmxco
Sun May 21, 2023 1:58 pm
cpu: ARM64
cpu-count: 4
cpu-load: 5%
bad-blocks: 0%
board-name: cAP ax
platform: MikroTik
I think it's a driver crashing problem too and was hoping the 7.10b5 would fix it with the release note item mentioning "key handshake timeout". I updated my support ticket that this beta version didn't fix the problem.
I'll keep this forum post updated this week with my journey to get this fixed with support, if they help me.
PeterXC
Sun May 21, 2023 3:36 pm
Have you tried to reset to factory defaults and manually configure it?
I had a similar issue: WiFi outage and errors after the SW upgrade. In my case, it helped.
No errors in logs. Still, the WiFi stability is not perfect. I have a ping probe to one of my IOT devices, and I can see it loses connectivity almost every day.
(time in UTC)
root@MikroTik:/etc/pihole# cat ping_log.txt
IP: 192.168.200.127 was unreachable from 2023-05-09 07:36:26 to 2023-05-09 07:38:27. Unavailable for 2 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-09 07:41:46 to 2023-05-09 07:47:51. Unavailable for 6 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-09 19:29:07 to 2023-05-09 19:30:07. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-13 11:05:04 to 2023-05-13 11:06:04. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-15 07:30:11 to 2023-05-15 07:31:11. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-16 07:30:46 to 2023-05-16 07:31:46. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-17 09:30:22 to 2023-05-17 09:31:22. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-17 23:39:42 to 2023-05-17 23:40:42. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-19 07:33:25 to 2023-05-19 07:34:25. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-19 19:33:42 to 2023-05-19 19:34:42. Unavailable for 1 minutes.
IP: 192.168.200.127 was unreachable from 2023-05-21 11:46:37 to 2023-05-21 11:48:38. Unavailable for 2 minutes.
gigabyte091
Sun May 21, 2023 4:50 pm
Have you try to netinstall ROS again ? Maybe that would help ?
gigabyte091
Mon May 22, 2023 3:35 pm
I tried to enable WPA2/WPA3 but as soon as I did that i get PMKSA error... Only WPA2 or WPA3 no problems on ax2 and cap ax so i'm waiting for another update...
ajmxco
Mon May 22, 2023 4:39 pm
Would downloading the 7.8 bits and downgrading solve this problem for the HAP ax2 until this getting resolved? Has this worked for anyone?
nonolk
Mon May 22, 2023 4:50 pm
@ajmxco, Yes it works fine for me on 3 (ax2 and one ax lite), I have 20 days of connection time for some of my devices without major issues.
So at least for now and if you are not using the ax2 as router (or without ipv6) this is a viable workaround.
Best regards,
ajmxco
Mon May 22, 2023 5:01 pm
Best regards,
Thanks for the info and why are you saying not using the ax2 as a router or w/o ipv6?
nonolk
Mon May 22, 2023 5:39 pm
@ajmxco, because of this viewtopic.php?t=196384
Even if the impacted configuration is not so common ;-)
ajmxco
Mon May 22, 2023 5:45 pm
@nonolk - thanks for the link and I'll downgrade later today and report back with the results to this forum thread.
ajmxco
Mon May 22, 2023 7:20 pm
After downgrading to 7.8 + firmware, the wireless interfaces no longer showed up in winbox so I factory reset the unit. This still didn't fix the missing wireless interfaces.
I upgraded to 7.9.1 + firmware and the wireless interfaces are still missing so now I'm in a worse state of affairs. Wow this is crazy...
I'll update the support ticket with my new problem now and include the support.rif file.
holvoetn
Mon May 22, 2023 7:24 pm
Manual downgrade ?
Most likely you forgot wifiwave2 package.
Care to try again ? :lol:
ajmxco
Mon May 22, 2023 8:06 pm
Manual downgrade ?
Thanks for the tip and, after reading through some of the documentation and learning how to install packages, I'm back to 7.8 with wireless working again. I'll let this bake and see what happens...
gigabyte091
Mon May 22, 2023 9:40 pm
Meh, 7.9.1 is only security update, no real change for now...
ajmxco
Tue May 23, 2023 4:42 pm
Update - no issues since downgrading to 7.8 and support contacted me with an alpha release of 7.10 past b5 that might fix the problem. I hesitant to try this because I need stable wifi for the work week so maybe this weekend.
ToTheFull
Tue May 23, 2023 5:16 pm
What's new in 7.10beta8 (2023-May-22 18:52):
Anybody tried it yet ?
ajmxco
Tue May 23, 2023 5:19 pm
I saw that too after my post just now. I updated my ticket asking what's the difference between 7.10beta8 and the alpha version they sent me to fix this problem.
ajmxco
Tue May 23, 2023 5:29 pm
Support replied back and said 7.10beta8 doesn't contain the fix for this problem.
ToTheFull
Tue May 23, 2023 5:36 pm
Thanks save me the bother
ajmxco
Tue May 23, 2023 5:41 pm
The alpha version they sent me is 7.10beta8 + the fixes for this problem and I'll probably test it out this weekend.
massinia
Tue May 23, 2023 5:50 pm
Me too, great support as always.
Now I am testing the 7.10alpha237 version.
nonolk
Tue May 23, 2023 5:54 pm
Glad to hear that. I will wait for next beta then before deploying it ;-), thank you ajmxco
gigabyte091
Wed May 24, 2023 7:46 am
Please test with WPA2/3 combined so we can see if you got rid of the PMKSA errors
massinia
Wed May 24, 2023 9:54 am
Sure!
I'm using WPA2/WPA3, for now there are no errors but it's still early.
gigabyte091
Fri May 26, 2023 3:53 pm
New 7.10rc1 works now, at least for me, no PMKSA errors for now... we will see
PeterXC
Fri May 26, 2023 10:46 pm
This issue is tricky. In my case, it was stable for 17 days and today it got back :(
Both WiFi were not accepting any clients. I had some time, so I tried to troubleshoot: I disabled WiFi for a while, disabled the security profile and also enabled debug on WiFi, but no luck. No obvious errors besides authentication.
Upgraded to 7.9.1 both ROS and RouterBoard. I hope it will be stable. One more outage and I'm switching back to old AC Asus.
gigabyte091
Fri May 26, 2023 11:07 pm
Why don't you try 7.10rc1 ? It worked for me, at least for now.
massinia
Fri May 26, 2023 11:38 pm
I'm still with the 7.10alpha237 which seems very stable, I only have 4 days of uptime but for now there are no problems.
ToTheFull
Sat May 27, 2023 12:09 am
Getting these Ipad Air 2 7.10RC Only wpa2 enabled. Is this Normal ?
18:55:16 wireless,info XX:XX:XX:XX:XX:XX@wifi1 disconnected, association SA Query timed out, signal strength -51
20:02:13 wireless,info XX:XX:XX:XX:XX:XX@wifi1 disconnected, association SA Query timed out, signal strength -52
ToTheFull
Sat May 27, 2023 11:07 am
I don't have FT enabled
S8T8
Sat May 27, 2023 12:47 pm
Out of curiosity, has 7.10rc1 fixed issues with AX devices?
ToTheFull
Sat May 27, 2023 1:33 pm
Thats a loaded question, I think the answer is it's to early to tell yet for some.
maigonis
Sat May 27, 2023 1:34 pm
No, I still see all issues appear. I also see SA query time outs whit out FT enabled as ToTheFull mentioned.
gigabyte091
Sat May 27, 2023 3:27 pm
We are getting there, slowly...
vhaisman
Sun May 28, 2023 12:15 pm
I am still getting a lot of "can't find PMKSA" even with the 7.10rc1.
gigabyte091
Sun May 28, 2023 2:48 pm
WPA2/3 combo ? Which device are we talking about ? Are you using CAPsMAN ?
holvoetn
Sun May 28, 2023 2:50 pm
I'm on 7.10rc1 for ax2 and ax3, using both wpa2/3 on purpose.
Not seeing this error anymore.
AstroPig7
Sun May 28, 2023 3:15 pm
I installed a hAP ax³ late last week and upgraded it to 7.9.1. Last night, the SSIDs were suddenly no longer visible to clients and the indicator light for wireless activity was off on the device itself. Disabling and re-enabling the interfaces brought it back to life, but I saw no errors in the system log (i.e., no timeouts under the wireless topic). I didn’t have this problem with my ac³, but I also wasn’t using the WifiWave2 package on it.
Does not seeing errors but still experiencing what appears to be a driver crash match anyone else’s experience?
maigonis
Sun May 28, 2023 3:28 pm
On ax2 yes, looks like it.
vhaisman
Sun May 28, 2023 3:29 pm
Yes, WPA2+3. It's hAP ax^3. No CAPsMAN.
ToTheFull
Sun May 28, 2023 3:42 pm
What samsung device is that (C8:) your having trouble with.
vhaisman
Sun May 28, 2023 4:03 pm
That's Samsung Galaxy A72 (SM-A725F/DS).
gigabyte091
Sun May 28, 2023 6:13 pm
I tried now with Samsung Galaxy A34 and no errors on ax3 (I know, it's not WiFi6). What did you tried to do ?
vhaisman
Sun May 28, 2023 6:51 pm
I tried turning off WPA2. I want WPA3. That did not fix it.
gigabyte091
Sun May 28, 2023 9:36 pm
Did you opened support ticket ? Can you try netinstall ROS again ? That's strange... I never had problems with WPA3, only when used in combo with WPA2.
When you use only WPA2 do you get any errors ?
vhaisman
Mon May 29, 2023 8:16 am
With only WPA2 I do not get those "can't find PMKSA" messages.
maigonis
Mon May 29, 2023 9:15 am
You should not get PMKSA errors, as it is WPA3 related. WPA2 does not have PMKSA.
gigabyte091
Mon May 29, 2023 5:08 pm
I tried with Samsung Z Fold 4 and Z Flip 4 today and iPhone 14 pro with no problems. Still going strong.
ToTheFull
Mon May 29, 2023 5:22 pm
I'm all good here now the SA timeout problem has subsided for some reason on one device that had an issue, as of today I'm now using wpa2/wpa3 ccmp/gcmp 5g only on hAP ax (7.10RC1) as Router. And my cAP ax 2.4g/5g is still storming along no issue still on 7.10 beta5 go figure!
uptime: 2w4d7h48m39s
free-memory: 612.4MiB
cpu: ARM64
cpu-count: 4
cpu-load: 0%
free-hdd-space: 95.5MiB
write-sect-since-reboot: 696
write-sect-total: 71828
bad-blocks: 0%
board-name: cAP ax
platform: MikroTi
ajmxco
Wed May 31, 2023 3:09 pm
Did 7.10alpha237 fix this issue? I haven't had a chance to test it out yet...
massinia
Wed May 31, 2023 3:48 pm
For me yes, I'm using hAP ax3 as CAPsMAN Wave2 and two hAP ax2 as cAP.
Security WPA2/WPA3 without VLANs, everything perfect without errors for 8 days.
holvoetn
Wed May 31, 2023 3:54 pm
Interesting.
Why are those changes kept back for so long ...
massinia
Wed May 31, 2023 4:02 pm
They probably want to do more tests to find the cause of the problem.
I'm leaving the beta until it crashes... hopefully never :lol:
ffries
Thu Jun 01, 2023 8:39 pm
Same issue here, I am using 7.10rc1 + hAP AX3 with WPA3 only (using plain dump hardware with no filtering).
Can stay 1 or 2 days and the WIFI is no longer visible and I have to reboot.
I just disabled PMKSA to test if things improve.
ajmxco
Fri Jun 02, 2023 9:52 pm
This morning I installed 7.10alpha237 (from "7.8"), the 7.9 error messages are gone, and wireless is still working w/o a reboot.
gigabyte091
Mon Jun 05, 2023 10:45 pm
After 10 days no errors, still going strong :D
holvoetn
Mon Jun 05, 2023 10:47 pm
Showoffs :? :) :lol:
S8T8
Tue Jun 06, 2023 12:45 am
@gigabyte091 witch version are you using? WPA3 disabled? Any particular setting off?
gigabyte091
Tue Jun 06, 2023 6:23 am
@holvoetn
Maybe a little... :lol: :lol: actually im quite happy right now with mikrotik wireless, i can say that for me it now works as same as ubiquiti minus roaming ofc, not yet running capsman
@S8T8
I'm using 7.10rc1, default wireless config, only changed country, WPA2/3 mixed, nothing special.
gigabyte091
Thu Jun 08, 2023 6:53 am
After 12 days I got PMKSA error with new phone, but after disabling and then enabling phone's wifi i got no error and phone connects to 5GHz radio.
I will pay more attention to logs for a few days now just to see if this is some kind of one time error now or it will get more common.
ToTheFull
Thu Jun 08, 2023 2:13 pm
Same here about 12 days uptime 7.10RC1
Note that PMKSA only present when I start my machine but not every time.
gigabyte091
Thu Jun 08, 2023 10:38 pm
I just noticed something with new phone, for eg. old phone always report connection speed 1200 Mbps, but new phone reports 1201 Mbps...
No errors for now, i think this was one time event.
holvoetn
Thu Jun 08, 2023 11:14 pm
I always see 1201 on my S20.
On pc using tp link adapter too.
gigabyte091
Sat Jun 10, 2023 10:55 pm
So, another PMKSA error and phone connects to 2.4 GHz, after enabling and disabling wifi on the phone twice i can connect to 5 GHz.
Error is not frequent for now... But we will see
gigabyte091
Sun Jun 11, 2023 7:35 am
Getting error when connecting laptop to AP but still connects to 5 GHz radio:
maigonis
Sun Jun 11, 2023 3:10 pm
When i disable WPA3 and PMKID I see two issues: "SA Query timed out" and "key handshake timeout". Otherwise WiFi is more stable, waiting for 7.11 beta.
Ca6ko
Long time Member
Long time Member
Wed Jun 14, 2023 9:51 am
AX2 7.9.2/7.10.rc5 clients can not connect to the wifi. There are Handshake errors in the logs.
Configuration features included WPA2/WPA3 have virtual interfaces.
add band=2ghz-ax disabled=no frequency=2412 name=channel1 width=20mhz
add band=2ghz-ax disabled=no frequency=2437 name=channel6 width=20mhz
add band=2ghz-ax disabled=no frequency=2462 name=channel11 width=20mhz
add band=5ghz-ax disabled=no frequency=5180 name=channe36 width=\
    20/40/80/160mhz
add band=5ghz-ax disabled=no frequency=5240 name=channel48 width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5260 name=channel52 width=\
    20/40/80/160mhz
/interface wifiwave2 datapath
add bridge=bridge1 disabled=no name=datapath1
add bridge=bridge2 disabled=no name="datapath2 Guest"
add authentication-types=wpa2-psk,wpa3-psk disabled=no encryption=\
    ccmp,gcmp,ccmp-256,gcmp-256 name=osnovnoy passphrase=wwwwwwwww
    ccmp,gcmp,ccmp-256,gcmp-256 name=guest passphrase=111111111
add channel.band=2ghz-ax country=Ukraine datapath=datapath1 disabled=no mode=\
    ap name="cfg1 2.4" security=osnovnoy ssid=V
add channel.band=5ghz-ax datapath=datapath1 disabled=no mode=ap name="cfg2 5" \
add channel.band=2ghz-ax country=Ukraine datapath="datapath2 Guest" disabled=\
    no mode=ap name="cfg4 guest 2.4" security=guest ssid=VGuest
add channel.band=5ghz-ax country=Ukraine datapath="datapath2 Guest" disabled=\
    no mode=ap name="cfg3 guest 5" security=guest ssid=VGuest
add channel.band=5ghz-ax country=Ukraine datapath=datapath1 disabled=no mode=\
    ap name="cfg5 D" security=osnovnoy ssid="V 5ax"
set [ find default-name=wifi1 ] channel=channe36 channel.width=20/40/80mhz \
    configuration="cfg2 5" configuration.country=Ukraine .mode=ap disabled=no
set [ find default-name=wifi2 ] configuration="cfg1 2.4" configuration.mode=\
    ap disabled=no
add configuration="cfg3 guest 5" configuration.mode=ap disabled=no \
    mac-address=00:11:22:33:44:54 master-interface=wifi1 name=wifi3
add configuration="cfg4 guest 2.4" configuration.mode=ap disabled=no \
    mac-address=00:11:22:33:44:55 master-interface=wifi2 name=wifi4
add configuration="cfg5 D" configuration.mode=ap disabled=no mac-address=\
    00:11:22:33:44:56 master-interface=wifi1 name=wifi5
ajmxco
Thu Jun 15, 2023 7:52 pm
Update...
7.10alpha237 worked great w/o a reboot for a couple weeks then yesterday the "handshake timeout" errors came back, the wireless clients couldn't connect, and I had to reboot again. I updated my support ticket and included the support file.
I'm not going back to 7.8 since 7.10alpha237 lasted for a couple weeks and that's fine with me; for now.
Support did say they've been able to re-create this issue on their end so that's good news.
igoork
Thu Jun 15, 2023 9:40 pm
HAP ax3, wifi 5GHz and Samsung S23 Ultra, latest 7.10 stable connection dropped and I couldn't connect again.
7.8 and before that one is where things are stable, any version past that has this problem. :?
gigabyte091
Thu Jun 15, 2023 9:50 pm
Updated ROS to 7.10 stable, little bit of PMKSA errors at the beginning, after DFS check I needed to disable and enable wifi on phone and laptop because they didn't want to connect to 5 GHz WiFi.
Now we wait for another error, this one i will discard as router just booted up.
ajmxco
Fri Jun 16, 2023 12:31 am
Another update.
Same problem just happened again today after being stable for a couple weeks. Rebooting fixed the problem. Very strange indeed...
For my setup, I've managed to find a pattern that might be legit. I've noticed that for versions greater than 7.8, when a couple Apple wireless devices (iphone, laptop, watch) connect this problem returns. When there are no Apple wireless devices connected, this problem doesn't happen. I'm not 100% sure about this but I'll continue monitoring.
hasmidzul
Fri Jun 16, 2023 3:00 am
Another update.
Same here,if no apple devices connected on wifi..it seem ok,but when i started to introduce apple devices on the mix..this problem happen.(7.9.1)
Now,just upgraded to 7.10 and hopefully this wifi problem goes away.
gigabyte091
Fri Jun 16, 2023 6:34 am
I noticed that if in phone settings, randomnized MAC address is enabled phone conncets to 2.4 GHz only, and rarely conncets to 5 GHz. Is anyone experiencing the same problem ?
ajmxco
Fri Jun 16, 2023 5:58 pm
Had to reboot again. I've sent several support files to support and notified them every time I've had to reboot. I don't want to downgrade to 7.8 again but I simply cannot use this product anymore in the current state.
I'm close to buying a different product and never using Mikrotik again.
gigabyte091
Fri Jun 16, 2023 6:13 pm
Unfortunately we all depend on Mikrotik to solve this issue with firmware updates and it's a shame to see people like you that bought Mikrotik's AP and then they have problem with that.
I myself have two Ubiquiti U6 Lite AP as I was forced to buy them because ax2 and ax3 failed at providing me with stable WiFi and they are miles away from Mikrotik ax devices for now...
Only advice right now for you is just what you said, buy new AP because right now i think that drivers won't be stable in some short time.
For eg. now i have a problem with my phone not connecting to 5 GHz WiFi while i didn't have that problem with 7.10rc1
antonvovk
Mon Jun 19, 2023 8:18 pm
Recently I have updated to 7.10 Stable hoping that the problem would finally be fixed because it was mentioned in the changelog.
wifiwave2 - fixed key handshake timeout with re-associating clients;
Sadly the problem is still there and it looks like it occurs even more frequently than in 7.9.
I had to roll back to 7.8 again :(
Guntis
Tue Jun 20, 2023 1:51 pm
We have introduced several improvements regarding the AX stability. It is still a work in progress, but in order to gather more feedback as soon as possible, here is a link to the latest alpha version that contains these fixes. The fixes are mainly targeted at the issue discussed in this thread - the inability of WifiWave2 interfaces to authenticate the clients.
Please treat it with caution. If you experience any wireless-related issues with this alpha build, then let us know at support@mikrotik.com
https://box.mikrotik.com/d/e700b4d034174bce8a22/
holvoetn
Tue Jun 20, 2023 2:45 pm
Applied to AX2 and AX3.
So far no issues seen.
gigabyte091
Tue Jun 20, 2023 8:15 pm
Tested on cAP ax, ax2, ax3 with several phones and laptops.
Running default config, only thing changed is country and cAP ax is in bridge mode, no router function, channel and frequency is set to auto (I had this manually set but i want to see how will mikrotik handle it on auto).
Before connecting devices to WiFi i forget network on all devices, just in case they maybe remembered wifi1 as unstable interface and i waited for DFS check to be over.
All devices connects to wifi1 (5 GHz) no problem and I didn't get PMKSA error like on 7.10 stable.
I'm glad and I think it's a good thing Mikrotik decided to release this alpha version to us for testing.
ToTheFull
Tue Jun 20, 2023 8:47 pm
I'm testing the hAP ax with no changes at all. 5 hour uptime all devices, no devices dropped or giving errors so far so very positive today.
I didn't want to jump in and say it's all good but I feel it needs a mention for anybody thinking of testing on a hAP ax2 I would be happy to say go ahead.
Ok so I know @maigonis didn't want us to mention speed but I'm seeing an imbalance TX vs RX rates... anybody else?
interface/wifiwave2/registration-table/print detail stats interval=0.5
Flags: A - authorized
 0 A interface=wifi1 ssid="" mac-address=C0: uptime=5h51m56s signal=-55 tx-rate=300.0Mbps rx-rate=300.0Mbps
     packets=5311,5691 bytes=294076,241276 tx-bits-per-second=0bps rx-bits-per-second=0bps
 1 A interface=wifi1 ssid="" mac-address=A0: uptime=5h51m9s signal=-53 tx-rate=1080.9Mbps rx-rate=720.6Mbps
     packets=2610231,1390432 bytes=3450818111,1451738447 tx-bits-per-second=130.7kbps rx-bits-per-second=10.9kbps
 2 A interface=wifi1 ssid="" mac-address=26: uptime=5h49m3s signal=-59 tx-rate=866.7Mbps rx-rate=526.5Mbps
     packets=278529,146200 bytes=305892385,25167344 tx-bits-per-second=0bps rx-bits-per-second=0bps
gigabyte091
Tue Jun 20, 2023 9:23 pm
Here are my speeds, nothing unusual as i can see:
[admin@MikroTik] > interface/wifiwave2/registration-table/print detail stats
 0 A interface=wifi1 ssid="Mikrotik" mac-address=XX:XX:XX:XX:XX:XX uptime=41m35s
     signal=-37 tx-rate=1201.0Mbps rx-rate=1201.0Mbps packets=54682,12745
     bytes=78344168,1592534 tx-bits-per-second=0bps rx-bits-per-second=0bps
 1 A interface=wifi1 ssid="Mikrotik" mac-address=XX:XX:XX:XX:XX:XX uptime=39m12s
     signal=-46 tx-rate=1080.9Mbps rx-rate=864.7Mbps packets=720,832
     bytes=256392,173143 tx-bits-per-second=2.1kbps rx-bits-per-second=2.3kbps
 2 A interface=wifi1 ssid="Mikrotik" mac-address=XX:XX:XX:XX:XX:XX uptime=37m23s
     signal=-38 tx-rate=1201.0Mbps rx-rate=1201.0Mbps packets=87,125
     bytes=17140,15925 tx-bits-per-second=0bps rx-bits-per-second=0bps
I'm sitting right below AP with my laptop and phone, and my wife is at the table with her laptop 3-4 meters from the AP.
ToTheFull
Tue Jun 20, 2023 9:30 pm
@gigabyte091
Thanks for that might just be the frequency I'm on.....
 /interface/wifiwave2/monitor wifi1
               state: running
             channel: 5745/ax/Ceee
    registered-peers: 3
    authorized-peers: 3
gigabyte091
Tue Jun 20, 2023 9:42 pm
I'm on 5500 MHz:
[admin@MikroTik] > /interface/wifiwave2/monitor wifi1
               state: running
             channel: 5500/ax/Ceee
    registered-peers: 3
    authorized-peers: 3
            tx-power: 22
ToTheFull
Tue Jun 20, 2023 10:00 pm
I'm on 5500 MHz:
ahh sorry below it cAP ax then ?
gigabyte091
Tue Jun 20, 2023 10:11 pm
Yea, this is from cAP ax, channel is set automatically. Did you set your channel manually ?
ToTheFull
Tue Jun 20, 2023 10:22 pm
Yes manually set just to check what I was using like for like. I'm updating the cAP ax tomorrow if the hAP ax2 keeps behaving itself.
pretty impresed so far, I will then start testing auto and the dreaded radar frequencies to see how that goes now!
off to watch film...
gigabyte091
Tue Jun 20, 2023 10:40 pm
I will setup ax2 tomorrow along with cAP ax and some devices will connect to ax2 some to cAP ax, it's not ideal as they are 1 meter apart... But for testing it will be fine, i will manually assign channels.
Enjoy the movie :D
td32
Wed Jun 21, 2023 12:17 am
tested this, SUP-114237 is not fixed yet.
can connect only by downgrading to wpa-psk
Rox169
Wed Jun 21, 2023 12:27 am
thank you.
Im missing DUDE package for my AX3
ToTheFull
Wed Jun 21, 2023 12:29 am
Umm....
 20:24:21 wireless,debug 26:@wifi1 reauthenticating
 20:24:22 wireless,info 26:@wifi1 disconnected, SA Query timeout, signal strength -54
 20:24:22 wireless,debug 26:@wifi1 disassociated, SA Query timeout, signal strength -54
Help me understand!
Edit add:
So here is the same device deciding to connect to a 2.4g AP upstairs lol...
20:24:22 wireless,info A6:@wifi2 connected, signal strength -75
20:24:22 wireless,info A6:@wifi2 disconnected, connection lost, signal strength -75
20:38:58 wireless,info A6:@wifi2 connected, signal strength -76
dewitpj
Wed Jun 21, 2023 5:46 am
Following.
FYI - Deployed the 7.11 alpha on my CAP and HAP with FT, so far...it's good
gigabyte091
Wed Jun 21, 2023 6:19 am
Yea, now I noticed following errors to:
 06-20 19:28:09 wireless,info XX:XX:XX:XX:XX:07@wifi1 disconnected, SA Query timeout
, signal strength -61
 06-20 21:34:17 wireless,info XX:XX:XX:XX:XX:1C@wifi1 disconnected, SA Query timeout
, signal strength -66
06-20 22:24:05 wireless,info XX:XX:XX:XX:XX:1C@wifi2 disconnected, SA Query timeout
, signal strength -68
I will sent supout file to support.
ToTheFull
Wed Jun 21, 2023 11:07 am
good plan.
Here's the pattern from last night from just the 1 device, WiFi 5 Ipad Air 2 playing up.
Jun/20/2023 20:24:21 wireless,debug       26:@wifi1 reauthenticating
Jun/20/2023 20:24:22 wireless,info        26:@wifi1 disconnected, SA Query timeout, signal strength -54
Jun/20/2023 20:24:22 wireless,debug       26:@wifi1 disassociated, SA Query timeout, signal strength -54
Jun/20/2023 22:52:36 wireless,debug       26:@wifi1 associated, signal strength -56
Jun/20/2023 22:52:36 wireless,info        26:@wifi1 connected, signal strength -56
Jun/20/2023 22:52:36 dhcp,info            defconf deassigned  for 26:
Jun/20/2023 22:52:37 dhcp,info            defconf assigned  for 26:
Jun/21/2023 04:03:20 wireless,debug       26:@wifi1 reauthenticating
Jun/21/2023 04:03:21 wireless,info        26:@wifi1 disconnected, SA Query timeout, signal strength -53
Jun/21/2023 04:03:21 wireless,debug       26:@wifi1 disassociated, SA Query timeout, signal strength -53
gigabyte091
Wed Jun 21, 2023 11:24 am
Maybe you should send them supout also...
ToTheFull
Wed Jun 21, 2023 12:27 pm
If I had a lab I would, not happy sharing all my Live Enviroment if I am 100% honest after mooching through the supout.rif myself.
gigabyte091
Wed Jun 21, 2023 1:31 pm
Understandable, my devices are for testing right now so no problem there. But regarding those errors i didn't noticed any slowdowns or disconnections...
I sent Mikrotik support file this morning, ticket #: SUP-119840
ToTheFull
Wed Jun 21, 2023 1:44 pm
Yeah it's just the 1 device that has played up so far, thats a wpa2 only device that Apple refuses to stop supporting gah!
I've moved on to testing Auto now and seeing how I get on with the "radar detected" situation I was having fun with last time I tried.
Any-who gong off topic here.
maigonis
Wed Jun 21, 2023 8:10 pm
I have seen no speed related issues so far.
ToTheFull
Wed Jun 21, 2023 8:57 pm
Now I've moved to 5500 Ceee I'm even again. It's more than like I've been on 5745 Ceee for so long you tend to notice small nuances.
Slowwly been moving around using Auto which has just kept moving me down in frequency to my delight. The reason I fixed the frequecy previously was because being kicked all over the place due to radar detection, we live on a big hill. Glad to say that now for some reason seems far better.
gigabyte091
Wed Jun 21, 2023 9:39 pm
So speeds are better now ?
EDIT: On cAP ax i get only one more SA Query error, now i disabled cAP ax radio and i moved to ax2 for a day or two. So far so good
gigabyte091
Wed Jun 21, 2023 10:44 pm
Yea, SA Query error on ax2 also, i went upstairs so signal dropped, i noticed that i lost internet because i just started loading video.
ToTheFull
Wed Jun 21, 2023 10:45 pm
Yeah the speeds TX vs RX much better compaired to yesterday aye.
 0 A interface=wifi1 ssid="" mac-address=C0: uptime=3h33m29s signal=-53 tx-rate=300.0Mbps rx-rate=300.0Mbps
     packets=3384,3471 bytes=184876,147652 tx-bits-per-second=480bps rx-bits-per-second=336bps
 1 A interface=wifi1 ssid="" mac-address=A0: uptime=3h33m11s signal=-47 tx-rate=1080.9Mbps rx-rate=1080.9Mbps
     packets=2545658,228609 bytes=3657927066,24717188 tx-bits-per-second=53.7kbps rx-bits-per-second=4.9kbps
  2 A interface=wifi1 ssid="" mac-address=26: uptime=3h30m45s signal=-54 tx-rate=866.7Mbps rx-rate=866.7Mbps
     packets=204569,85395 bytes=237163295,20363318 tx-bits-per-second=1025.2kbps rx-bits-per-second=28.8kbps
I've come to a conclusion that some WiFi5 stuff just doesn't like the higher frequecies offered by the Wifi6 device ie stick to 5500 Ceee for a better
experience.
@gigabyte091 if you get chance can you try 5745-5805
gigabyte091
Wed Jun 21, 2023 10:48 pm
Will try it tommorow, wife is streaming her show on netflix so now it's not a good time to mess with the wifi :lol: :lol: :lol:
ffries
Wed Jun 21, 2023 10:51 pm
Since 7.10 the hap AX3 seems more stable:
Uptime		3d 04:15:44
ToTheFull
Wed Jun 21, 2023 10:55 pm
cheers, that woudn't be a good idea no!
Beer Oclock plus Movie...
gigabyte091
Wed Jun 21, 2023 11:18 pm
Yea :lol: I hope that the drivers are stable... I really wouldn't like to be beaten by a laptop :lol: :lol:
I will check speeds with higher frequency tommorow.
@ffries, you have wifi issues or overall stability issue ?
dewitpj
Thu Jun 22, 2023 1:27 am
It appears that here we go again:
06-22 10:26:15 wireless,debug BC:FF:4D:F9:FC:33@wifi3 disassociated, key handshake timeout, signal strength -47
06-22 10:26:16 wireless,debug DC:4F:22:78:A9:BD@wifi3 disassociated, key handshake timeout, signal strength -78
06-22 10:26:18 wireless,debug 30:83:98:A6:F4:81@wifi3 disassociated, key handshake timeout, signal strength -67
06-22 10:26:18 wireless,debug 1C:39:29:32:ED:FC@wifi2 disassociated, key handshake timeout, signal strength -48
06-22 10:26:19 wireless,debug C8:2B:96:05:15:EE@wifi3 disassociated, key handshake timeout, signal strength -40
gigabyte091
Thu Jun 22, 2023 7:19 am
Can you send supout file to support ?
I changed frequency to 5745:
0 A interface=wifi1 ssid="Mikrotik" mac-address=XX:XX:XX:XX:XX:1C uptime=7m1s
signal=-51 tx-rate=720.6Mbps rx-rate=960.8Mbps packets=724,854
bytes=452507,122083 tx-bits-per-second=0bps rx-bits-per-second=0bps
ToTheFull
Thu Jun 22, 2023 10:16 am
Thanks any idea what power that was ? "India If low"
gigabyte091
Thu Jun 22, 2023 2:45 pm
               state: running
    registered-peers: 1
    authorized-peers: 1
            tx-power: 9
  available-channels: 5745/ax/Ceee
This is on ax2
dewitpj
Thu Jun 22, 2023 4:34 pm
Sending now
ToTheFull
Thu Jun 22, 2023 9:10 pm
               state: running
    registered-peers: 1
    authorized-peers: 1
            tx-power: 9
This is on ax2
Thanks yet again for trying, yours seems ok the rates are low because of the power level I was testing with 19.
All testing stopped for now because the device that was disconnecting is on a 24 hour test on a wifi5 AP just to make sure!
Test Settings
        26:  -54 dBm / -101 dBm (SNR 47)  80 ms ago
        RX: 866.7 MBit/s, VHT-MCS 9, 80MHz, VHT-NSS 2    134576 Pkts.
        TX: 866.7 MBit/s, VHT-MCS 9, 80MHz, VHT-NSS 2    340797 Pkts.
        expected throughput: unknown
wlan0     ESSID: ""
          Access Point:
          Mode: Master  Channel: 100 (5.500 GHz)
          Center Channel 1: 106 2: unknown
          Tx-Power: 24 dBm  Link Quality: 59/70
          Signal: -51 dBm  Noise: -101 dBm
          Bit Rate: 866.7 MBit/s
          Encryption: mixed WPA2/WPA3 PSK/SAE (CCMP)
          Type: nl80211  HW Mode(s): 802.11nac
          Hardware: 168C:003C 0000:0000 [Qualcomm Atheros QCA9880]
          TX power offset: none
          Frequency offset: none
          Supports VAPs: yes  PHY name: phy0
gigabyte091
Thu Jun 22, 2023 10:00 pm
This power is set automatically, i will try to bump it up manually, but for now im testing on ax2 until monday, so far so good.
deanMK
Thu Jun 22, 2023 10:12 pm
Installed 7.11alpha version today on hAP AX3. Will inform here if some problems occured.
dewitpj
Fri Jun 23, 2023 12:47 am
What is the best version to run - the Beta or the Alpha ?
The Beta appears to contain some of the fixes ?
gigabyte091
Fri Jun 23, 2023 7:39 am
Someone from Mikrotik support wrote in the other topic that this beta version contains all changes which are introduced in alpha version
kaosaly
Fri Jun 23, 2023 9:55 am
7.11beta2 nothing changed, the same problem on AX3. Tried Netinstall on AX2 a couple of weeks ago, it have helped, no WIFI drops. Will try Netinstall on AX3 .
Kitsok
Fri Jun 23, 2023 3:13 pm
Hello!
Just my report.
I have same issues with key handshake timeout since (probably) 7.9
After upgrade to 7.10 this issue became annoying: I had to reboot router something between 10 minutes and 12 hours.
Today I gave up and downgraded to 7.8, will report how it goes.
Update: almost forgot. I also had to switch from WPA3 to WPA2 to make it work, but I did it on 7.10, not sure if WPA3 is broken in 7.8
gigabyte091
Fri Jun 23, 2023 3:26 pm
Try 7.11beta2 and see if that helps
Teslazavr
Fri Jun 23, 2023 4:21 pm
Greetings to the community. I have the same issue with my hap ax3 after updating to 7.9 and then to 7.10 and today on 7.11beta2 did not solve the issue with the stability of WiFi, which stopped working 2 hours after updating to 7.11beta2 and the device had to be rebooted
ajmxco
Fri Jun 23, 2023 8:06 pm
I rode the roller coaster of this problem and eventually downgraded to 7.8 w/o issue (see my posts in this thread). I want to be part of the solution so I'll give 7.11beta2 a go this weekend and report back.
ToTheFull
Sun Jun 25, 2023 3:14 pm
I'm having a much better exerience with hAP ax2 7.11-Alpha127 (7.11Beta2)
Installed beta2 on cAP ax today no issues do far, also notice since 7.7 the Radar Detection problems I was having have gone so thats a Big Plus.
speeds and signal have varied since 7.5 on my hAP ax2 at least so it's an on-going journey which is getting better i'm happy to say.
gigabyte091
Sun Jun 25, 2023 8:27 pm
7.11 stable could be "the one", no problems so far, everything is working like a charm :D (knock, knock, knock so i don't jinx it)
holvoetn
Sun Jun 25, 2023 8:32 pm
Knock on head ?
Same as wood ?
:lol:
gigabyte091
Sun Jun 25, 2023 9:02 pm
No, no, this is important, real wooden table, no head this time :lol:
deanMK
Sun Jun 25, 2023 10:49 pm
WiFi performances are still crap. hAP AX3.
gigabyte091
Mon Jun 26, 2023 6:26 am
Compared to what ? On my tests ax2 performed better than U6 Lite. And I'm not biased, I switched to Ubiquiti because Mikrotik wireless had a lot of problems back then...
Njumaen
Mon Jun 26, 2023 8:20 am
I totally agree BUT did anyone manage to get VLAN Slave interfaces (for guest wifi) up an running via capsman?
If I set the VLAN tag in the capsman configuration it is NOT passed to the cap interface and therefore this is not dynamicly added to the tagged vlan of the caps bridge.
local interfaces without capsman work fine this way…
FurfangosFrigyes
Mon Jun 26, 2023 8:48 am
I add the guest interface to the bridge manually and set up the VLAN. It is not a nice solution. If i change anything on CAPSMAN side the name of the slave interface will be changed on the CAP and i have to reboot the CAP to restore the interface name/numbering otherwise the bridge config will be failed.
gigabyte091
Mon Jun 26, 2023 10:37 am
Only reason I'm thinking about CAPsMAN is roaming... but i think i will skip it, to much trouble for 2 AP
Rox169
Mon Jun 26, 2023 10:44 am
If ROS is working there is no much trouble with capsman. I have it for two AP too
Njumaen
Mon Jun 26, 2023 1:27 pm
Roaming is soooo awesome! I have 3 CAP an CAPsMAN running on my 1100ahx4… Found out: running CAPsMAN on a CAP seems not so to be a bright idea.
Njumaen
Mon Jun 26, 2023 1:28 pm
I will try it your way unless this is fixed.
Joe1vm
Mon Jun 26, 2023 2:06 pm
You can select and add ALL dynamic interfaces into the bridge. Then, when new/changed guest intrface is created, it is added automaticaly to the bridnge.
FurfangosFrigyes
Mon Jun 26, 2023 3:21 pm
I do not want to do it automatically!
igoork
Mon Jun 26, 2023 4:18 pm
I still have ocassional wifi drop every few days but this time nothing in the log, it just says client disconnected.
It's on latest beta 7.11.
After reboot everything works again, On 7.8 there is no problem, everything is smooth.
Kitsok
Mon Jun 26, 2023 4:59 pm
Hello!
Just my report.
Okay. It failed on 7.8 after some time. There are "key handshake timeout" in log and >20% CPU utilization.
I've disabled 80MHz channel width (20/40 now on both 2.4GHz and 5GHz), enabled FT, disabled WPA3 (now on WPA2) and upgraded to 7.11b2.
It worked for more than 24 hours, but now it failed again, so I gave up and added a reboot script to be ran every 10 minutes on the home server.
It should be installed onto Mikrotik itself, but I'm not good at writing scripts for MT.
#!/bin/bash
REBOOT_CMD="/system/reboot"
MT_HOST="main_router"
MT_USER="secretuser"
MT_PORT=123456
LOG_LIMIT=20
DEBUG=true
log() {
        local ts=$(date +%Y-%m-%d_%H:%M)
        [ "$DEBUG" = "true" ] && echo $ts : $@
        logger -t "check_mikrotik" "$@"
num_syslog=$(cat /var/log/syslog | grep wireless,debug | tail -100 | grep "key handshake"  | wc -l)
log "num_syslog=$num_syslog limit:$LOG_LIMIT"
[ $num_syslog -gt $LOG_LIMIT ] && log "Limit exceeded, rebooting" && ssh -p $MT_PORT ${MT_USER}@${MT_HOST} $REBOOT_CMD </dev/null
Rox169
Mon Jun 26, 2023 11:09 pm
what failed again? Did you send supout? If my router restart every 10 minutes it would make me crazy..better to insall 7.8
sudanking
Tue Jun 27, 2023 6:46 am
I have to reboot my hAP ax3 every hour to fix wifi problem....I get back to 7.8
Rox169
Tue Jun 27, 2023 7:44 am
what problem? there are more problems...did you send supout to MT?
hasmidzul
Tue Jun 27, 2023 10:29 am
Mine still going strong.Mix androids and iphone.WPA2/WPA3 mixed.AX mode.
[xxxx@xxxhome ] > system resource print
                   uptime: 5d21h26m26s
                  version: 7.10 (stable)
               build-time: Jun/15/2023 05:17:29
         factory-software: 7.5
              free-memory: 590.1MiB
                      cpu: ARM64
                cpu-count: 4
                 cpu-load: 1%
           free-hdd-space: 94.6MiB
  write-sect-since-reboot: 1027
         write-sect-total: 57474
               bad-blocks: 0%
               board-name: hAP ax^3
                 platform: MikroTik
[xxxx@xxxhome ] > interface wifiwave2 registration print
Flags: A - AUTHORIZED
Columns: INTERFACE, SSID, MAC-ADDRESS, UPTIME, SIGNAL
#   INTERFACE  SSID    MAC-ADDRESS        UPTIME   SIGNAL
0 A 2GHz       2GHzAX  xxxx58:73  3h9m42s  -42
1 A 5GHz       5GHzAX  xxxxxF2:C9  3h9m25s  -47
2 A 2GHz       2GHzAX  xxxxEA:1B  3h7m9s   -56
3 A 2GHz       2GHzAX  xxxx76:87  1h7m13s  -36
[xxxx@xxxhome ] >
Kitsok
Tue Jun 27, 2023 12:33 pm
Devices started to reconnect, key handshake timeout messages started to fill log. It wasn't after 10 minutes, at least now I see devices that connected 8.5 hours ago and still up.
I have tried 7.8 and faced the same issue.
Update: I've also noticed that enabled 80MHz on 5GHz increases the instability (reduces time between fails).
Another observation is that Apple devices (iPhone and MacBook) stayed connected while Android phones and my Linux notebook failed to connect (with "key handshake timeout" diagnostics in wireless debug log).
PeterXC
Re: ax series lineup WiFi issues
Tue Jun 27, 2023 10:55 pm
it looks like they finally fixed it in 7.10
Rox169
Tue Jun 27, 2023 11:22 pm
no, not even in 7.11
dewitpj
Wed Jun 28, 2023 12:08 am
Yip, Same here - still have to reboot quite often to get Wifi to work...
Kitsok
Wed Jun 28, 2023 12:30 am
I will able to confirm or refute it tomorrow, but looks like access list is causing wifi driver to fail with "key handshake timeout". Will report.
Kitsok
Wed Jun 28, 2023 10:10 am
Didn't help. Uptime raised to 8 hours, but then it failed again.
dewitpj
Wed Jun 28, 2023 10:44 am
I have no access lists and it's broken
epkulse
Thu Jun 29, 2023 1:22 pm
I had the failure with "key handshake timeout" again today, 2 nd time in roughly a week. I run CAPSMAN wifiwave2 with 2 HAP-AX3 and 1 HAP-AX2. Suddenly one HAP-AX3 refused connection on 5GHz. However, I was still able to connect to 2,4 GHz on the same CAP, where I use WPA/WPA2 security only due to old devices. Tried to disable/enable 5G-wifi, no luck. Changed from WPA2/3 to WPA/WPA2 on 5 G, no luck. Changed to AC-only on 5G, no luck. Eventually rebooted this CAP, woks fine again.
Ticket raised with supout to support...
Rox169
Thu Jun 29, 2023 1:29 pm
on which version of ROS? 7.10 or 7.11beta?
epkulse
Thu Jun 29, 2023 1:42 pm
Sorry - 7.11 Beta 2...
gigabyte091
Thu Jun 29, 2023 9:55 pm
Interesting... I will try CAPsMAN this weekend, RB4011 as controller, 2 cap ax as CAPs, no VLANs, basic for now, just to see if it will be stable. For now i don't have any problems.
holvoetn
Thu Jun 29, 2023 10:11 pm
I have a setup with RB5009 as capsman server, 2 cAP AX and 1 AX3 running for quite a while (11 days and counting).
No VLANs for now.
All on 7.10.
Apart from 1 SW update (otherwise it would be over 20 days already), no hickups whatsoever.
There is even a network enabled machine connected for over 8 days straight, no problems with it.
Only noticeable entries I see in log are related to devices coming in and devices going out of range.
No deauth errors, no PMKSA errors, nada.
gigabyte091
Thu Jun 29, 2023 10:42 pm
Sooo, maybe I retire U6 Lite soon and go back to Mikrotik wireless again. I don't see any errors in logs whatsoever.
I mean, im running basic setup but i don't see reason the reason wifi will not work with vlans.
UpRunTech
Fri Jun 30, 2023 12:24 am
I have hAPAX's running in the house now with CAPSMAN and all is well but for the Epson Workforce 435 printer no longer connecting. The log shows:
00:26:AB:CC:E3:B2@cap-wifi7 rejected, invalid MDE
Google is not much use to me, it must be something deeply technical in the Wifi spec.
The only concern here is if and when I start deploying AX devices to clients that I don't start having issues with equipment that might be old but otherwise working well and "buy a new scanner/printer" isn't a solution for clients.
anav
Fri Jun 30, 2023 1:00 am
No VLANs for now.
All on 7.10.
Statistical anomaly of 1,doesn't count (insignificant) ! ;-P
holvoetn
Fri Jun 30, 2023 8:27 am
Hmmm ...
It has the value of proving the whole concept is not totally broken since it works at least for 1
8)
epkulse
Fri Jun 30, 2023 10:40 am
I have read statements that 7.8 may be stable? Is that true? So downgrading to 7.8 may help until bug is fixed?
Rox169
Fri Jun 30, 2023 10:53 am
Yes
epkulse
Fri Jun 30, 2023 11:13 am
OK, downgraded 3 CAP´s now to 7.8 and hope for the best...
holvoetn
Fri Jun 30, 2023 11:15 am
Depending on what you do with those caps, you may want to reconsider ...
7.8 was (up til 7.10 and later) the more stable one for wifi.
But it was only with 7.9 default script was added for caps mode.
So when you are able to configure everything yourself, no problem.
If you rely on default script to handle caps mode, you need at least 7.9 (which is to be avoided).
deanMK
Fri Jun 30, 2023 11:31 am
Dont make mistake. UBNT wireless is superior compared to buggy Mikrotik wireless. Stay with UBNT!
gigabyte091
Fri Jun 30, 2023 12:35 pm
Right now, Mikrotik wireless is working without a problem, at least for me, without any bugs and I never really intended to stay on UBNT, just until Mikrotik sort their wireless right. (Some of us need to stay on Mikrotik and test it until they got it perfect). Also I'm not really fan of mixing vendors together, if I use Mikrotik, I want to stay on Mikrotik.
UBNT is working great, their app is awesome, and configuration is really easy but I don't like the fact that I have to have dedicated controller or, like I saw that some vendors don't even have anything but cloud based management. I want local management and I like when I can log into device from browser. (I use winbox but I have an option to log from browser)
But those are just my personal preferences.
And in iperf3 tests I got faster speeds on ax2 than on U6-Lite for eg.
epkulse
Fri Jun 30, 2023 2:51 pm
Worked OK to downgrade - all config remained... Let´s hope it is more stable, though...
DarkNate
Fri Jun 30, 2023 4:21 pm
I've seen zero disconnections since 7.10 on my ax2. Seems stable to me for the last many days.
bristic
Fri Jun 30, 2023 11:43 pm
Got two cAP ax, managed with wifiwave2 capsman from RB3011, all at version 7.10.1 - 99% of devices work except HP Printer (PageWide Pro MFP 477dw)
I tried several attempts to create configuration that would comply to 802.11n 5GHz dual band printer capabilities, but simply wireless network is not listed in there.
I assume it is because of the Channel extension ax, because whatever I do I cannot make it to run without it, current status is (5745/ax/Ceee).
However if I list radio capabilities there are all flavors 5745/a, 5745/n, 5745/n/Ce, 5745/ac, 5745/ac/Ce, 5745/ac/Cee, 5745/ax, 5745/ax/Ce, 5745/ax/Cee (Country Netherlands)
Is it possible to somehow specify the channel, for example, 5745/n?
Of course this would be the SSID for printer network only, the rest is running fine on ax... I appreciate any ideas :)
holvoetn
Fri Jun 30, 2023 11:58 pm
A bit of a problem there ... you can only change radio behavior on the main radio.
Any slave radio with a different SSID, will use the same radio settings.
When you specify a channel as ax, any device connecting with N or AC should be able to connect (at least that's my experience).
So I am going to make an educated guess the problem is not with the channel but the security settings.
But ... as it happens to be I also have one of those with a customer I work for.
And those things can only connect to 2.4GHz, not 5GHz as far as I know ?
I even went back to check the product manual, it clearly says so: 2.4GHz only.
HOWEVER: the features page does indicate dual band 802.11n incl 5GHz.
So go figure.
Can you try using 2.4GHz SSIDs ? Try an SSID with only WPA, nothing else and no encryption. For testing even no security at all (just for testing).
If you want to try further using 5GHz, setting the channel can be done on multiple places:
In configuration you can specify which channel or band to use. That config is then applied on the radio (if possible).
Or
On the radio, you can specify the channel/band directly (tab with the logical name ... channel :lol: ).
Keep in mind, priority of settings is from left to right in Winbox. Setting on the left has priority over the same setting on the right.
If you set channel directly on radio, the one set in config is not taken into account anymore.
bristic
Sat Jul 01, 2023 10:44 am
Thank you @holvoetn for the reply, I learned a lot and here are my findings:
I managed to make it work with 2GHz G on channel 2422/g with security WPA/WPA2, I left ciphers choice without any selection.
I tried all radios on 5GHz and on 2GHz and the only one that works is the one from above, so now when I list the networks on printer's display, I can find the SSID finally :shock:
What I will try to do next is to see if I can update printer's firmware, maybe that will help.
Now the tricky part...
So this means that we need to sacrifice one of the radios for legacy devices?
Although we are able to make security, channel and configuration profiles, we are still not able to make radio profiles, correct?
holvoetn
Sat Jul 01, 2023 4:20 pm
Not really.
You don't have to sacrifice a radio for legacy device. But you will have to accept those legacy devices will slow down your network on that radio for all other devices. Slowest one dictates the pace.
Consider it an opportunity to get rid of those dinosaurs :lol:
If on that radio you set a slave interface with another SSID, it will use the same radio settings (channel and band).
Security settings however can be different on a slave interface.
Radio settings not, they come from the master. Channel is a radio setting. So is band (AX, B/G/N, N-only, ...)
bristic
Sat Jul 01, 2023 7:30 pm
Allright....@holvoetn this took a bit of our precious time, so final verdict - printer is working fine on 2G AX (2422/ax/Ce)
The problem was that I left too much unset.. so the frequency range :oops: . Somehow controller was always setting the frequency in one of the channels 12 (2467Hz), 13 (2472Hz) and/or 14 (2484Hz) which are not supported by the printer interface :lol:
I configured 2G master for channels 1-12 (2412-2462) e voila! I tried to do the same for 5G, but that does not work yet. tried several frequencies from the scanned list none work :lol:
As you mentioned previously, Radio settings cannot be changed in slave interfaces and I am happy that I solved this issue this way, thank you very much for your help once again!
Some sources https://en.wikipedia.org/wiki/List_of_WLAN_channels
And I found this topic as well viewtopic.php?t=167719
Kitsok
Sat Jul 01, 2023 10:37 pm
Okay, here I am again.
It's a goddam magic, the dark forces of the electricity.
Last message here was 28.06, and after that I had no key handshake timeouts anymore, uptime is since 28.06.
What changed:
1. My wife moved our wireless printer to another floor, so now it's standing ~30cm from CAP;
2. The worker finished plastering one of the rooms in the house, so -1 old Android phones from the connected devices.
I didn't change configuration, upgrade MT firmwares, etc.
What I can assume is the workers' phone did not support WiFi-6, that's basically all I can think about. The conclusion from this assumption is that old device may lead to some failure inside wireless drivers on AX devices.
deanMK
Sun Jul 02, 2023 10:27 am
With this ISP speed get constantly Youtube buffering on my AndroidTV box even on 1080p with wired connection. Wifi randomly goes down and for some moments i cant load nothing at all on my smartphone. HAP AX3. This device is worst one until i using Mikrotik products. Even previous hAP AC3 is working better and stable then this one. Latest 7.11beta2 firmware. Disappointed from how works this device. RoS 6.X was stable for months, RoS 7.X constantly problems with it.
ttrs
Sun Jul 02, 2023 11:40 am
Hi. For information - my ax2 wifi issue was fixed with 7.10.1.
A problem had been introduced with 7.9. I did not try versions after 7.9 before 7.10.1.
viewtopic.php?p=1010935#p1010935
holvoetn
Sun Jul 02, 2023 12:05 pm
Well ... my ISP at home is 500/30. Using a wifi5 card in my laptop towards AX3 running 7.11b2
Maybe time for you to start a new thread with your specific config ?
gigabyte091
Sun Jul 02, 2023 12:26 pm
So, now with CAPsMAN enabled and everything, on my devices I get 160/120 Mbps, and on PC with wired connection I get 169/128 Mbps. Everything is working for now.
I even get better speeds now when I'm using CAPsMAN... iperf3 avg is about 660 Mbps, max was about 723 Mbps.
I will leave like this for a week or two, then i need to add vlan's into play so i can fully migrate to mikrotik wifi.
holvoetn
Sun Jul 02, 2023 12:37 pm
That's a venture I am not embarking on yet: the combo wifiwave2-capsman and vlan :lol:
It doesn't work yet like it used to work 'in the old days' and you need to do quite some manual intervention on the caps-bridge to get vlan handling working correctly (as far as I understood from last time I toyed with it which was on 7.8 ).
I haven't seen any indications yet that issue is solved / optimized.
gigabyte091
Sun Jul 02, 2023 2:22 pm
I saw some instructions regarding VLAN on capsman with wifiwave 2
https://help.mikrotik.com/docs/display/ ... onexample:
bristic
Mon Jul 03, 2023 10:27 am
..another bummer, on my Dell XPS I have Intel Killer Wireless-n/a/ac 1535 Wireless Network Adapter...
It refuses to connect to 5GHz, whatever I try to do on the laptop adapter by changing the "Wireless mode" it just recognizes 2.4GHz 802.11n 300/300Mbps with WPA3-Personal
I have old TP link at the attic and I can "see" SSID and connect to 5GHz 802.11ac 400/400Mbps with WPA2-Personal
The only time SSID is visible on 5GHz is if I set Wireless Mode on adapter to Device Manger > Network adapters > Killer Wireless.. > Advanced > Wireless Mode > 10-11 a/g/n/ac or another variant with "ac" and then 5GHz is scanned properly and after a few moment's is gone from the list. Connection is not possible during this period.
Logs on MK are blind.... My conclusion is that driver on the adapter requires explicit AES cipher to allow connection :( any ideas?
sudanking
Mon Jul 03, 2023 11:01 am
It is working good so far ... Last 12 hours without restart.
Thanks for sharing alpha.
Where I get updated version of alpha? It is not published any where!
gigabyte091
Mon Jul 03, 2023 11:18 am
7.11beta2 is same as this alpha version.
Guntis
Mon Jul 03, 2023 2:57 pm
We made some progress in regard to fixing this issue.
Here is a new RouterOS release that contains several improvements regarding the AX stability. The fixes are mainly targeted at the issue discussed in this thread - the inability of WifiWave2 interfaces to authenticate the clients.
While the issue should be resolved, it is still a work in progress, in order to gather more feedback as soon as possible, here is a link to the latest alpha version that contains these fixes.
https://box.mikrotik.com/d/d17a854bfb0948f6b77d/
ToTheFull
Mon Jul 03, 2023 3:05 pm
Thanks snagged a copy
mkx
Mon Jul 03, 2023 3:12 pm
Do you have both wireless interfaces configured with exactly the same security settings?
What I found out is that a few of my wireless clients didn't like if I enabled any of gcmp* encryption types. So now I'm running my Audience (ac device) with these parameters:
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk dh-groups=19,20,21 disable-pmkid=yes \
    encryption=ccmp,ccmp-256 ft=yes group-key-update=5m name=mysecprofile wps=disable
and all clients are pretty happy (also those that don't know a squat about WPA3). Those that only know about WPA2 use AES encryption while others mostly use CCMP (I don't know if I ever saw any client to use CCMP-256 and as mentioned, including GCMP did upset some clients).
smotrov
Mon Jul 03, 2023 3:48 pm
Is this 7.11beta2 or other build?
I uploaded
routeros-7.11alpha179-arm64.npk
and
wifiwave2-7.11alpha179-arm64.npk
to the root directory of my AX2. And after reboot nothing is changed, except files are disappeared. I'm still on 7.11beta2 (2023-Jun-21 14:39).
Am I doing something wrong?
maigonis
Mon Jul 03, 2023 3:53 pm
I uploaded
and
As 7.11alpha it is considered as downgrade by ROS in your case, so you need to "downgrade". (In package list there is button, but in general check docs to understand how this works)
gigabyte091
Mon Jul 03, 2023 4:39 pm
Installed alpha build on 2×cAP ax and 1×hAP ax3, everything started right up, now we will see if there will be any problems.
massinia
Mon Jul 03, 2023 11:12 pm
Thanks Guntis :)
hAP ax3+hAP ax2+ cAP ax updated
bristic
Mon Jul 03, 2023 11:43 pm
Yes I do have both radios under the same name, but when I test I turn the radio 2.4GHz off.
Thank you for the config, I tried but still no success :(
bristic
Mon Jul 03, 2023 11:49 pm
I installed it and my issues with Dell XPS Wifi adapter Intel Killer Wireless-n/a/ac 1535 still persists. But I am optimist and happy to be tester for a while 8)
holvoetn
Tue Jul 04, 2023 12:00 am
Please don't take this wrong but that's a wireless adapter from ... 2015/2016 ? Something like that ?
Heck, even my laptop having Intel Wireless-ac 9560 doesn't have a problem with AX
(but it's only wifi5, not 6).
Wouldn't it be easier for your mental health to get a sub-40 EUR TP Link TX20U (USB3) and enjoy AX speeds as they need to be ?
That's what I did (ok, for testing but I admit being a tech-geek :lol: )
bristic
Tue Jul 04, 2023 12:17 am
I am not taking it wrong, of course not. Laptop itself is about 5y old, that is one of the flagship Dell laptops with Intel i9 CPU etc... but crappy WiFi adapter apparently.
But I am worried because it can connect to 5GHz (thus higher speeds) on my TP LINK EAP330 which is also EOL product and it cannot to the brand new cAP AX.
I also have 2 x TP Link EAP 610 v1 (two years old) which are also WiFi 6 and I am replacing them with 2 x caP AX now. Also with them I had not a single problem of the same kind.
Much older Dell laptop, like 10y old, connects easily on 5GHz on cAP AX without any issues. So it is adapter problem indeed, but... what is the problem? :lol:
gigabyte091
Tue Jul 04, 2023 6:14 am
I don't know if problem is is my phone or what... My wife's phone roams without a problem, my phone on the other hand... I go downstairs and i see that signal is almost gone but it's still connected to the upstairs AP... On 5 GHz band...
Then phone reconnects to downstairs AP, but only after signal drops and phone disconnects...
Maybe i should decrease TX on APs ? Any other suggestions ? I don't think it's a problem with APs...
chechito
Tue Jul 04, 2023 6:31 am
yes, decreasing TX power on AP can help to tune client roaming behavior, you must verify how much you can lower TX power without harming coverage on intended areas
AP TX power tunning can help to make client prefering 5ghz over 2.4ghz if you need that
gigabyte091
Tue Jul 04, 2023 7:37 am
I set power to 10, I believe that for cAP ax 24 is max, now i will test for a while... But i find my phone to be very clingy :lol: I put it on top of the upstairs AP and it's still connected to downstairs AP...
chechito
Tue Jul 04, 2023 7:50 am
sometimes other way to influence roaming behavior on client devices can be AP location
for example you can take advantage of existing objects or elements to reduce or favor your coverage in some directions
the objetive is locate the AP in some way that its obstructed from covering the zone where you want client devices to roam to other AP without harming coverage in the zones you intend to have good coverage
i know can be tricky, reducing TX power helps to make this changes more notorious
gigabyte091
Tue Jul 04, 2023 9:04 am
My AP placement is not perfect, I didn't account for AP's when house was in remodelling so now one AP is on a shelf (downstairs AP) and another AP is right above downstairs AP on my desk.
I disabled 5 GHz Wi-Fi on Ubiquiti so no interference from 5 GHz but 2.4 I must leave on because my IoT and security is connected to Ubiquiti for now as I don't want to tackle with workarounds with VLAN's and CAPsMAN now...
I'm going trough logs and i can see for eg. that wife phone roams no problem and my roams in the way that i get SA Query timeout and then it reconnects to another interface... but interesting, wifiman for android reports that device roamed between 2 AP
holvoetn
Tue Jul 04, 2023 9:10 am
See this post from Guntis again:
viewtopic.php?p=1009820#p1009820
SA Query timeout on itself is not to be considered as an issue (unless it's really FLOODING your logs).
Your wifiman app on Android seems to confirm that.
ToTheFull
Tue Jul 04, 2023 9:39 am
Anybody else with 0 Bytes wifi
2 A interface=wifi2 ssid="" mac-address=60:6B uptime=20m49s signal=-92 packets=0,0 bytes=0,0 tx-bits-per-second=0bps
3 A interface=wifi2 ssid="" mac-address=F2:AA uptime=8m26s signal=-54 packets=0,0 bytes=0,0 tx-bits-per-second=0bps
gigabyte091
Tue Jul 04, 2023 10:05 am
Don't worry, I don't consider that as an error. What bothers me is that wifiman reports roaming but logs don't... But wife phones roams no problem
Kitsok
Tue Jul 04, 2023 11:53 am
Updated yesterday, so far so good, no key handshake timeout.
But I already had normal behaviour with 7.11b2.
Did you manage to find a root cause, if I may ask?
Thank you!
kinx
Tue Jul 04, 2023 5:30 pm
Really annoying, I started installing Cap AX at customers, and while it was working from my laptop, may other devices weren't. Customers were furious xD
Finally found this thread, and solved the problem... I hope it will remain stable now...
@MikroTik, please communicate transparently with your customers and professional installers, and DON'T RELEASE NOT WORKING PRODUCTS any more. Hire some testers before releasing a product with failing software on the market.
gigabyte091
Tue Jul 04, 2023 6:19 pm
Yea, here I must agree, it's annoying when it's not working for us.
And most of us are testing for now.
But when you have a paying customer that's a different story... It your ass on the line...
I know lot of people that use Mikrotiks router and switches but for wireless... No, mostly ubiquiti... Similar price range but much much more polished software...
kinx
Tue Jul 04, 2023 6:23 pm
When I compare prices prices for Ubiquiti are 20 to 50% higher than similar MikroTik devices... Maybe I should look for some other distributors, but when I did last year, prices were almost similar...
gigabyte091
Tue Jul 04, 2023 6:40 pm
I bought my two U6-Lite for around 110 euros each about 8 months ago, now they are about 130 - 140 euros. cAP ax is about 140 - 150 euros depending on distributor (all prices include VAT)
massinia
Tue Jul 04, 2023 6:49 pm
@Guntis I don't know if it's already been reported, if needed I'll make a ticket
ROS 7.11alpha179
The devices you see at 0 are connected and making traffic.
The speed of the connection resumes if I turn off the wireless of the devices (smartphones and tablets) and on again.
So far no password errors and very stable wireless connection.
holvoetn
Tue Jul 04, 2023 6:51 pm
I got my cap AX from nasstore.eu (Latvian company so close to the source :lol: )
99 EUR ex, 119.79 EUR TVA incl.
gigabyte091
Tue Jul 04, 2023 6:59 pm
Yea, my distributor sells them at 114 euros plus 25% VAT...
bristic
Tue Jul 04, 2023 7:02 pm
ROS 7.11alpha179
Same here :(
ToTheFull
Tue Jul 04, 2023 7:35 pm
yes me too!
gigabyte091
Tue Jul 04, 2023 7:51 pm
Same here !
Also, I started to receive radar detection messages on one of the CAP's but not on the other one... And frequencies are all over the place...
ToTheFull
Tue Jul 04, 2023 8:02 pm
I've not had any issue so far on my cAp-ax fingers crossed.
Also intresting to note that devices in CAPSMANN AP and Router configuration are showing the same missing TX/RX Byte problem.
holvoetn
Tue Jul 04, 2023 8:08 pm
Impossible if you set the frequencies manually.
Don't use auto !
gigabyte091
Tue Jul 04, 2023 8:16 pm
They are set manually... 5220 for the upstars, 5500 for downstairs and when i check i get this:
holvoetn
Tue Jul 04, 2023 8:19 pm
5500 = DFS channel so subject to radar detection.
Your router is doing what it is supposed to do. It detects radar so it changes frequency.
Avoid that frequency if you're in an area subject to DFS.
gigabyte091
Tue Jul 04, 2023 8:23 pm
Strange thing is that i never had this problem before upgrade, i don't live near airport or any other facility that should have radar installed...
I will search what are non DFS frequencies in my country and set AP to that frequency... But like I said never had this problem before...
holvoetn
Tue Jul 04, 2023 8:28 pm
Weather radar also uses that range, not only airports or military installations.
Can go from 150km up to 300km.
ToTheFull
Tue Jul 04, 2023 8:31 pm
Welcome to the club!
Try this https://en.wikipedia.org/wiki/List_of_WLAN_channels
gigabyte091
Tue Jul 04, 2023 8:54 pm
Thank you :lol: :lol: :lol:
One AP is at 5220 MHz now, and the other one on 5745 MHz but I'm thinking about setting channel width to 40MHz and use 5180 and 5220 MHz...
bristic
Tue Jul 04, 2023 9:57 pm
While you are there, :) put 2G on range 2412-2462 so your printers and other IoTs do not fall into channels 13, 14 and/or 15.... like in my case :oops:
gigabyte091
Tue Jul 04, 2023 10:00 pm
IoT devices are on another AP for now, this is testing setup for now, and on mikrotik i have channels 1 and 6, and ubiquiti is on channel 11, 20 MHz channel width.
sudanking
Thu Jul 06, 2023 11:02 am
ROS 7.11alpha179
Wireless so stable, no need to restart for last 48 hours.
holvoetn
Thu Jul 06, 2023 11:03 am
A new beta is out, should include this alpha as well.
gigabyte091
Thu Jul 06, 2023 11:50 am
I didn't see much changes in change log, only a few changes.
I will return TX power on cAP ax because my phone hangs to AP like crazy... Signal became really low but it hangs onto it...
Also it doesn't like higher channels on 5 GHz radio, i'm thinking about 40 MHz channel and using 5180 and 5220 MHz
ToTheFull
Thu Jul 06, 2023 11:51 am
For anybody qurious about the TX-RX problem being fixed in 7.11.beta4 it isn't....
uptime: 13m32s
version: 7.11beta4 (development)
build-time: Jul/05/2023 10:33:54
free-memory: 619.9MiB
total-memory: 928.0MiB
cpu: ARM64
cpu-count: 4
cpu-frequency: 864MHz
cpu-load: 0%
total-hdd-space: 128.5MiB
write-sect-since-reboot: 76
write-sect-total: 440236
bad-blocks: 0%
architecture-name: arm64
board-name: hAP ax^2
platform: MikroTik
holvoetn
Thu Jul 06, 2023 11:53 am
Access list can help to kick out devices which keep hanging on, even when signal level is too low to be good.
/interface wifiwave2 access-list
add action=accept allow-signal-out-of-range=30s disabled=no interface=any signal-range=-67..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=1s disabled=no interface=any signal-range=-120..-68 ssid-regexp=""
holvoetn
Thu Jul 06, 2023 11:54 am
They didn't say yet it was fixed :D
gigabyte091
Thu Jul 06, 2023 12:31 pm
That's the only option for now... I was thinking about it, will try it
ToTheFull
Thu Jul 06, 2023 12:34 pm
I'll take another Power nap then, nothing to see here, move along!
Guntis
Thu Jul 06, 2023 1:47 pm
Statistics reporting will be resolved in next beta release, clients should still work as expected.
robmaltsystems
Long time Member
Long time Member
Thu Jul 06, 2023 2:07 pm
Is it worth the trouble for just 2 AP ?
Certainly not. :D
Unless you want to learn about CAPsMAN.
gigabyte091
Thu Jul 06, 2023 2:37 pm
Why not, I love to learn :D :D
I set up Access list but I added MAC address of my phone, because other devices behave normally.
ToTheFull
Thu Jul 06, 2023 3:50 pm
@Guntis thanks for taking the time.
best regards
universe5ht
Thu Jul 06, 2023 4:23 pm
I have a strange problem.
RB3011 (capsman controller) + cAP ax.
The xiaomi projector does not connect to Wi-Fi. There is an error in the logs: 10:2C:6B:35:F4:A4@AP1-cAP ax-dmt-5GHz disconnected, SA Query timeout, signal strength -47 and disconnected, connection lost, signal strength -51 .
I have tried firmware 7.09,7.10,7,11 beta - does not work
I have tried all the settings that I can, and there is no result.
If you disconnect the point from the capsman and distribute Wi-Fi locally with the same ones, then the projector connects without problems.
The problem is with only one device, the other 20 work without problems.
What to do?
holvoetn
Thu Jul 06, 2023 7:10 pm
Search for the difference in security settings.
Really comb through every nitty gritty detail.
gigabyte091
Fri Jul 07, 2023 8:38 am
Access lists are working like a charm :D
bristic
Fri Jul 07, 2023 5:01 pm
What to do?
I have the same setup like you, however no xiaomi projector unfortunately...
There seems to be the problem with that, see these posts:
https://xiaomi.eu/community/threads/mij ... lem.62538/
https://piunikaweb.com/2021/11/23/xiaom ... onnection/
I am not in favour of disabling 5GHz but try if you can disable 5GHz on projector if that is possible at all...
Rox169
Fri Jul 07, 2023 6:00 pm
Try 7.11 beta4
karhill
Sat Jul 08, 2023 6:31 am
hAP ax2:
My problem is that the 5Ghz radio will just stop running. Sometimes it will run for several days, other times it will run for several minutes. It seems very fragile. It doesn't take much for the 5Ghz radio to drop dead. Just changing the country from Canada to US can cause it drop dead.
I had the issue of the 5GHz going offline with versions 7.9, 7.9.1, 7.10, 7.10.1, and now I'm trying 7.11beta4
The 5GHz radio has not disappeared yet, but I'm not able to connect to the 5GHz radio. I'm not sure why I can't connect to the 5GHz radio..I'll experiment a little more.
I really enjoy the hAP ax2 as a little router, but the WIFI capabilities have been very problematic so far.
gigabyte091
Sat Jul 08, 2023 6:51 am
What settings are you using for 5GHz radio ?
redjahred
Sat Jul 08, 2023 1:20 pm
Check the frequency. Maybe router took 169 channel or above and your client just do not see it.
hAP ax2:
karhill
Sat Jul 08, 2023 10:32 pm
hAP ax2:
I think I mislead people with my comment that changing the radio's country settings would cause it to drop dead. That naturally lead people to think it might be a frequency problem. I don't believe it's a frequency problem. By mentioning the country change to the radio settings I was just trying to illustrate how easy it was to make the 5GHz radio go dead. Other changes that are equally simple and have nothing to do with frequencies can cause the 5GHz radio to disappear. For example, adding 2 or 3 SSIDs and connecting them to VLANs can make the 5GHz radio disappear.
Meanwhile, I've been 24 hours on 7.11beta4, and the 5GHz radio has not disappeared. The reason that I could not connect to the 5GHz radio after upgrading to 7.11beta4 was that somehow in the upgrade process the 5GHZ radio interface (wifi1) was dropped as one of the interfaces on the bridge. As soon as I added the wifi1 interface back to the bridge, the interface is working fine.
I am going to attempt some of the actions that would cause the radio to go dead on earlier versions (e.g. adding some SSIDs and connecting them to VLANs). I'll report back how stable the radio is. But so far, it's looking better.
holvoetn
Sat Jul 08, 2023 10:49 pm
I have 3 ssids on 3 different vlans, both 2.4 and 5ghz.
Apart from 7.9 which was a true challenge, had little problems.
gigabyte091
Sun Jul 09, 2023 8:13 am
Ahhh, you guys without capsman... :lol:
gigabyte091
Sun Jul 09, 2023 12:05 pm
So I tried to play with VLANs on CAPsMAN, my current setup is RB4011 as router and CAPsMAN controller and ax2 as CAP.
ether10 on RB4011 is hybrid port VLAN1 untagged I left that for mgmt. purposes, VLAN10 and 20 tagged going to ax2 ether1 and it works just fine, 5GHz interface is VLAN10, 2.4 GHz is VLAN20.
S8T8
Sun Jul 09, 2023 2:02 pm
Hi @gigabyte091, could you please share your /interface wifiwave2 export on both devices?
I was testing CAPsMAN for a similar set-up you have without success, WiFi settings were non applied to CAP.
Thanks!
gigabyte091
Sun Jul 09, 2023 2:11 pm
Sure thing,
Here is RB4011 (CAPsMAN controller):
# 2023-07-09 13:08:02 by RouterOS 7.11beta2
# software id =
# model = RB4011iGS+
# serial number =
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add interface=bridge name=vlan20 vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 datapath
add bridge=bridge disabled=no interface-list=LAN name=datapath_vlan10 \
    vlan-id=10
add bridge=bridge disabled=no interface-list=LAN name=datapath_vlan20 \
    vlan-id=20
/interface wifiwave2 configuration
add channel.band=5ghz-ax .frequency=5500 .width=20/40/80mhz country=Croatia \
    datapath=datapath_vlan10 disabled=no mode=ap name=cfg1-5ghz \
    security.authentication-types=wpa2-psk,wpa3-psk ssid=Mikrotik2
add channel.band=2ghz-ax .frequency=2437 .width=20/40mhz country=Croatia \
    datapath=datapath_vlan20 disabled=no mode=ap name=cfg2-2.4ghz \
    security.authentication-types=wpa2-psk,wpa3-psk ssid=Mikrotik3
add channel.frequency=5500 configuration=cfg1-5ghz configuration.mode=ap \
    disabled=no name=cap-wifi1
add channel.frequency=2437 configuration=cfg2-2.4ghz configuration.mode=ap \
    disabled=no name=cap-wifi2
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=dhcp_pool1 interface=vlan10 lease-time=1d name=dhcp1
add address-pool=dhcp_pool2 interface=vlan20 lease-time=1d name=dhcp2
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
    admit-only-untagged-and-priority-tagged interface=ether3 pvid=20
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=bridge,ether10 untagged=ether2 vlan-ids=10
add bridge=bridge tagged=bridge,ether10 untagged=ether3 vlan-ids=20
add interface=vlan10 list=LAN
add interface=vlan20 list=LAN
/interface wifiwave2 capsman
set ca-certificate=auto enabled=yes package-path="" require-peer-certificate=\
    no upgrade-policy=none
/interface wifiwave2 provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg1-5ghz \
    supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=\
    cfg2-2.4ghz supported-bands=2ghz-ax
    192.168.88.0
add address=192.168.10.1/24 comment=vlan10 interface=vlan10 network=\
    192.168.10.0
add address=192.168.20.1/24 comment=vlan20 interface=vlan20 network=\
    192.168.20.0
/ip dhcp-client
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Zagreb
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
And here is ax2 (CAP):
# 2023-07-09 13:10:42 by RouterOS 7.11beta2
# software id =
# model = C52iG-5HaxD2HaxD
# serial number =
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridgeLocal
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
# managed by CAPsMAN
# mode: AP, SSID: Mikrotik2, channel: 5500/ax/Ceee
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp \
    disabled=no
# mode: AP, SSID: Mikrotik3, channel: 2437/ax/Ce
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp \
    disabled=no
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/system clock
/system note
holvoetn
Sun Jul 09, 2023 2:54 pm
You are using ax2 as simple cap, nothing more ?
gigabyte091
Sun Jul 09, 2023 3:07 pm
Yes, simple cap, nothing was done on ax2, everything is set up on rb4011, and ofc i installed wifiwave2 package on rb4011
karhill
Sun Jul 09, 2023 7:54 pm
hAP ax2: With a few days of testing, Version 7.11beta4 has provided a much more robust 5GHz radio. The 5GHz radio has not dropped once in scenarios where it would surely have dropped with previous versions. I'm fairly optimistic at this point.
Question: is the standard procedure to upgrade the routerboard firmware to the same version as the RouterOS?
gigabyte091
Sun Jul 09, 2023 8:09 pm
It's recommended, I always upgrade ROS and then routerboard firmware.
gigabyte091
Mon Jul 10, 2023 1:36 pm
@holvoetn, did you try to replicate settings for VLAN's yet ?
holvoetn
Mon Jul 10, 2023 9:54 pm
AX device as simple AP, that one works.
My problem is with the hybrid situation: AX device acting as AP under capsman ánd VLAN switch on some or all of the ether ports.
gigabyte091
Mon Jul 10, 2023 10:19 pm
I didn't try that, ax2 is a simple AP controlled by capsman, and that part works. I didn't try to play with other ports on it but i will try tomorrow
gigabyte091
Mon Jul 10, 2023 10:35 pm
I tested it right now and yes, i'm unable to get VLAN's working, if I enable vlan filtering on ax2 bridge shit go haywire, client is unable to get IP address...
Users browsing this forum: Bing [Bot] and 52 guests
