TUNG0407
Netwatch Error
Mon May 15, 2023 6:47 am
Dear ALL,
I'm looking to use Netwatch to monitor some IPs to trigger the routing, but i found a strange issue, the ping and netwatch result is mismatch, i used the ping tool is able to ping 8.242.4.210, but I use netwatch is showing the "down" status and the RTT Avg,Min,Max, Jitter and Stdev is still changing the value, anyone can help?
TungHo
eworm
Re: Netwatch Error  [SOLVED]
Mon May 15, 2023 9:50 am
I guess the tests fail because replies take too long to travel back. If this is fine in your case increase the values for thr-rtt-*...
https://help.mikrotik.com/docs/display/ ... obeoptions
Users browsing this forum: dsfak, FurfangosFrigyes, Qanon, Ramirocuei, tnperron, UkRainUa and 171 guests
