waynger
Mikrotik DHCP issues
Mon May 15, 2023 7:28 am
I have a network with 30 devices I am using a mikrotik router that is configured as a DHCP server for all attached devices.
Lease time is 5 days
I have 3 smart outlets that refuse to connect unless the Mikrotik is rebooted daily they connect fine after a reboot.
I also have a smart TV that with the mikrotik says there is no internet on the wired connection, however it connects and works fine using a wireless connection on the mikrotik
If I unhook the Mikrotik, and hook up a netgear router everything works and connects with no issue and remains fully functional for months at least, probably for years.
Hooking up the Mikrotik the 3 outlets and the TV fail to connect.
I really want to like and use the Mikrotik because I can use some of it's other features but this failure to connect issue makes it a non starter.
I have upgraded the firmware no change, I am attaching a log file so you can see what it starts doing after a few hours or a day or so.
rextended
Re: Mikrotik DHCP issues
Tue May 16, 2023 3:30 pm
If you set the lease time to 1 second, that's normal...
waynger
Wed May 17, 2023 10:46 pm
holvoetn
Wed May 17, 2023 10:56 pm
From your screenshot it looks more like 5 SECONDS.
Show the config !
BTW ...is that a recent screenshot ? Your time settings on that router are possibly completely wrong (I don't even need to know in which time zone you are, Jan 31st is already LOONG gone).
Not the first time I see DHCP issues due to completely wrong time settings on a router.
Check that one too please.
waynger
Thu May 18, 2023 1:10 am
That is an old screenshot from earlier this year, sorry. I have attached the latest and pretty much original config. As you can see ether 5 is a different server(quantar) no problems there all the problems are on ether 2,3,4 which are bridged. Thanks for having a look UPDATE: looks like lease time is 2hours? No Idea about that home network and suggestions?
# may/17/2023 15:06:36 by RouterOS 7.8
# software id = ZS56-J9I0
# model = RB750Gr3
# serial number = xxxxxx
add admin-mac=C4:AD:34:93:E6:7B auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MANAGEMENT
/interface lte apn
add name=dhcp ranges=192.168.1.5-192.168.1.254
add name=dhcp_pool_quantar ranges=192.168.89.10-192.168.89.110
add address-pool=dhcp interface=bridge lease-time=2h name=Primary
add address-pool=dhcp_pool_quantar interface=ether5 lease-time=5d name=\
"Guest_Ether5 DHCP"
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
/ipv6 settings
add comment=quantar interface=ether5 list=LAN
add comment=routeraccess interface=bridge list=MANAGEMENT
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.89.1/24 comment=quantar interface=ether5 network=\
192.168.89.0
add address=192.168.1.1/24 comment=Default interface=bridge network=\
192.168.1.0
add address=216.173.136.43/26 interface=ether1 network=xxx
/ip arp
add address=192.168.1.29 interface=bridge mac-address=B4:E6:2D:0D:81:DD
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server alert
add disabled=no interface=bridge
/ip dhcp-server lease
add address=192.168.1.5 client-id=1:98:da:c4:83:78:bb mac-address=\
98:DA:C4:83:78:BB server=Primary
add address=192.168.1.20 client-id=1:0:1c:2a:1:73:2a mac-address=\
00:1C:2A:01:73:2A server=Primary
add address=192.168.1.27 client-id=1:98:da:c4:e7:6d:42 mac-address=\
98:DA:C4:E7:6D:42 server=Primary
add address=192.168.1.15 mac-address=B4:E6:2D:07:35:74 server=Primary
add address=192.168.1.46 client-id=1:f8:b1:56:ab:d3:6a mac-address=\
F8:B1:56:AB:D3:6A server=Primary
add address=192.168.1.26 client-id=1:34:17:eb:a5:8:9 mac-address=\
34:17:EB:A5:08:09 server=Primary
add address=192.168.1.52 client-id=1:4:a1:51:88:2a:3e mac-address=\
04:A1:51:88:2A:3E server=Primary
add address=192.168.1.37 client-id=1:2c:aa:8e:6a:87:c3 mac-address=\
2C:AA:8E:6A:87:C3 server=Primary
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24
add address=192.168.89.0/24 comment=quantar dns-server=192.168.89.1 gateway=\
192.168.89.1 netmask=24
set allow-remote-requests=yes servers=xxx
established,related,untracked
invalid
add action=accept chain=input in-interface-list=MANAGEMENT
add action=accept chain=input comment="Allow LAN DNS queries - TCP" \
connection-state=new dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="Allow LAN DNS queries-UDP" \
connection-state=new dst-port=53 in-interface-list=LAN protocol=udp
add action=drop chain=input comment=" drop all else"
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=forward comment="Allow Internet " in-interface-list=\
LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat connection-state=new disabled=yes \
in-interface-list=WAN
add action=drop chain=forward comment=" drop All else "
add disabled=no dst-address=0.0.0.0/0 gateway=xxx
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=NetgearMik
/system scheduler
add interval=2d name=reboot-10am on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=feb/27/2023 start-time=10:00:00
/system upgrade upgrade-package-source
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=MANAGEMENT
holvoetn
Thu May 18, 2023 11:58 am
1- best to post config between code quotes, much easier for reading posts.
2- best to remove your serial number and pubic IP (I can ping your gateway !!) from config export. For some, depending on how their setup is made, it can reveal the door via Mikrotik IP Cloud service. And if the firewall is not setup correctly, you could be in trouble. Not indicating this is the case here but general remark.
3- I'm not seeing anything obvious which could cause this except (and now comes a long shot) ...
I see some config bits related to OSPF. I assume you don't use it.
But it makes me remind about an issue from quite a while ago where bits and pieces from ROS6 config could have an impact on ROS7 (even when not used).
I have seen it too (also on Hex) with wireguard all of a sudden not working 100% anymore. (and the OSPF config was what I was seeing too at that time).
And here comes the long shot:
Have you ever netinstalled that device since moving to ROS7 ?
Or did you only do upgrade, upgrade, upgrade, ... ?
If you didn't, it might be worthwhile to do so. It's a bit of work but it will make sure your device is pristine-ROS7 without anything left from ROS6.
Export config, show-sensitive.
Put the file on your computer and inspect the export is complete.
Netinstall device
Import config again block by block (I'm not sure the order has been completely fixed already for simple import) making sure to omit bits and pieces which are already present unless you are 100% sure you know why you want to change that default setting.
waynger
Thu May 18, 2023 7:14 pm
As you can tell, I am pretty green at this, thank you for the help!
I removed sensitive data from previous post.
It has always been upgrade, upgrade..
I read about net install and will go that route but I am going to wait a day or two to verify that nothing has changed with what I am running.
"I see some config bits related to OSPF"
No Idea what that is other than just reading about it, since this is a small system I assume I don't need it.
Can you point me to what you were talking about and what to remove?
Thanks again
holvoetn
Thu May 18, 2023 7:50 pm
Ospf
From what I can see it is disabled but the fact it is visibly there, is for me an indication something is left from before.
And then it's better to clean the house.
waynger
Tue May 23, 2023 8:53 am
I downloaded netinstall and hooked things up however I didn't know which package to download, I am running windows 10, the only file I can get to show up in the netinstall window is for routeros-mmips and when I run it I get a "Key file too big " when I click install
Any input appreciated
holvoetn
Tue May 23, 2023 8:55 am
Hex is mmips architecture.
tangent
Tue May 23, 2023 9:02 am
It’s common configuration flotsam.
holvoetn
Tue May 23, 2023 9:07 am
Manually removing isn't always the solution (been there, done that).
But it may be an easier first step, that's true.
waynger
Tue May 23, 2023 9:10 am
Wow, thank you for the quick response, I edited my post above and am getting a key file too big error
Update, rebooted everything and it is now installing, I went back to 6.48.6 as I think that may be what was on this thing from the factory. I tried doing a reset to factory but it kept saying 7.x.x
Users browsing this forum: Ahrefs [Bot], SMARTNETTT and 27 guests
