corsairetc
Caps manager
Tue May 16, 2023 2:47 pm
Hello I have working Caps manager and managing three Cap clients. Recently I was bought "MikroTik cAP ax" and I want to add it as fourth Cap client. I was mention under Wireless>WiFi Wave2>CAP is different configuration as other devices. I running "Caps manager" on "RB952Ui-5ac2nD" Caps manager not see new radio. Can I ask how can I add this new device to current Caps manager ?
I have on all devices installed latest "RouterOS 7.9".
Thank you for any advice.
holvoetn
Re: Caps manager
Wed May 17, 2023 1:51 pm
Legacy capsman (controlling non-wifiwave2 radios) and Wifiwave2-Capsman (AX radios or any other device running wifi via Wave2) can not be mixed.
You will need two controllers.
foraster
Re: Caps manager
Mon Jan 22, 2024 9:43 pm
With latest RouterOS versions (7.13 and later) is it possible to have on the same router both a legacy-capsman and a wifi-capsman?
holvoetn
Re: Caps manager
Mon Jan 22, 2024 11:22 pm
Yes it is.
I am running it on hex at home for testing.
foraster
Re: Caps manager
Mon Jan 22, 2024 11:29 pm
Cool, I've been trying to enable the new Capsman but when doing so, the lecacy-capsman CAPs get disconnected... :?
holvoetn
Re: Caps manager
Tue Jan 23, 2024 8:11 am
You may have to delete all certificates and recreate them.
I think I saw something mentioned about that by MT staff.
My setup was new on that device starting with 7.13 so there were no previous certificates lingering around.
foraster
Re: Caps manager
Tue Jan 23, 2024 8:23 am
Thanks, regenerating the certificates did the trick.
Users browsing this forum: No registered users and 80 guests
