egal667
cAP XL inaccessible via IP, only with MAC via Winbox
Tue May 16, 2023 3:27 pm
I have a cAP XL configured as a bridge, connected to a router via another switch. The router is the DHCP server, and the cAP has a static IP configured, in the same subnet.
I cannot connect to the cAP's webfig interface with a browser, nor with Winbox via it's IP. It only works from Winbox with the MAC address.
It responds to pings though. And when I ping it, ARP is resolving the right MAC, so I'm guessing it's not an address conflict.
What am I missing here?
This is the output of /export hide-sensitive compact:
[admin@MikroTik cAP XL ac] > /export hide-sensitive compact
# jan/16/1970 20:09:44 by RouterOS 6.49.7
# software id = BBL3-MUR9
# model = RBcAPGi-5acD2nD
# serial number = HDK08******
add admin-mac=48:A9:8A:25:56:85 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys name=auth supplicant-identity="" \
    unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=israel disabled=no distance=indoors \
    frequency=2442 installation=indoor mode=ap-bridge security-profile=auth ssid="Net 2.4" wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=israel disabled=no distance=indoors \
    installation=indoor mode=ap-bridge security-profile=auth ssid="Net 5" wireless-protocol=802.11
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/queue interface
set wlan1 queue=only-hardware-queue
set wlan2 queue=only-hardware-queue
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
add comment=defconf interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
add disabled=yes
add address=192.168.88.2/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf interface=bridge
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system identity
set name="MikroTik cAP XL ac"
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
anav
Re: cAP XL inaccessible via IP, only with MAC via Winbox
Tue May 16, 2023 3:51 pm
In winbox ensure you include the port# lets say 51555
connect to:IP-ADDRESS:51555
Why is your capax setup as a router???
holvoetn
Tue May 16, 2023 4:07 pm
egal667
Tue May 16, 2023 5:03 pm
Excuse my ignorance but how can you tell it's setup as a router? And how do I set it to bridge mode?
Adding the port didn't change anything, same error.
anav
Tue May 16, 2023 5:18 pm
Just to be clear, you only have one flat network?? No vlans, no wifi for homeusers, guests, IOT devices, etc..... ???
egal667
Tue May 16, 2023 5:25 pm
There's a vlan and guest wifi defined on the router that's at 192.168.88.1. I'm connecting to the cAP via wifi directly though.
anav
Wed May 17, 2023 1:53 am
Again riddles, nothing clear, I asked if you had one flat network throughout and you answered a vlan and guest network........ is that two different things or the same thing?
Where is the other subnet then the non guest subnet??
What is the capacxl attached to, what device, if MT where is its config........... where is internet coming from............
holvoetn
Wed May 17, 2023 12:01 pm
test
anav
Wed May 17, 2023 5:37 pm
You failed the test, try again.
egal667
Sat May 20, 2023 9:13 pm
I think I see where you're going with this, so I powered the cAP with a PoE injector and no data, to eliminate possible network interference. The whole topography is:
Laptop <--- wifi ---> cAP
No vlans, no guest networks. What I posted in the original post is the configuration.
Since it has no DHCP server I configured the laptop with a static IP (192.168.88.61, subnet 255.255.255.0). And it still behaves the same, I can connect with winbox via MAC but not via IP.
Users browsing this forum: mansuramir and 89 guests
