N2E
Connect SSH and winbox with Loopback IP
Tue May 16, 2023 3:46 pm
I try to connect from a server (in my backbone) on my CPE Hex via its loopback IP with SSH and Winbox, but I have a timeout error.
Is it possible to configure a Mikrotik CPE with its loopback IP ?
I have no problem reaching it via ICMP and SNMP.
CPE configuration :
add name=Loopback protocol-mode=none
add comment=defconf name=WAN
add comment=defconf name=LAN
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 name=xxxxxxx
add interface=Loopback list=WAN
add address=192.168.31.1/30 comment=defconf interface=bridge network=192.168.31.0
add address=185.x.x.x/30 interface=ether1 network=x.x.x.x
add address=10.252.0.215 interface=Loopback network=10.252.0.215
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add distance=1 gateway=185.x.x.y
/ip service
set telnet disabled=yes
set ssh address=0.0.0.0/0
set winbox address=0.0.0.0/0
/snmp
set enabled=yes location="xxx" trap-generators=interfaces trap-target=0.0.0.0 trap-version=2
/system identity
set name=CPE-xxxx--xxx-AI-01
Looking forward ti reading you.
Regards,
N2E
anav
Re: Connect SSH and winbox with Loopback IP  [SOLVED]
Tue May 16, 2023 5:14 pm
Not sure, but try this (ADD):
add action=masquerade chain=srcnat dst-address=192.168.31.0/24 src-address=192.168.31.0/24
If still no joy then additionally REPLACE,
TO:
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
anav
Tue May 16, 2023 5:16 pm
To reach winbox and ssh by IP address dont forget to add Ip-address:Port#[/b]
N2E
Wed May 17, 2023 12:37 pm
Hello Anav,
it's working for me, thanks :)
Users browsing this forum: Bing [Bot], Frostbite1991, lubara and 157 guests
