fbitterlich
Can't get dst-nat to work
Tue May 16, 2023 7:02 pm
I'm pretty much a beginner... so forgive me if it's a stupid mistake. I need two dst-nat rules for web traffic, but I can only get one to work. The other one simply does not connect to the target server.
I've got the following addresses (public IPs have been changed for privacy):
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=62.100.31.125/27 interface=ether1 network=62.100.31.96
add address=62.100.31.123/27 interface=ether1 network=62.100.31.96
add address=192.168.1.220/24 interface=ether3 network=192.168.1.0
I want to forward web connections (ports 80 and 443) on address 62.100.31.125 to 192.168.88.190, and 62.100.31.123 to 192.168.1.202.
My NAT rules:
add action=dst-nat chain=dstnat dst-address=62.100.31.125 dst-port=80 protocol=tcp to-addresses=192.168.88.190 to-ports=80
add action=dst-nat chain=dstnat dst-address=62.100.31.125 dst-port=443 protocol=tcp to-addresses=192.168.88.190 to-ports=443
add action=dst-nat chain=dstnat dst-address=62.100.31.123 dst-port=80 protocol=tcp to-addresses=192.168.1.202 to-ports=80
add action=dst-nat chain=dstnat dst-address=62.100.31.123 dst-port=443 protocol=tcp to-addresses=192.1.0.202 to-ports=443
The only difference that I can see is that the NAT target for the .123 address is on ether3, and the one for .125 is on ether2. Yet the one to .123 does not work. The target address (192.1.0.202) can be pinged from the MikroTik, and accessing that IP directly from another host in the same physical network as the ether3 interface with a browser works.
I have set up the NAT that works several months ago, so maybe there is something else that's needed for this to work which I have forgotten...?
Form completeness, here are the filter rules; I believe they are the default.
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
I would be grateful for any idea on how to solve this.
own3r1138
Long time Member
Long time Member
Re: Can't get dst-nat to work
Tue May 16, 2023 7:23 pm
Did you check if the ports are bonded with www and www-ssl services?
fbitterlich
Tue May 16, 2023 7:28 pm
You mean in the IP > Services section? I though that this would control the ports under which the admin interface (WebFig) of the MikroTik itself can be accessed?
Anyway, the port 80 is bound to www, and the binding of 443 to www-ssl is there but disabled.
Or do you mean this could conflict with the NAT rules? If so, why only with one of them and not the other?
k6ccc
Tue May 16, 2023 7:29 pm
Are you doing anything to ensure that responding traffic is being returned with the correct source IP. If you are not doing anything, all your outbound traffic will be coming from the same public IP. That means that if a computer out on the Internet sends traffic to the other address, responses will be coming from a different address and the far end computer will reject the packet.
Please export your complete configuration rather than a few small extracts. Feel free to conceal personal information.
fbitterlich
Tue May 16, 2023 7:44 pm
No, it was my impression that if a client is opening a TCP connection to the public IP xxx.xxx.xxx.125 and the MikroTik per its NAT rules forwards the traffic to 192.xxx.xxx.202, then the NAT will also change the source IP of the response packets to that of the target IP of the original connection... I know that this will be more difficult with UDP, but since we're talking about pure HTTP(S) here, I assumed the address translation works "automagically"...?
Ok, here's the full config (redacted):
add admin-mac=zz:zz:31:E4:zz:zz auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-ZZZZZZ \
    station-roaming=enabled wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=xxx
add name=dhcp ranges=192.168.88.10-192.168.88.127
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge comment=defconf interface=pwr-line1
/ip dhcp-client
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add distance=1 gateway=62.100.31.97
/system clock
/tool mac-server
/tool mac-server mac-winbox
(End of config)
Buckeye
Forum Veteran
Forum Veteran
Tue May 16, 2023 11:24 pm
So you just use someone else's public IP? Why not use the IP addresses reserved for documentation and examples? See rfc5737.
TEST-NET-1 192.0.2.0/24
TEST-NET-2 198.51.100.0/24
TEST-NET-3 203.0.113.0/24
fbitterlich
Wed May 17, 2023 12:20 pm
No. I'm not "using" someone else's IP addresses. This is not a tech documentation, and I don't want to concentrate on finding the right replacement IP addresses, subnet masks and other stuff, just to make my redacted config look neat. I'm trying to solve a NAT problem.
broderick
Wed May 17, 2023 12:32 pm
I see something wrong here:
IP 192.1.0.202??
Besides, maybe you should also create two different srcnat rules, one for each subnet, to make sure that the server would respond via the same public IP from which it gets requests.
Not sure though. I've never tried it.
fbitterlich
Wed May 17, 2023 1:02 pm
IP 192.1.0.202??
Wow, thanks for noticing that. I fixed that, still no luck.
What would these rules look like?
broderick
Wed May 17, 2023 1:28 pm
Maybe something like this:
 add action=src-nat chain=srcnat out-interface=ether1 src-address=192.168.88.0/24 to-addresses=62.100.31.125
 add action=src-nat chain=srcnat out-interface=ether1 src-address=192.168.1.0/24 to-addresses=62.100.31.123
careful though, I may have overlooked something, or miss a step to make it work properly or as expected.
Just give it a try and let us know.
fbitterlich
Fri May 19, 2023 4:18 pm
I see. This would change the source ip of every packet that has an original source IP in the 192.168.1.x network to be "62.100.31.123" if the packet goes out through the ether1 interface.
I tried it, and it didn't work. The counter for this rule stays at 0, so apparently no packet matching the rule is ever received by the firewall.
It was my understanding that this should have been done already by the existing "masquerade" rule, (see https://wiki.mikrotik.com/wiki/Manual:I ... Masquerade).
Th curious thing is that it works with the other host/IP address, and I can't find any difference that looks relevant to me.
broderick
Fri May 19, 2023 10:02 pm
As I said, I may have overlooked something.
Buckeye
Forum Veteran
Forum Veteran
Sat May 20, 2023 12:19 am
Having multiple ip addresses on your ether1 interface complicates things.
Do a google search for mikrotik nat masquerade when exit interface has mulitple addresses there are many threads, I didn't read them because I don't have multiple addresses on my router's WAN.
karlisi
Sat May 20, 2023 11:34 am
Be sure masquerade is the last in srcnat chain, if you want to keep it.
wiseroute
Sat May 20, 2023 7:03 pm
hello karlisi,
all you need to do is add src nat for each specific incoming dst nat. the reply address should be the same as requested.
example:
dst nat on 31.125 to 88.190,
you should add a src nat from 88.190 (or .88 subnet for simplicity) to outside ip of 31.125
and so forth.
(can be basic subnet masquerade as well, if you want).
aa.. and do check your src nat or masquerade sequence. put those special src nat on top of other masquerade rules.
hope this helps.
mkx
Sat May 20, 2023 7:10 pm
There's no need to put src-nat rule matching a dst-nat rule ... connection tracking machinery will recognise return packets and un-do the dst-nat on them.
wiseroute
Sat May 20, 2023 7:22 pm
@ mkx
well, from your conntrack and "basic* masquerade pov, then I could tell there will be a lot of misaligned request and reply sessions - if you have more than one outside ip on single interface - and doing basic masquerade.
mkx
Sat May 20, 2023 10:02 pm
As I wrote: conntrack machinery will un-do the dst-nat action ... exactly. It doesn't matter how many addresses might be bound to any interface.
It is different with src-nat which has to decide which address (and port) will be used as src-address (and src-port). However, src nat and dst nat are pretty much unrelated and independent. src nat (or masquerade as special case) doesn't even have to be configured/active for dst nat to do its job ...
Users browsing this forum: patrikg and 124 guests
