giguard
cAP ax in CAPs mode, empty configuration
Wed May 17, 2023 6:50 am
Just got brand new cAP ax and switched to CAPs mode only to find out its not joining to CAPsMAN.
I hook up my laptop to ether2 and noticed unit is without any configuration.
Perhaps this is why its not auto joining to CAPsMAN?
I've got number of hAP lite joined to CAPsMAN automatically so I'm pretty sure my current CAPsMAN setup is okay.
This brand new cAP ax is with v7.8. And CAPsMAN is running on v6.49.3. May be this is problem?
Anyway, I'm really puzzled why cAP ax will not join. Version issue? or the fact that no configuration for cAP ax in CAPs mode is the culprit?
EDIT: While cAP ax is in CAPs mode, I logged in using Winbox. I opened up wireless then pressed CAP button.
Enable checkbox is not checked. I think this is BUG.
EDIT2:I've now enabled CAP. I'm seeing "no suitable CAPsMAN" on the log.
Unit hasn't received IP as it is not configured with DHCP client. Does it need one to find CAPsMAN?
I haven't seen min. configuration for a unit when it is in CAPs mode.
liviu2004
Re: cAP ax in CAPs mode, empty configuration
Wed May 17, 2023 7:19 am
Thought you could not combine old capsman with new cap ax wave2 drivers things like that. It has been written before, give a search.
giguard
Wed May 17, 2023 7:34 am
Thought you could not combine old capsman with new csp ax wave2 drivers things like that. It has been written before, give a search.
You are right. I think I've came across that while back. Forgot.
Version conflict aside, cAP ax running in CAPs mode without CAP enabled is still an issue.
holvoetn
Re: cAP ax in CAPs mode, empty configuration  [SOLVED]
Wed May 17, 2023 8:58 am
Default caps config for AX devices was only fixed with 7.9
*) defconf - added CAPs mode script for wifiwave2 devices;
giguard
Wed May 17, 2023 9:22 am
Ahh.. That makes sense. I just upgraded cAP ax to v7.9 and it joined.
Thx.
davidemiccone
Sun Apr 07, 2024 10:48 am
I'm using CAPsMAN on CCR-1009 with RouterOS 7.14.2 and cAP ax on RouterOS 7.14.2.
Hours spent to connect cAP ax to CAPsMAN still "no connection to CAPsMAN" - all others CAPs (not ax) works. :( :( :(
Any help please!
Users browsing this forum: Bing [Bot], gkoleff and 62 guests
