jmantnt
I encountered an error while installing plex
Wed May 17, 2023 7:19 am
There is a file read and loading error while I was using the container function to install plex using RouterOS v7.9. The error message is as follows
User UID: 1000
User GID: 1000
chown: changing ownership of '/config': Operation not permitted
**** Permissions could not be set. This is probably because your volume mounts are remote or read-only. ****
**** The app may not work properly and we will not provide support for it. ****
mkdir: cannot create directory ‘/config/Library’: Permission denied
The error message shows that there is no permission to read or access files. How can I handel this problem? Thank you.
saifulmd0
Re: I encountered an error while installing plex
Sat May 20, 2023 11:19 pm
Is anyone there to help? I have a similar issue with another docker containter called hurlenko/filebrowser.
optio
Long time Member
Long time Member
Sun May 21, 2023 4:31 pm
Directory is monuted as readonly in container when doesn't contain .type file with content container, this directory is then accessible from ROS files (r/w). This may happen when starting container which have mount configuration to already existing directory or when .type file is manually deleted. You cannot have both r/w directory access in mounted container directory and from ROS files.
Users browsing this forum: No registered users and 2 guests
