Rox169
POE switch for MT
Wed May 17, 2023 7:45 am
could you please advise me if I can power with TP-Link TL-SG1210P mikrotik device: AX2,AX3, Cube 60? This switch is standard 802.3af, 802.3at but MT is using some Passive PoE.
Thank you
Rox169
Re: POE switch for MT
Wed May 17, 2023 10:31 pm
onyone know please?
Rox169
Thu May 18, 2023 10:31 pm
no one knows?
karlisi
Fri May 19, 2023 8:28 am
Passive PoE is not compatible with 802.3af/at
Rox169
Tue May 30, 2023 3:18 pm
do you know if I can power with TP-Link TL-SG1210MP POE switch HAP AX2? Could I make it work?
peterda
Tue May 30, 2023 5:11 pm
Your HAP AX2 can ONLY use Passive POE, no need to ask the same question over and over, the answer will be the same.
One of the options is to buy a Passive POE injector like the RBPOE :https://mikrotik.com/product/RBPOE
Amm0
Tue May 30, 2023 6:06 pm
The hAPax2 and hAPax3 are <30V max... while 802.11at/af is 48V...
But this box would convert the 802.11at/af power to 24V:
https://mikrotik.com/product/rbgpoe_con_hp
Rox169
Wed May 31, 2023 7:20 am
do you know any poe switch which support passive poe and poe 802.3af for reasonable price? I see only from MT but they are too expensive.
rextended
Wed May 31, 2023 10:37 am
It's not something that MikroTik doesn't produce...
Asking for advice on other competitors' hardware is not allowed on the MIKROTIK forum...
Rox169
Wed May 31, 2023 12:20 pm
so send me then PM, please.
Users browsing this forum: Amazon [Bot] and 44 guests
