s19
Massive delays and packet loss in LAN traffic on RB5009UG+S+IN
Wed May 17, 2023 8:31 am
Greetings,
I recently received my long-awaited RB5009UG+S+IN router. Before this I have used a Mikrotik hEX connected to a switch, which has worked beautifully for my home network and server use. However, I needed the hEX and switch for another project and decided to get an RB5009UG+S+IN as a one-stop shop solution.
The change has not gone without issues.
I successfully moved my custom configuration from the hEX to the RB and everything seemed to work (port forwarding to my server, hairpin NAT for my home network), but communication within my LAN network was very unstable and erratic. This was not limited to any single protocol. When pinging another device within the network, 50-75% of the requests would be responded to instantly and the rest would time out. SSH connections would be interrupted within seconds of opening them, accessing folders on network drives would either succeed instantly or time out, HTTP and HTTPS connection to the server on my network were very erratic (some resources loading instantly, some taking dozen of second to mites to load). Any successfully established remote desktop connections within the network would fail within seconds. Curiously enough, the problem was not as bad with connections to the web server from outside the network (WAN), but still very noticeable. Also, when moving files from and to the network drives, as long as the transfer got started, it would run at a very stable 1Gbps speed regardless of the file size (tested up to 10Gb).
Connections from LAN to the router itself and to internet worked flawlessly, even remote desktop connections.
I tried disabling IPV6 and hairpin NAT rules, no effect. I reset the configuration to device default using Winbox, the same problem persisted.
Now I accidentally clicked "remove configuration" thinking this would allow me to reapply my own config for further testing, but of course the device became completely inaccessible. I will probably have to perform some hard reset if I want to keep experimenting. For now I have moved back to my hEX+switch setup and everything is running smoothly.
RB was updated to latest 7.9 software. Google searches did not yield any useful results. Device CPU load was negligible during the connection lags/interruptions.
Is there something I have missed, some setup step I skipped? Considering the problem persisted even on default configuration, do you think I have a faulty unit or is there something more I can do?
My custom config:
add admin-mac=xxx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=local ranges=192.168.1.10-192.168.1.254
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
    192.168.88.0
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.200 client-id=1:3c:7c:3f:1d:eb:87 mac-address=\
    xxx server=defconf
add address=192.168.1.12 client-id=1:cc:32:e5:f:ab:57 mac-address=\
    xxx server=defconf
add address=192.168.1.11 client-id=1:98:da:c4:d:3:cf mac-address=\
    xxx server=defconf
add address=192.168.1.100 client-id=1:1c:98:ec:1e:26:fe mac-address=\
    xxx server=defconf
add address=192.168.1.101 mac-address=xxx server=defconf
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
    connection-state=invalid
add action=accept chain=forward comment="allow internet traffic" \
    in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
    connection-nat-state=dstnat
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=\
    192.168.1.0/24 src-address=192.168.1.0/24
add action=dst-nat chain=dstnat comment="Server HTTP" dst-address=\
    !192.168.1.1 dst-address-type=local dst-port=80 in-interface-list=WAN \
    protocol=tcp to-addresses=192.168.1.100 to-ports=8000
add action=dst-nat chain=dstnat comment="Server HTTPS" dst-address=\
    !192.168.1.1 dst-address-type=local dst-port=443 in-interface-list=all \
    protocol=tcp to-addresses=192.168.1.100 to-ports=4430
add action=dst-nat chain=dstnat comment="Server WireGuard" dst-address=\
    !192.168.1.1 dst-port=51820 in-interface-list=WAN protocol=udp \
    to-addresses=192.168.1.100 to-ports=51820
/ip service
set www port=8080
set www-ssl port=4430
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=xxx
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: karlisi and 122 guests
