paolobyte
OSPF fast timers bug?
Wed May 17, 2023 7:29 pm
I am using ROS7 already on some devices (CCR2004, NetPower 16P, CRS326-24S+2Q+, CRS328-24P-4S+) with layer 3 hardware offloading and I do notice that the OSPF session just keeps on flapping randomly w/out any real reason in the logs.
Scenario:
- /30 IP between 2 devices
- Running OSPF PTP
- No OSPF authentication
- Running 7.9 stable
- Timers set: 1 Hello, 2 Dead/ (some are set at 2 hello, 4 dead)
Timers were set too aggressive because this was our workaround for the lack of BFD.
I've had the same config on VYOS and Juniper devices and never had any problems with it. No random OSPF flaps.
I even ran a ping test to the neighbor device until I see OSPF session drop, and there wasn't any ping drops, yet the OSPF session restarts.
Refer to the attached image. It's either it just "timeout", or I get "sequence mismatch".
This happens very random. No pattern seen. Neighbor device is either ROS6/ROS7 with the same setting, no BFD.
Anyone experiencing the same problem? And what is your work around and how did you deal with it??
sirbryan
Re: OSPF fast timers bug?
Thu May 18, 2023 4:12 am
I posted a reply on Facebook, but try slightly altering your timers. For example, I have hello at 1s and dead at 4s.
nichky
Thu May 18, 2023 7:37 am
is not a bug.
Timers set: MUST to be the same on both/all sites
paolobyte
Tue May 23, 2023 10:16 am
is not a bug.
Not necessarily. What makes you say that? There's no such rule as that.
Timers must be identical on the each ends of the OSPF session, not across all sites/network
paolobyte
Tue May 23, 2023 10:17 am
This issue has subsided.
Setting high dead timers somehow prevents the flaps to happen. it just doesnt make sense, all I see is that Mikrotik is poor at handling this.
Users browsing this forum: clambert, pmcsill and 186 guests
