alan02
It's possible if creating vpn Mikrotik site A to Mikrotik site B through Fortigate?
Thu May 18, 2023 1:50 pm
Hello everyone, i have stuck in my configuration.. When i tried config vpn ipsec Fortigate to Mikrotik still no luck because Mikrotik site is using Private Ip.
here's my topology,
i was planning to config Mikrotik Site A to Mikrotik Site B through Fortigate is it possible?
thanks, your help is really appreciate
BartoszP
Re: It's possible if creating vpn Mikrotik site A to Mikrotik site B through Fortigate?
Thu May 18, 2023 2:01 pm
VPN behind other firewall is possible but you need to check if Fortigate does not block VPN traffic.
alan02
Thu May 18, 2023 2:40 pm
i did config using pptp, and allow policy through fortigate but still no sign connected...
BartoszP
Thu May 18, 2023 4:17 pm
Can you connect with IPSec to Site B with computer? Try this. If yes then you know that Fortigate is not a problem.
alan02
Fri May 19, 2023 5:25 am
well that's possible? the site B Mikrotik Gateway wan is using private ip
BartoszP
Fri May 19, 2023 11:34 am
So there is one router in front of Site B missing ... didn't spot the private address. Does this missing router allows incoming VPN and passing it to Site B mikrotik?
alan02
Fri May 19, 2023 12:34 pm
Thanks for reply, well front Mikrotik Site B is ISP/Modem where's i dont have access into it. Mikrotik site B using 192.168.1.1 to 0.0.0.0 dhcp from isp
alan02
Fri May 19, 2023 12:36 pm
There's another solution except using ipsec?
AntiUltimate
Fri May 19, 2023 2:16 pm
SSTP should get through it. Maybe not with self-signed certificate though.
https://help.mikrotik.com/docs/display/ROS/SSTP
Users browsing this forum: Bing [Bot], jamesperks, maldridge and 104 guests
