nimda
Edit specific NAT rule
Thu May 18, 2023 3:08 pm
The command doesn't work.
/ip firewall nat set [/ip firewall nat find out-interface=l2tp-out1 ] disabled=yes
/ip firewall nat set [find out-interface=l2tp-out1] disabled=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=l2tp-out1
[admin@821] /ip firewall nat> /ip firewall nat set [find out-interface=l2tp-out1] disabled=yes
[admin@821] /ip firewall nat> export
Where is the mistake?
anav
Re: Edit specific NAT rule
Thu May 18, 2023 3:33 pm
Buying an MT router?
Not taking a training course?
Try the rule ENABLED! ;-)
/ip firewall nat set [/ip firewall nat find out-interface=l2tp-out1] disabled=yes
nimda
Thu May 18, 2023 5:08 pm
How is this command written correctly?
anav
Thu May 18, 2023 5:17 pm
Sorry I dont write commands.....
I go into winbox and make config change
nimda
Thu May 18, 2023 5:23 pm
With this, the following command works correctly.
/ip firewall nat set [find dynamic=no] disabled=yes
but not these
/ip firewall nat set [find where out-interface=l2tp-out1] disabled=yes
rextended
Thu May 18, 2023 7:02 pm
what is l2tp-out1, a "system something"?
If not, why you do not use " "?
# disable
disable [find where out-interface="l2tp-out1" and disabled=no]
# enable
enable [find where out-interface="l2tp-out1" and disabled=yes]
Offtopic:
Even if then there is to understand why you want to deactivate exactly that rule....
anav
Thu May 18, 2023 8:33 pm
To make rextended points clear........ Imagine software on the spaceship......
disable <----- NONSENSICAL
disable [find where dst-location="earth-home" and disabled=no]
enable
Logical.......
enable [find where dst-location="earth-home" and disabled=yes
Users browsing this forum: gkhun, unhuzpt and 67 guests
