rextended
test message on MikroTik app received
Fri May 19, 2023 12:53 pm
Thanks.
LaurensHPS
Re: test message on MikroTik app received
Fri May 19, 2023 1:03 pm
Yes me too, someone accidentally sent out a broadcast message?
fragtion
Fri May 19, 2023 1:08 pm
Same... They apologised in the message so they probably knew we'd all get it?
Hrm... didn't know this app could receive live cloud messages on demand, that's a bit unnerving to be honest. What other information is communicated via this app that we aren't aware of?
Zallius
Fri May 19, 2023 1:17 pm
Let me guess, we all agreed to this breach of trust somewhere in the Terms of Use before installing the app. Apology not accepted. Notifications now permanently disabled, considering full app removal.
rextended
Fri May 19, 2023 1:35 pm
Don't get paranoid, I've analyzed the app, it doesn't transmit anything (except the IP number where you're calling from, obviously).
They added the critical security information in real time (VERY GOOD), they are preparing for it:
viewtopic.php?t=196303
ErfanDL
Fri May 19, 2023 1:44 pm
Same here...
dioeyandika
Fri May 19, 2023 1:45 pm
i got the message on the second phone, kinda surprise, check the router nothing wrong, are mikrotik app is going to commercial with ads maybe?
rextended
Fri May 19, 2023 1:49 pm
Did you read my post without starting with the fancy conspiracies?
dioeyandika
Fri May 19, 2023 1:53 pm
i did, i am just guessing, until we get official answer from mikrotik, maybe they testing new feature
normis
Fri May 19, 2023 2:06 pm
Mistake by our team. Nothing to worry about. Please ignore :) No conspiracy.
rextended
Fri May 19, 2023 2:14 pm
No no, don't be sorry, if it's about the security warnings, you're right!
All users waiting official response on this:
I thought it was a test to warn everyone...
normis
Fri May 19, 2023 2:18 pm
Yes, notice will be posted there too. Suggestion to prepare for upgrading ROS soon if you use Ipv6
holvoetn
Fri May 19, 2023 2:37 pm
Q: how come some receive this message and some don't ?
normis
Fri May 19, 2023 2:39 pm
Android malfunctioned. iPhone users did not get it.
Or you have notifications off for the mikrotik app
holvoetn
Fri May 19, 2023 2:40 pm
No, just checked for Mikrotik app. Notifications are on.
And yes, Android.
normis
Fri May 19, 2023 2:41 pm
it was a mistake to begin with, I don't think it's worth investigating, why mistake happened only partially :D
holvoetn
Fri May 19, 2023 2:49 pm
I understand it was a fluke but in the context of pushing notifications to users (which CAN be helpful), it might be a problem if some get it and some not.
Something for a "someday/maybe"-list.
rextended
Fri May 19, 2023 3:07 pm
I have received notification on all my android phones, but not all at the same time, 10/20 min differences.
rextended
Fri May 19, 2023 3:08 pm
If you didn't understand it (excluding it is preparatory to advertising) we are happy with this!
anav
Fri May 19, 2023 3:45 pm
What APP, what SETTING
I have the MT app and use it in conjunction with wireguard to access configs.
There is no 'NOTIFICATION' setting that I can find???????
normis
Fri May 19, 2023 3:47 pm
Each app can have notifications enabled in the SYSTEM settings. How are you guys able to use the forum, but unaware of how smartphones work?
holvoetn
Fri May 19, 2023 4:04 pm
Ah but that's an easy one.
Fora (plural for forum) existed already BEFORE smartphones did.
And BTW, in that other thread I indicated I DO have notifications enabled but I did not receive them either.
You said yourself you did not understand how that message could have gone out.
So who doesn't know how it works ? :lol:
<luckily it's Friday ...>
anav
Fri May 19, 2023 4:10 pm
There is no such thing as notifications on the iphone Mikrotik App itself.
Both in the above pic, and the below pic, I fail to find anything resembling notifications......
If you are talking on generic notifications setting on iphone, yes set to ON, but none received........ which is probably a good thing, spam is no fun.
Users browsing this forum: Benzebub, networknoob984651, zabloc and 49 guests
