rfok
OpenVPN Client Supported Options
Sat May 20, 2023 6:11 pm
Hi
This is what's inside the .ovpn file that my VPN provider gave me
client
dev tun
proto udp
remote somevpnsite.net 8041
verify-x509-name somevpnsite.net name
resolv-retry infinite
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping 15
ping-restart 0
reneg-sec 0
remote-cert-tls server
comp-noadapt
auth-user-pass
auth sha256
cipher AES-128-CBC
verb 3
<cert>....
I could import it easily via import .ovpn button in PPP.
But I think RouterOS 7.9 doesn't supprt all of these options. For example resolv-retry infinite.
Therefore my connection is not stable and the OpenVPN Client cannot recover itself automatically
Am I right?
MickeyT
Re: OpenVPN Client Supported Options
Mon May 22, 2023 10:52 am
You are correct that the RouterOS OpenVPN client does not retry to connect when the connection fails or drops and the resolv-retry infinite has no effect.
Currently the only option I am aware of to automatically reconnect would be to write a script that checks the connection and initiates a reconnection attempt if it is down. You would then schedule the script to run on a periodic basis (e.g.: every 5 or 10 minutes).
Users browsing this forum: Mr47, mtkvvv, pajapatak and 129 guests
