smbecker3673
Prevent MPLS importing routes on ros7
Sun May 21, 2023 1:12 am
I only use MPLS/LDP to create layer 2 VPLS tunnels. In ros 6 I never had any issues, since ros 7 it imports a bunch of routes which cause the connection to flap and eventually die. I was going to use a routing filter but they completely screwed that idea up in ros 7, for me anyway, I could figure them out in ros 6.
This is primarily for a voip phone that needs layer 2 and VPLS has always worked better than l2tp or eoip, until ros 7 of course.
wiseroute
Re: Prevent MPLS importing routes on ros7
Sun May 21, 2023 12:21 pm
hello,
did you do a version 7 test/ poc - before you put it in production?
well, maybe the best way to reach out @ support - along with your config details.
Users browsing this forum: No registered users and 13 guests
